Irondragon Forge ClayWorks Posted September 6, 2018 Share Posted September 6, 2018 Mudman If you lay a bead of latex calking compound around under the anvil it will deaden the ring even more. I was skeptical about this but tried it on an ear splitting cast steel MP farriers anvil and it's now as quiet as any Fisher or Vulcan. My wife made this steak turner yesterday. Made out of an old wrought iron RR spike. Quote Link to comment Share on other sites More sharing options...
VaughnT Posted September 6, 2018 Share Posted September 6, 2018 Very nice work, Mud. That's a nice anvil, and I appreciate the extra work you went through to make forged hold downs and angles for the set up. It looks very professional. Quote Link to comment Share on other sites More sharing options...
Mudman Posted September 7, 2018 Share Posted September 7, 2018 3 hours ago, Irondragon Forge & Clay said: That's my plan as well, but I've decided on a bigger stump. There's a guy with a good size piece of Chinese Elm. So I was going to do the same thing, except not screw up this time. Then inset the anvil, and so the silicone. 3 hours ago, VaughnT said: Thanks, It was actually Faram's lol. He and I were brainstorming- which I only added 1% valuable input. Then he remembered he had those mounts, and gave them to me . Quote Link to comment Share on other sites More sharing options...
MC Hammer Posted September 7, 2018 Share Posted September 7, 2018 Don't forget to band up your stump with thin bands or it will split over time. One on the top and bottom works just fine, but don't screw them into the wood yet. I bolted mine together and when I stop having to tighten it at all then I'll know my stump is pretty much not going to shrink anymore. It's been 2 years and I think I'm just about ready to put the bands on permanently. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted September 7, 2018 Share Posted September 7, 2018 Mudman, that size stump allows you to work close to the anvil, and provides clearance for long items worked over the horns. Try just adding a widewr foot for stability , but I would probably leave it as is. As to green stumps. Checking and splitting come from drying too fast. If you seal the end grain with wax or paint it dries much slower and less checking/splitting if any occurs. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 7, 2018 Share Posted September 7, 2018 Note that changes in ambient humidity will continue to affect air dried wood pretty much forever---at least furniture from king Tutankhamen's tomb is reported to still change with ambient humidity. Quote Link to comment Share on other sites More sharing options...
sfeile Posted September 7, 2018 Share Posted September 7, 2018 Got some more work done on the razor between swatting mosquitoes today. Quenched and tempered it yesterday, then got it just about ready for scales and honing today. Still a little refinement to do on the tang, but almost there. (Next to my Tanifuji for size reference) I actually got the edge centered. It's right at 1/2 hollow for the grind. Quote Link to comment Share on other sites More sharing options...
MotoMike Posted September 7, 2018 Share Posted September 7, 2018 Looks killer Shawn. the hollow is from your grinder you just put the tool rest on? Quote Link to comment Share on other sites More sharing options...
sfeile Posted September 8, 2018 Share Posted September 8, 2018 Thanks Mike! Yep, that's what I used. Gets tricky not to over heat it when it's that thin, but I think it turned out ok. That finish is from a 600 grit trizact belt. Turned out being a very nice satin finish. Quote Link to comment Share on other sites More sharing options...
JHCC Posted September 8, 2018 Share Posted September 8, 2018 Today was welding, taking the back end of my treadle hammer’s arm from this: To this: This has no effect on the hammer while it’s in operation (apart from needing one fewer return spring), but it brings the hammer head higher up and farther out of the way when the pedal is disconnected. This makes regular work at the anvil easier. Also welded up some bits of pipe and plate onto a tire rim for what will ultimately become a work stand. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted September 8, 2018 Share Posted September 8, 2018 Sfeile, thats turning out great. Always like seeing whats next John. I've been getting and throwing away these subaru door hinges for a while thinking they would make a cool octopus. Well I tried one as a wall hook. And it hinges for no purpose whatsoever. Cathulu like? Ah well, a good hooky thing. Images are of it screwed into a board. Quote Link to comment Share on other sites More sharing options...
SLAG Posted September 8, 2018 Share Posted September 8, 2018 I love it., it bears an uncanny resemblance to some of my relatives!, Try Robertson screws (square drive), instead of the straight screws for a slightly more realistic look for the beast. The centered square 'slot' looks more like a realistic eye, than the straight slot and Phillips screw heads. Those superior Robertson screws are usually available in woodworking stores. They can sometimes be found in some of the big box stores. (I did buy some at a Home Hardware a while back). They are, also, for sale in any hardware store in Canada where straight slot screws have been substantially supplanted by them. That screw head was invented in Canada. (patented in 1909, by you guessed it, Mr. Robertson). Hence its wide use and popularity in that country. Boatbuilders also use the Robertson screw. So boat builders supply sellers should have them too. Give it a shot. SLAG. Quote Link to comment Share on other sites More sharing options...
Mudman Posted September 8, 2018 Share Posted September 8, 2018 Thanks fellas, I'll work on some straps tomorrow. Picked up some 1-1/4 x 1/8 flat stock today, but ended up not having enough. Need to pick up more tomorrow. Quote Link to comment Share on other sites More sharing options...
ausfire Posted September 8, 2018 Share Posted September 8, 2018 Das, that octopus hook is cool. I thought the 366 Hooks thread just about covered all but you've added another! And I like the slotted screws set vertically. Gives him a surprised look. The head reminds me of the robot in the movie Number 5. Quote Link to comment Share on other sites More sharing options...
JHCC Posted September 8, 2018 Share Posted September 8, 2018 Nice hook, Das. Very creative! Quote Link to comment Share on other sites More sharing options...
sfeile Posted September 8, 2018 Share Posted September 8, 2018 10 hours ago, Daswulf said: Sfeile, thats turning out great. Thanks Das! That hook is awesome!! Quote Link to comment Share on other sites More sharing options...
Daswulf Posted September 8, 2018 Share Posted September 8, 2018 Thanks Slag, I'll see what I can find. I have only noticed the square drive on decking screws. Thanks Aus, I have some other hinges to play with. You mean the movie Short Circuit? Or another movie? Thanks John and Sfeile. Quote Link to comment Share on other sites More sharing options...
Jasent Posted September 8, 2018 Share Posted September 8, 2018 Johnny 5 alive.... love it das. Quote Link to comment Share on other sites More sharing options...
sfeile Posted September 8, 2018 Share Posted September 8, 2018 1 hour ago, Daswulf said: I have only noticed the square drive on decking screws. They have cabinet screws, sheet metal screws, a lot of new electrical stuff is coming with square drive. They are out there, the trick is finding them locally. Some big stores like home depot or lowes, or even an electrical supply house should have something that would work Das. Quote Link to comment Share on other sites More sharing options...
Kevin Olson Posted September 8, 2018 Share Posted September 8, 2018 Disassemble!!! No disassemble number 5 Quote Link to comment Share on other sites More sharing options...
SLAG Posted September 8, 2018 Share Posted September 8, 2018 Das, You are welcome. Searching for a seller of Robertson screws close, to you is, probably, the easiest route. But if that proves too involved/complicated, mail order is the next best option. I decided to do a web search for Roberson screws. (for my own purposes), and found many sellers. I used the search term "Roberson screws". For example, try www.robertsonscrew.com. There are many other sellers out there so you have a wide choice of vendors. Happy hunting! Pilgrim, SLAG. Quote Link to comment Share on other sites More sharing options...
Dax Hewitt Posted September 8, 2018 Share Posted September 8, 2018 The razor is excellent and I love the octopus, brilliant stuff. The forging gods were not with me today, I just couldn't get the metal to move where I wanted it to. I did make a poker for a mate. It's only 6mm round bar, a bit thin to be much good but he finds his 8mm poker too heavy to use. I did my first fire weld too where I bent the tip back to form the rake. It didn't take 100% but I was happy for my first go. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted September 8, 2018 Share Posted September 8, 2018 Thanks Sfeile, Slag. I'll take a look next time im out and if no luck then I'll look online. Dax, thats a nice twisted handle. Forge welding is kind of like " once you get it, you get it." Keep practicing. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted September 8, 2018 Share Posted September 8, 2018 Das, since it is a hinge make a door knocker out of them Selfie, what is your sharpening process for the straight razor? Quote Link to comment Share on other sites More sharing options...
Daswulf Posted September 8, 2018 Share Posted September 8, 2018 Theres a cool idea. Quote Link to comment Share on other sites More sharing options...
