  • Replies 30.4k
  • Views 2.9m
Finished an ammonite paperweight, took a pic. of it in the fire just so I could make a joke about fossil fuels!
Also made some prototype components for curtain rail finials, the need more curves and some texture on the leaves.
DaMaakus.... they are for my Aunt-in law for her cottage. She has 3 grand kids that are not real good at respecting things. Great kids, just need some polishing.
58er... WOW !
Nice idea, rocketman!
58er, those look very good!
Desmato, well, crossing my fingers they don't hurt themselves.
I made something today, too. Tried my first flower, since I thought it might become a christmas gift.
It didn't work out like I wanted. The inner petals tore apart, so only two instead of three layers. Peening the stem didn't work, so I had to weld for the first time. Looks bad and the inner leaf still rotates a little, despite the giant blob in the middle. I also forgot to round the edges of the petals.
It's kind of a disaster. I'm still tempted to gift it, though. If I find a way to stop the rattle. :(
It is not a disaster, it is called R&D, a prototype, problem solving, etc. Use the prototype in order to fix any problems and make the next on better.
Try setting each part into place then use a center punch to put a dent between the part and the stem.
Thank you Glenn, I will try that.
I made this self standing split cross for my mother in law. It's my first one. I'm pretty pleased with the way it turned out.
20181223_150117.thumb.jpg.390101faa8dbb950423dea67efdf49c2.jpg20181223_150207.thumb.jpg.7ac6eb2b8a04fcdb0c40357b9d90ccab.jpg20181223_150219.thumb.jpg.b536ff15ffd30bd9a32104cb90ce9e71.jpg
I decided to try to texture the leaves from my previous post. I also made two more to keep practicing. I have several chisels and punches which could have been used. I gave it a shot with them but kept dropping the leaf after each strike. Since these previous leave were already bent into a shape that did not help me being able to hold them while striking. I then went to the straight peen hammer.
I am not a fan of the straight lines from chisels on some leaves that I seem to see from a lot of beginners, but I still suck at making them so that may be part of it.
As usual, comments or suggestions for improvement are encouraged.
In regards to these curtain rod holders.
 I have some pics of the process but am still not happy with how they turn out. I would like them to be attached to the wall, come out about one inch them dip down into a slight "U" for the rod to rest in. This will keep the rod off the wall/window/molding, etc. After that, they can turn up into the leaf. I have not been able to figure out how or when to make the "U" the rod rest upon. The last pic with the arrow is where I want the holder to dip down so the rod rests upon it. Suggestions on when/how to do that?
I bought a different piece of 1/4” square to make little split crosses. It cut way easier and I was able to split them fairly straight this time. Very small and easy to lose in the coal forge. I made one more today by forging it with a plumbers love torch instead of my coal forge. It worked well. I also made a wood grain hammer. I practiced with it some and starting to get the knack of it.
Had a busy day in the shop today. Had some good helpers too. Since Christmas hasn't come yet, they weren't wearing their aprons yet. My son made a toasting fork from 1/4"(6mm) mild round stock. He's 10, but did the bending and twisting of the handle. He ran the blower while I hot cut the fork tines and dressed them. We had fun working together to make it, but I believe he liked the testing process more! My daughter made her first split cross from 1/2"(12mm) mild square stock. I helped hold it while she did the hammering. The texture was hammered in with a fencing pliers. Finished the day with my first leaf on a wall hook made from 1/2"(12mm) mild square stock.
Great job getting them started and making things Glenn.
Got a little time to try a new leaf style today. It's cool how a simple fold completely changes the look.
23 hours ago, jlpservicesinc said:
58er, Wow, that is great..  how much time do you figure you have into it?
Thanks again.
I would say about 4 hours......
i started to make a heat treat oven yesterday with left over fire brick from my gas forge :)  i got the rough part done now it need the heater element and i can finish it and start using it to make stuff
When I make leaves, I bevel both edges of the top surface to create the center ridge and the thin edges, and then I texture the surface with a cross- or straight-peen hammer as the mood strikes me. Then I flip it over and hammer out the “belly” with a ball-peen hammer over a divot in a wooden stump. A little tweaking, and we’re done.
2 hours ago, jlpservicesinc said:
Wow,  Made good time as well.. things seem to take forever to make now...
Thanks, its not as hard as it looks......
Thanks for the tip JHCC. I will give that a shot.
I have plenty of wood to make a dishing bowl. Another project added to the list to make.
Just hammer in the beginning of a divot with a ball-peen hammer; working hot leaves in that spot will burn it in the rest of the way.
It remains to paint and make an oak rail. One of the most difficult jobs.
A mountain of work Alexandr. Very nice. I wouldn't know where to start. Good luck with your next steps.
Thank you !
Sometimes small projects come across.
I'd love to get on that level some day.
