BillyBones Posted August 18, 2019 Share Posted August 18, 2019 I had to stay with a friend for a minute and his wife raised guinea pigs. She had about 40 of them. They are the most annoying creatures when in a bunch i have ever been around. 1 aint so bad but that many with all the squeaking... Quote Link to comment Share on other sites More sharing options...
CrazyGoatLady Posted August 18, 2019 Share Posted August 18, 2019 This little guy isn't actually mine. He's staying with us for awhile. His name is Samwise. I've never had a Guinea pig before, but I love this little critter. He loves pets and snuggles. And hay I think when he goes home, I'll have to get one. Add another critter to the menagerie. Quote Link to comment Share on other sites More sharing options...
pnut Posted August 18, 2019 Share Posted August 18, 2019 The indigenous folks raise them for food in the Andes. Mmm mm. Just kidding I don't know how tasty they are. I like the little critters. They do make a bunch of different noises. I could imagine a herd of them could get a little annoying. Pnut Quote Link to comment Share on other sites More sharing options...
eseemann Posted August 18, 2019 Share Posted August 18, 2019 23 hours ago, JHCC said: The question is, was the hay buddin’? That is a bad pun by my (very low) standards. 3 hours ago, pnut said: The indigenous folks raise them for food in the Andes. Mmm mm. Just kidding I don't know how tasty they are. I like the little critters. They do make a bunch of different noises. I could imagine a herd of them could get a little annoying. Pnut A herd of guinea pigs, looking out on the yard and seeing nothing my lumps of furry cuteness, all little squeaky voices and whiskers. There are people that have a fear of mice and such that would extend to guinea pigs but not me. Can you imagine what it would look like driving this herd from one pasture to the next. There is a Far Side comic waiting to happen. Quote Link to comment Share on other sites More sharing options...
671jungle Posted August 18, 2019 Share Posted August 18, 2019 On 8/16/2019 at 8:29 PM, Daswulf said: I'm sure I'll ask where this gas forge has been all my life once done tho. Congrats! They are fun to light! Fun to build too! The sound from my two 1/4" burners is kinda soothing. But they are only 1/4"ers. On 8/16/2019 at 7:21 PM, Frosty said: I only anchor things that really need anchoring. I too am always rearranging until things find their cozy little nooks. The idea of portable is appealing. This piece of gym equipment scrounged from the metal bin is what I have on hand. the "4x4" is only for reference. some cutting/tweaking with optional stake holes may make it a candidate for a postvise stand. On 8/16/2019 at 7:21 PM, Frosty said: gozinta pin could not come up with search results as to what this is. Quote Link to comment Share on other sites More sharing options...
BillyBones Posted August 18, 2019 Share Posted August 18, 2019 A gozinta pin is a pin that gozinta the hole. Quote Link to comment Share on other sites More sharing options...
671jungle Posted August 18, 2019 Share Posted August 18, 2019 Oh jeez. That was good. Thanks BillyBones. I even asked the almighty google. Well in that case I have plenty Gozinta pins! Quote Link to comment Share on other sites More sharing options...
Jon Kerr Posted August 19, 2019 Share Posted August 19, 2019 Picked up a new leg vice today. It was a lucky eBay win.... £25. Turns out it has 5" jaws and must weight 30kg at least. Its almost seized up but the screw is well greased and looks perfect. The jaws have replaceable plates like a bench vice which seems to be unusual. Is this a problem? The screws holding these plates in place are dropping out so I assume the threqds are stripping. Is this likely to be original or a badly thought through modification?? Quote Link to comment Share on other sites More sharing options...
Chris C Posted August 20, 2019 Share Posted August 20, 2019 I picked up a nice chisel at a garage sale for 10 cents. The name on it is Mayhew Alloy. Has a sharp ring to it, so I'm guessing it's hardened and is a cold cut chisel. It has a 1" wide cutting surface. Can I assume correctly it will work with hot cutting? Or would it be better to naturalize it first? Quote Link to comment Share on other sites More sharing options...
Steve Shimanek Posted August 20, 2019 Share Posted August 20, 2019 Mayhew was produced domestically as far as I remember, so no need to go about naturalizing, checking passports, etc. However, it will probably be too short for hot cutting, unless you hold it with tongs. Quote Link to comment Share on other sites More sharing options...
JHCC Posted August 20, 2019 Share Posted August 20, 2019 Or wear a glove on that hand. Quote Link to comment Share on other sites More sharing options...
JHCC Posted August 20, 2019 Share Posted August 20, 2019 Couple of days’ haul: a used 1HP motor, a magnetic-mount lamp, some safety gear, a toaster oven, and an old file (all for about sixty bucks from the industrial surplus place) and 25 lbs of 1/2” square drops from my steel supplier. The motor isn’t working right now, but I’m hoping that’s just a matter of a loose connection inside the ammeter box. Quote Link to comment Share on other sites More sharing options...
Chris C Posted August 20, 2019 Share Posted August 20, 2019 1 hour ago, Steve Shimanek said: Mayhew was produced domestically as far as I remember, so no need to go about naturalizing, checking passports, etc. However, it will probably be too short for hot cutting, unless you hold it with tongs. It's 8 1/2" long, so a gloved hand wouldn't have a problem with the heat. Boy, JHCC, I'd love to pick up a motor like that. Really hope to build a 2x72 belt sander some day. Quote Link to comment Share on other sites More sharing options...
JHCC Posted August 21, 2019 Share Posted August 21, 2019 My 2x90 has a 1-1/2HP motor, which I’d consider the bare minimum. 1 hour ago, JHCC said: I’m hoping that’s just a matter of a loose connection inside the ammeter box. Turns out to have been a cut wire that was quickly reattached, and now everything works great. Unfortunately, the small pulley I was planning to use is for the wrong shaft size, so I’ll have to get another one. Quote Link to comment Share on other sites More sharing options...
Les L Posted August 21, 2019 Share Posted August 21, 2019 A friend changed the "fingers" on his hay rake and brought me the old ones. 32 pieces of 1/4 x 16 round spring steel Quote Link to comment Share on other sites More sharing options...
Reeltree Posted August 21, 2019 Share Posted August 21, 2019 I use them to make hooks Quote Link to comment Share on other sites More sharing options...
picker77 Posted August 21, 2019 Share Posted August 21, 2019 Wow, a little gold mine. Reeltree, I suppose they would certainly make really nice (and very strong!) hooks, but it would seem overkill to use good quality spring steel on things that are usually made from cheaper, easily obtainable mild stock. Were it me, I think I'd save those for a "higher use" application, ha. Anyway, lots of good material there, Les, have fun with it! Quote Link to comment Share on other sites More sharing options...
pnut Posted August 21, 2019 Share Posted August 21, 2019 They'd make nice leather awls and maybe ice picks. Quote Link to comment Share on other sites More sharing options...
Reeltree Posted August 21, 2019 Share Posted August 21, 2019 Perhaps so Picker if I did not have so many from years and years of having to replace broken hay tines. Quote Link to comment Share on other sites More sharing options...
picker77 Posted August 21, 2019 Share Posted August 21, 2019 Excellent, I envy you having a good supply like that. Recycled spring steel in small sizes seems to be relatively rare around here, although large junked coil springs are available if you can get help to carry one to your truck. Quote Link to comment Share on other sites More sharing options...
Chris C Posted August 21, 2019 Share Posted August 21, 2019 Picker. Stop by most any over head door replacement guys in the phone book. They throw springs in the garbage every night. Quote Link to comment Share on other sites More sharing options...
picker77 Posted August 21, 2019 Share Posted August 21, 2019 Good idea, Chris. Thanks. I'll check that out. Quote Link to comment Share on other sites More sharing options...
Chris C Posted August 21, 2019 Share Posted August 21, 2019 The one I picked up was 1/4" spring wire. The guys at Korney's said to just stick as much of it as I could get in the forge, drop it down over a piece of rebar clamped in a vise and grab the end with a pair of vise grips and "head south". Cut it off where it stops unwinding.................and repeat as necessary. Haven't done it yet, but it made sense to me. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted August 21, 2019 Share Posted August 21, 2019 I have door springs in several sizes, so much so I quite collecting them. What they said about straightening them works really well. If I straighten all I have they would probably reach Oklahoma. Quote Link to comment Share on other sites More sharing options...
Chris C Posted August 21, 2019 Share Posted August 21, 2019 That was the one thing they warned be about.................said I'd end up with a much longer piece than I thought. Oh well, just stop when you have what you need and cut it off. There will be plenty left. One of the guys said he heated up a full spring and did that and ended up going clear out the door of the shop. 3.1416 x the diameter of the spring x the number of coils......it'll amaze you. Quote Link to comment Share on other sites More sharing options...
