Pug}{maN Posted June 4, 2012 Share Posted June 4, 2012 that is my neighbor ! lol. yes we make knifes in the street with heat on our hips ! its grate... Quote Link to comment Share on other sites More sharing options...
hiltsbilt Posted June 17, 2012 Share Posted June 17, 2012 well just got mine finished today. went with 2x12 for my 90# PW, put a peace of rubber under the anvil to dull the sound, ill add a hammer holder latter Quote Link to comment Share on other sites More sharing options...
hiltsbilt Posted June 17, 2012 Share Posted June 17, 2012 pics help lol Quote Link to comment Share on other sites More sharing options...
KenHMT Posted October 3, 2012 Share Posted October 3, 2012 this is my Anvil stand Great stand - looks really sturdy! We've added it to our growing database at homemadetools.net: http://www.homemadetools.net/floor-mounted-anvil-stand Ken Quote Link to comment Share on other sites More sharing options...
KenHMT Posted October 3, 2012 Share Posted October 3, 2012 I went with 2X12's. I used an oak stump first, but I couldn't cut it straight enough. Nice one! I like the convenient tool storage, too. Added to the homemadetools.net database: http://www.homemadetools.net/wooden-plank-anvil-stand Ken Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 3, 2012 Share Posted October 3, 2012 If you make your tool holders sturdy enough you can use them as handles to move the stump around. In general I claim it is not a good idea to try to pick up and move both the anvil and stump at the same time for systems where the anvil just drops in---had a couple of college kids try that and ended up dumping my 134# HB onto it's nose on the concrete shop floor. No damage to the HB but the floor will have that divot *forever*. Quote Link to comment Share on other sites More sharing options...
Jeff Lodge Posted October 3, 2012 Share Posted October 3, 2012 The stand is White Oak. I used a router to cut in the top so the Anvil would sit into the stump. I also tapered the sides of the stump with a chain saw to make the bottom a touch more stable. 170lb HB sits on top with a rubber mat between the anvil and stump to help with the ring. Quote Link to comment Share on other sites More sharing options...
Suboc Posted October 3, 2012 Share Posted October 3, 2012 Here is the stand I made for my 450# Nimba. The shelf on the right pivots or is removed easily. Quote Link to comment Share on other sites More sharing options...
Anvil Guy Posted October 3, 2012 Share Posted October 3, 2012 Here is the stand I made for my 450# Nimba. The shelf on the right pivots or is removed easily. Wow! That looks great, nice job!! Quote Link to comment Share on other sites More sharing options...
VaughnT Posted October 3, 2012 Share Posted October 3, 2012 Suboc, that's gorgeous work! Quote Link to comment Share on other sites More sharing options...
Suboc Posted October 3, 2012 Share Posted October 3, 2012 Wow! That looks great, nice job!! Thanks, I had fun with making it, and being a visual person I wanted it to look interesting as well as be functional.. I thought using 3/4" button head rivets to construct it seemed appropriate. Quote Link to comment Share on other sites More sharing options...
Bigcity Posted October 5, 2012 Share Posted October 5, 2012 I had to make a new base for my anvil i went with 4x4s bolted together. It seems to be more solid than the old stump i had before which was maple i think. Quote Link to comment Share on other sites More sharing options...
01tundra Posted October 8, 2012 Share Posted October 8, 2012 2" x 4" x 1/4" legs filled with sand, 1/4" plate feet on top of 2" Red Oak blocks, 1" thick mounting plate, 2 layers of 30# roofing felt between the anvil (155 lb. Hay Budden) and mounting plate, 3/8" drop-in concrete anchors & Grade 8 bolts fastening the stand to the slab. Fabrication details - http://www.iforgeiro...l +stand +build Quote Link to comment Share on other sites More sharing options...
royce unruh Posted October 8, 2012 Share Posted October 8, 2012 my stand for my #2-0-12 pw here is the link i now have a 100 lb pw too it sits on a stump dad brought over thiking i wouldnt be satisfied with my metal stand Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted October 26, 2012 Share Posted October 26, 2012 I thought I'd add my stand to this thread. It is made from a couple of bits of I-beam, cut with my plasma and welded together in the centre, plus a 20mm plate on top and for the feet. The shape allows my feet to get nice and close, personally I don't like being restricted by a wide based anvil stand (stump etc). I drilled a few holes for future tool-holders etc etc, plus some in the feet in case I want to bolt it down, but I haven't needed to yet, its a 5 cwt anvil which helps. I used plasticine / modelling clay in between the anvil and stand, just a thin layer. It doesn't ring, move, wobble or waste energy. I recommend it. Cheers, Al. Quote Link to comment Share on other sites More sharing options...
Spots Posted October 26, 2012 Share Posted October 26, 2012 200 lb Kholswa anvil, on a large seasoned oak stump, 3 ft deep in the ground. Having it that deep, on a stump that large and heavy definetly helps when it comes to moving big steel. Straps around the stump for the most often used hammers and hardy tools Quote Link to comment Share on other sites More sharing options...
Big-D Posted October 29, 2012 Share Posted October 29, 2012 Here's mine: Quote Link to comment Share on other sites More sharing options...
VaughnT Posted November 4, 2012 Share Posted November 4, 2012 Never realized that I hadn't contributed, so here's mine! She started life as a pile of 1"x1" solid bar that my dad got from his work. There wasn't a straight piece in the whole lot and most of it had deep gouges from the machine it came from. Nasty stuff that worked like rebar, but it was free and available!! I wanted to do something different to hold the anvil in place. The anvil weighs over 300# so I'm not too concerned with it bouncing or walking - a couple of big bolts should suffice. Plus, the bolt under the hardy makes for a convenient place to hook a spring-loaded hold-down. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted November 4, 2012 Author Share Posted November 4, 2012 Handsome and stout looking. Since it is solid putting locating pins in, if needed, will be easy. Great idea! Phil Quote Link to comment Share on other sites More sharing options...
VaughnT Posted November 5, 2012 Share Posted November 5, 2012 Thank you, Phil. I might do some more welding to it in the future, after working with it for awhile. I can see a tool tray or hammer loop coming into play, and maybe a hot-cut holder. Who knows?! Right now, I'm just glad it's done and together! Quote Link to comment Share on other sites More sharing options...
Borntoolate Posted January 3, 2013 Share Posted January 3, 2013 This is a fascinating thread that demonstrates the creativity of the folks who visit this site. There are a lot of different anvil stands made from many different materials. I assume much of this is just making do with what is available as well as some folks who work to acquire specific materials to accomplish a specific outcome. Anyway BRAVO to all! My anvil stand is something that I am continually critical of and also one that I continually wish to modify or tweak but also one that works. Changing/improving it is a balance between using the anvil and making a new stand to support it. I tend to create more scale around it than work to make it better. But then... I am basically lazy. Quote Link to comment Share on other sites More sharing options...
Rockcrusher Posted January 9, 2013 Share Posted January 9, 2013 Here is an anvil stand I just finished fabricating for my 400# West anvil. It started with a heavy piece of H-beam. The legs were cut from some 3/4 x 8" flat bar and welded on slightly splayed out. I decided to enclose the open center of the H-beam by putting 1/2" plate doors on either side with some heavy self closing hinges. This leaves a pretty good size storage area inside the stand for hardy tooling and or swage blocks. I have room for three hammers on the ends under the heel and horn but still need to add a couple more holders for them. Top plate is 1" Steel plate drilled and tapped for the clamp bolts. The bottom of this anvil wasn't planed very flat so to get it to set level I formed in a trough and seated the anvil in 15 lbs of molten lead. Dead solid and that alone killed most of the ring. I topped off the lead trough with Belzona (industrial liquid metal) to contain the lead so no risk of exposure. The black finish is just used oil from my diesel painted on and rubbed mostly off....slows down the rust. Total weight on the stand was around 350#. I really don't expect to move it often but if neccessary I can get it around the shop on a heavy hand truck. Any way here are a couple pics of the works. Ed Quote Link to comment Share on other sites More sharing options...
Brezolin Posted April 29, 2013 Share Posted April 29, 2013 My anvil stand... Quote Link to comment Share on other sites More sharing options...
darren70 Posted April 29, 2013 Share Posted April 29, 2013 Here is mine http://www.iforgeiron.com/gallery/image/37086-stand/ http://www.iforgeiron.com/gallery/image/37087-stand/ Thanks Quote Link to comment Share on other sites More sharing options...
Davidrw70 Posted August 30, 2013 Share Posted August 30, 2013 Spent the last couple of days building the stand for my 209# Peter Wright....... I just need to add some tool holders..............Next comes the forge.... Quote Link to comment Share on other sites More sharing options...
