b4utoo
Large Steel Balls, Uses?
I guess I wear blinders. There's a thrift store less than 2 miles from me. Never knew it. Until over a year later lol
Found these there with a set of tongs...
Any idea of what they were...roughly 2" and 3.5" size solid
Share this post
Link to post
They could be bearings. Test them by doing a reverse rebound test. (No, not dropping an anvil on the ball!) ...you know what I mean.
Can we see a pic of the tongs???
Share this post
Link to post
An armourer who taught me, used to use those and larger ones for dishing.
His method was to weld them to posts, sometimes offset for plenishing in odd locations.
2 of them welded near each other allowed a valley for dishing into for heavy fluting, for things like the later period knee fans that protect the sides and tendon of the joint.
He would also weld them to hammers for added momentum. That also helped with inside odd spot where a heavy short arc of swing was the only way to dish.
I still use a large partial 8" ball welded to a post for plenishing and heavy dishing over wooden stump.
So ya....I would use them for forms for doing customized sheet metal work.
Share this post
Link to post
Are they cast?  It looks like a casting seem on the medium sized one at 17 inches and the small one at 12 inches.  The big one at 14 looks like it has a hole right at the tape measure, like it's hollow.
Regardless, that's a cool find.  I'm thinking eyeballs for critter sculptures, fruit or seed pods (grapes, berries), dishing tools.  Could you cut one in half, weld it to either end of a chunk of steel, harden it and make a rounding hammer head?
Share this post
Link to post
Weld a handle on one of the smaller ones to make a large-radius ball peen hammer.  Getting fancier, drill a large diameter hole in it and make a wooden handle to fit.
Share this post
Link to post
Ball topped stake is what I JUST put together with this steel ball.
The ball sits at 34" high on the stand for planishing and forming, and when used as hammer leaves lots of pipe as a handle when used on low dishing stump.
This one is a 5" diameter ball. It acts like a mild steel in welding, not like a cast ball at all. Seller claimed it was a very old cannon ball.
Total weight was 24lbs which is excellent, as I have a lighter 9" diameter factory knuckle (17lbs) for larger dished pieces like helmet tops.
I find the heavier the weight the less work I have to do. Heavy dishing ball does all the work.
Share this post
Link to post
Well 5.17 would fit an 18 pounder; unfortunately you generally want the cannon ball to shatter and do more damage and so cast iron works better than steel (and was MUCH MUCH MUCH cheaper back when they were using round shot in cannon)
Sellers seem to always claim that they are cannon balls even when their size wouldn't fit any cannon used in the last 200 years...)
Share this post
Link to post
These are best used to practice your packaging skills. Put a couple in a flat rate box. I will let you know how you did the moment I receive them.
Robert Taylor
Share this post
Link to post
Set into plates beneath the legs of whatever you wish to move; they would make the best sets of roller castors you will ever see.
Share this post
Link to post
They are mill balls, I have some to and am pleased to have looked at this thread.  I will mount at least one of mine on a stake so it will fit my anvil hardy hole/
Share this post
Link to post
well I am on the wrong continent for you, shipping would cost a lot unless you knew someone in the US military here
Share this post
Link to post
Well I currently have 2 100# dock weights.  They have a steel hook coming out of them and made from cast iron.  US$30 each Only problem is that they are pickup only...
Share this post
Link to post
That's what the hook is for.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
