Marc1 Posted February 1, 2017 Share Posted February 1, 2017 Have you ever seen anything like this? ( not mine by the way) Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 1, 2017 Share Posted February 1, 2017 7 minutes ago, Marc1 said: Have you ever seen anything like this? ( not mine by the way) Looks like someone welded a hollow tail onto an anvil with a broken-off heel. Quote Link to comment Share on other sites More sharing options...
Tubalcain2 Posted February 1, 2017 Share Posted February 1, 2017 i would agree. definitely looks like a home-job. Quote Link to comment Share on other sites More sharing options...
Ridgewayforge Posted February 1, 2017 Share Posted February 1, 2017 This looks like a nifty way to do it- You could weld a tube down to strengthen the hardy hole, and then use the thin hollow tail to work on thin forks and things. Quote Link to comment Share on other sites More sharing options...
Al Stephens Posted February 1, 2017 Share Posted February 1, 2017 I like it! I've got one with no tail that I use as a spare for classes. I see this modification in it's future. Quote Link to comment Share on other sites More sharing options...
stockmaker Posted February 1, 2017 Share Posted February 1, 2017 You need to call this anvil Lee Marvin. Note the silver nose! Well, there was an image of THATS HOT's anvil here when I wrote the above post. See his anvil picture above for a great looking anvil and stand and a little bit of humor. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 1, 2017 Share Posted February 1, 2017 Cat Ballou; bit off by his brother as I recall Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted February 1, 2017 Share Posted February 1, 2017 21 hours ago, Millhand said: 400 lb columbion, won't put a hammer to it until I get my hammer arm tuned. Nice anvil. Largest Columbian I have seen.. How big is the hardy hole? Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 2, 2017 Share Posted February 2, 2017 32 minutes ago, jlpservicesinc said: jlpserviceinc, when quoting a comment, remember to delete any photographs unless they're absolutely necessary for a question. They really eat up bandwidth. Thanks. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted February 2, 2017 Share Posted February 2, 2017 1 hour ago, JHCC said: jlpserviceinc, when quoting a comment, remember to delete any photographs unless they're absolutely necessary for a question. They really eat up bandwidth. Thanks. Thanks for the reminder.. I'm still figuring stuff out.. In fact I can't seem to find the edit button to remove the picture.. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 2, 2017 Share Posted February 2, 2017 edit buttons disappear swiftly on this site; just one of the idiosyncrasies we put up with because *other* *people* are doing the heavy lifting to keep it running! Quote Link to comment Share on other sites More sharing options...
SLAG Posted February 2, 2017 Share Posted February 2, 2017 JPLS, The edit button disappears after one hour from posting time. Hopefully one of the moderators will clean it up soon. regards, SLAG. Quote Link to comment Share on other sites More sharing options...
Millhand Posted February 2, 2017 Share Posted February 2, 2017 2 hours ago, jlpservicesinc said: Nice anvil. Largest Columbian I have seen.. How big is the hardy hole? To large imo 1.5, I haven't made any tools for it yet. She's In great shape. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 2, 2017 Share Posted February 2, 2017 I have 3 anvils with 1.5" hardy holes and found an easy way to get tooling for them is to buy top swages with badly mushroomed ends and forge the striking ends down to fit the hardy holes. Luckily I have a large screwpress that is brilliant in dressing the sides flat and parallel after forging near to size. Quote Link to comment Share on other sites More sharing options...
Millhand Posted February 2, 2017 Share Posted February 2, 2017 Thanks Thomas, I've no screw press but am starting a big forging press build to do just that. I have found my hands will not take hours of the hammer, much to my dismay. Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 2, 2017 Share Posted February 2, 2017 You could also build a reducing fitting to slip into the hole and bring it down to 1" or whatever fits your existing tools. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 2, 2017 Share Posted February 2, 2017 I do that too, I took a section of sq tubing that fit and cut down the diagonals about an inch; then heat and bend out the tabs to rest on the anvil. I then repeated the process to have a nesting set that will take the hardy to a "standard" 1" so I can use the tools from other anvils on the big one---but I do make/modify large tooling for jobs I do a lot of! Quote Link to comment Share on other sites More sharing options...
arkie Posted February 2, 2017 Share Posted February 2, 2017 Great idea on the square tubing trick for the hardy hole! Thanks for posting. Quote Link to comment Share on other sites More sharing options...
G-ManBart Posted February 3, 2017 Share Posted February 3, 2017 I know this picture is pretty bad...just brought home my first Hay Budden. It's 145lbs and the serious number appears to be 146868, which I think should put it at 1907 based off other posts here (feel free to correct me). Better pics tomorrow: Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted February 3, 2017 Share Posted February 3, 2017 shes a bute.. Quote Link to comment Share on other sites More sharing options...
Lionel h Posted February 3, 2017 Share Posted February 3, 2017 Pretty, very nice, have fun doing the hot iron hammer dance. Quote Link to comment Share on other sites More sharing options...
Marc1 Posted February 4, 2017 Share Posted February 4, 2017 This picture landed in my Facebook page. Never seen anything like it. Quote Link to comment Share on other sites More sharing options...
D.C. Posted February 4, 2017 Share Posted February 4, 2017 THAT..IS..AWESOME. The detail on the feet of the anvil...let alone the vise! Does anyone have any info on this thing? Quote Link to comment Share on other sites More sharing options...
Marc1 Posted February 4, 2017 Share Posted February 4, 2017 It seems more like a show piece than a work tool to me, but yes I agree a lot of detail in it. There would be a bit of getting used to have the vice right there ... Here is another one. At first it seems the anvil is small but in this one you can see an A4 page on the pin board for size comparison Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 4, 2017 Share Posted February 4, 2017 I'm thinking it can come live next to my chair in our livingroom. Sure Deb might scream but her anvil is sitting by the back deck door and this one is legitimately a piece of art. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
