Had a somewhat unproductive day in the sense that nothing came out quite how I wanted. I had always seen the old plantation hoes and wondered how they might be forged, I gave one a try today out of 5” of 1” square mild steel with a high carbon but forge welded in. It’s kinda wonky, but in general it’s ok. Forged a couple hardy tool billets to be upset tomorrow and made into cupping tools, and also forged a small stubby 1lb cross pein that came out weird. Also handled one of the sledges I forged and a 4.5lb rounding hammer.
  • Replies 26.3k
  • JHCC
    3141
  • ThomasPowers
    1935
  • Frosty
    1649
  • Daswulf
    1642
That’s what I figured, especially since being out of wrought that would be the smartest option. Mine I just punched and drifted. I took some pictures during the process that might be interesting to some. Starting stock 5” of 1” square. I upset and forged it on the diagonal, so to be able to spread a wider blade and have a taller eye.
Don't forget that they were an agricultural tool, and mostly made for use by slaves or subsistence farmers.  They would have been made of mostly wrought iron the cheapest way possible (forge welded, even the eye) and then used, remade, used again, etc.  Surviving historical pieces are mostly worn out!  Originals were probably bigger before wear.
Unrelated note, those are my favorite kind of tongs!
I had seen some examples up in ME some in MA and then a few in VA..  It was kinda neat seeing the different levels of wear..  Also neat seeing how big some of the originals were.
We have no real concept today of what things used to be even in early America.
Nice job LBS.. Great work.   You have grown so much as a smith..  I love stories like yours and thanks for sharing it.
Real nice Mark. Always great work from you.
Here's a bit of mine. Bottle opener didn't come out quite like I envisioned, but I know what to do different with anything like it again. My friend's last name is Hercules ( ain't that cool?) so it's an H. Spoon needs finish work. I have some more, but I didn't want to drag them all in the house. I'm getting better with the bowl shape I think. Y'all have a good night and take care out there
Due to strange times, I am out of work for the next few weeks. I believe I will find myself stripping scale off of older unfinished pieces and wondering what to do with the used vinegar. Anyone have ideas? BTW, everyone seems to be doing some great work keeping busy.
You can use it for a stain on woods that are high in tannins -- oak, ash, etc. The vinegar reacts with the iron oxides to produce iron acetate, which in turn reacts with the tannins to produce iron tannate -- a black metallic salt. This is the classic "ebonizing" finish of European cabinetry.
Jungle, sorry to hear about your job situation. It's hitting us too.
Thank you Jennifer, Les and Rojo. The opener is just 1/4" × 1" flat stock. I wanted it to be a little more robust, but after filing where I chisel cut out the top and bottom of the H to clean it up, I was left with much less material than I anticipated.
May I suggest a hack saw, Chellie? If the traditional police give you flack point out they've been around a lot longer than working iron, pre metal in fact. Sawing is fast and leaves a LOT less file work. I like the opener by the way, I think you have something really marketable with a little more development. Make more, they'll sell.
All you guys are showing some excellent work and outstanding improvement in your skills. Please don't think I don't notice I only have time to comment on a few posts. Things are a little hectic here right now. I sure wish that were for a better reason. <sigh>
Thanks Frosty. And I have that very idea of a hacksaw in mind. I use any tool available if it gets the job done. I just try to do as much with simple tools as possible. My hacksaw sees a lot of use.
I just ordered my dog's RX food from Chewy. It usually arrives he next day, but it says they are backed up and it may be 5-8 days before it gets here. I understand. Strange times indeed
Finished the stand and cleaning up a swage block that I will now try and sell. 175lber. I put the half inch bolts on the side that act as set screws and keep it from jumping and wiggling while being used. Also finish ground and handled a 4lb axe I forged while in Montana with Ethan and Jonathan.
Worked on my table legs some today. They are coming along nicely. Not what i would want but it is what my buddy wants so, hope he likes them.
Tried my hand at making a heart. First one, i think the heart came out good, the rest ehh, but i was a little tired after having to R&R a new ford explorer this PM. The old lady likes it, so that is the important part.
Thanks JHCC, that is great! I am actually working on a wood project that could use it.
It’s a good thing we are a resourceful bunch.
7 hours ago, ThomasPowers said:
Used vinegar: I always have poured it out on the gravel driveway.
I bet some plants wouldn’t mind.
Finally began the somewhat daunting task, in my opinion, of making a hot cut hardie for my anvil. Certainly the biggest piece of material I have worked on (my anvil has a 1" hardie hole) and my little forge was actually was able to keep up, which I am happy about.
Started with a 3/4" sq drop 5 maybe 6 inches long I had picked up at the steel supplier (they have a huge collection of miscellaneous drops they sell by weight). I upset it to 1", plus a bit, square then formed the shank and flattened out the rest to make the what will be blade. Then cut a slot down the middle, made a wedge with some 1/8" 1095 and forge welded that in for what will be the edge. I don't think this is necessary, and I'll have to temper it back significantly to avoid potential shrapnel, but it was fun. I've never tried that before.
It's not very pretty, but it was quite a lot of heavy hammering, and overall I'm happy with the result. Tomorrow I'll put an edge on it, heat treat, and it will be put to good use. My angle grinder has been doing all my cutting up to this point, but it's loud and my neighbors already put up with plenty of noise.
My brothers knife is coming along nicely, still hand sanding, but I couldn't help taking a peak at the pattern now that I'm getting close to final thickness.
Thanks, I admit it was by chance, and not what I was going for initially. I had filed down through the layers with a round file and flattened out the tiny billet (like a ladder pattern). However, I have at this point sanded through all that and this is what was left.
Darnit, Frazer, you are supposed to go into a lengthy dissertation about how you carefully and methodically created such a pattern.  Talk about disappointing.  :rolleyes:  You've let down the entire IFI community if you can't tell us how to replicate that pattern. :lol:
