April 24, 201511 yr What is aluminum oxide? It seems to me that an oxidized form of aluminum wouldn't be hard enough to use as an abrasive for sanding steel--that it would be weaker than aluminum, like oxidized steel is weaker than steel, so I suspect then that what is used as the abrasive on emery cloth is different from how it sounds. Also, sand, when melted, forms glass--an electrical insulator. This could cause a problem if sandpaper were used to polish metal, and sand fragments imbedded in the metal, then it was heated, and the resulting glass insulated the metal electrically---as in an HVAC guy cleaning a flame rod in a residential furnace, with sandpaper, to get a better electrical connection to the flame. He could inadvertently shorten the effective life of the flame rod. Aluminum is not an insulator, so my assumption is that given the same scenario except aluminum oxide abrasive cloth is used, that would not end up also insulating the flame rod. I was told once that it could, but I don't believe that for the above reasons, but I thought I should ask the question to see what you all think. Edited April 24, 201511 yr by TimB
April 24, 201511 yr Lets see Aluminum metal is hardness 2-2.9 on the Mohs scale and Aluminum Oxide is hardness 9 (diamond is 10)Iron oxide as scale has done a dandy job of polishing and smoothing the faces of my hammers and anvilsSeems like you have things mixed up somewhereNote that if you have ever seen someone take an Al can to scrape ice off their windshield and see them scratch it you might not sal Aluminum Oxide is too soft.
April 24, 201511 yr charcoal is soft, it is nearly pure carbondiamonds are hard, guess what they are made of?dont know the hardness of Buckminster fullerine, a newer stable form of carbon. a jet of water can cut thick steel and just about anything else and ice in the form of glaciers can wear down mountains.it is all relative
April 25, 201511 yr Anodized aluminum won't conduct electricity, so I am thinking that aluminum oxide grains wouldn't be either.
April 25, 201511 yr Aluminum oxide is the reason you can't cut aluminum with a torch. The torched area creates aluminum oxide which in turn has a higher melting point than the flame on a cutting torch can achieve.
April 25, 201511 yr Rubys and saphires are aluminum oxide with some trace elements added. It is harder than quartz.
April 29, 201511 yr Author Forgive me if I'm being slow, but what I'm gathering here is that oxidized metals, (at least Al, and Fe) are harder than the metal is originally---then rusty steel must get weaker due to brittleness of the harder oxidized form? If Al oxide melts at a higher temp than a cutting torch can achieve, and an Al can will scratch a windshield because of its harder Al oxide form, then why will it melt in a campfire that won't melt steel? If a cutting torch can't melt Al oxide, then the blue flame of a furnace burner surely won't either. And no one knows how hard woodpecker lips are
April 29, 201511 yr An aluminum drink camp will melt in a campfire because of how thin it is. I think if you had some steel that thin it would more easily melt too. I have melted/burned nails in fires while cleaning up construction debris so I don't thinks it's that hard to achieve.
April 29, 201511 yr So... anyhow, BOTH iron oxide and aluminum oxide are more abrasive... harder... than the parent metals. Significantly so! I have seen sand melted into ingots of glass by downed power lines! I used to keep some around for show and tell... from my days as a firefighter! Sorry guys! I just gotta stir the pot a little!
April 29, 201511 yr That one oxide of a metal (There are three different Iron oxides with various amounts of oxygen in them) is harder than the metal does not mean that another oxide is harder than the corrsponding metal. All elements do not behave in the same way. Aluminium has a lower melting point than Iron Thus the can melts but Iron turns into oxide. A cutting torch does not cut by meltiing but by burning the steel with the pure oxygen stream (the initial melt is to heat the steel enough to start the burning). The Iron oxides have lower melting point than Iron (thus it is possible to forge weld without flux) and will be blown away. The Aluminium oxide has higher melting point than the aluminium. Aluminium is highly reactive and there is always a very thin layer of oxide. This layer is so thin that it is invisible but so tight that it stops further reaction. This is what happens to stainless steel as well. Aluminium is used as a replacement to copper in electric wires so the thin layer obviously does not prevent electricity from flowing. As someone pointed out, the crystal form (if any) influences the properties so there can be different properties even if the chemical composition is the same.CheersGöte
April 29, 201511 yr To be fair, without extreme temps, the oxides in the can don't typically melt, so much as the can loses mechanical cohesion as the underlayer melts. You get something similar when you melt zinc pennies with a copper coating.The oxides, if you're lucky float. They often don't...and then have to be scraped off the bottom of the crucible when melting. One of about ten thousand reasons that soda cans make a lousy melt.Doubts aside, aluminum oxide is frequently used in sand blasting and on sandpaper. I couldn't say about flame rods, but I've used sandpaper on plenty of occasions to clean corroded electrical connections. Works a treat.Theory isn't always what it's cracked up to be. Ever hear the one about the scientist that put an engineer and a mathematician in a room with a pretty girl? Told them they could cross half the distance every thirty seconds. The mathematician starts to storm out, furious. "It can't be done!" The engineer stays put, and the mathematician looks at him and says, "You fool, don't you see you can never reach her?" Engineer - "Yes, but I'll be close enough for practical purposes..."Oh yeah, and an article on woodpecker beaks. Mohs hardness shouldn't be too hard to calculate from keratin and hard bone.http://www.asknature.org/strategy/438bfe12686a92af28a607ac3dc002b7#.VUDfSLtFDIU Edited April 29, 201511 yr by Nobody Special
April 29, 201511 yr *No* rusty iron is not weaker due to the brittleness of iron oxide. The iron oxide is present in a aggregation of small particles think of the difference between sand and quartz crystals, same material but one can be easily "cut". The weakness of rusty iron is due to loss of cross sectional area due to the rusting and the production of stress concentrators due to pitting due to rusting.As mentioned the aluminium oxide layer does not melt when you melt Aluminium it forms a part of the dross. Similarly when you forge rusty steel you don't forge the rust, it comes off in the fire and on the anvil and you forge the steel.
May 22, 20197 yr Tim, there's a couple Youtubers Pete&Peter who have concluded that oxides are formed in high heat environments. Rust is not oxidation, but the decomposition of iron in the presence of moisture (either humidity or water) and air. Neither of those two substances (water or air) seem to contain oxygen. Oxygen is formed by air put through a heat process. Everything we've known as "oxidation" or corrosion or rust is in fact decomposition and hence why you've found rusted metal to be weakened. Metal oxides or heat-treated metals are hardened. I suggest you check out Peter&Pete on YouTube.
May 22, 20197 yr Fredepepsi; Tim last visited in 2015; so I don't think he will get your update. Also rust *is* oxidation: iron becomes iron oxide---pretty much the definition of oxidation! So H2O, the chemical formula for water, doesn't contain O---oxygen? Air doesn't contain Oxygen? ("By volume, dry air contains 78.09% nitrogen, 20.95% oxygen, 0.93% argon, 0.04% carbon dioxide, and small amounts of other gasses") BTW Annealing is a method of heat treating metal to make it soft. I strongly suggest you don't accept ANYTHING on youtube as proof unless you know enough to vet it! April 28, 2015
May 22, 20197 yr Think there is no Oxygen in air or in rust? Rust is either Fe2O3 or Fe3O4 and Thomas already covered water and air. LOL I just love how some people join just to spout off nonsense I suggest you stop listening to Peter&Pete as well, unless you need a good laugh
May 22, 20197 yr I hope they were just trying to provide information on a discussion and were not trolling. Unfortunately they were basing that information on a bad source. People sharing incorrect information is a fairly constant issue on the internet. We have previously discussed how to evaluate information from sources you don't know; about subjects you are not familiar with. (experience, credentials, dogpiling, etc).
May 22, 20197 yr Just to be fair, I endured eight minutes of the 48 + minute video. Excruciating. I doubt that these gentlemen are doing anything more than trolling the gullible. Robert Taylor
May 22, 20197 yr 2 hours ago, Fredepepsi said: the decomposition of iron Into protons, electrons, and neutrons?
May 22, 20197 yr Mr. F.-Pepsi, Where did you study chemistry? By the way, Mr. Powers is absolutely correct. And Messrs. P. & P. are completely uninformed. SLAG.
May 23, 20197 yr Anybody here really think Fred PEPSI(?) is doing anything but messing with us or maybe is a youngster? Frosty The Lucky.
May 23, 20197 yr Or too embarrassed when they found out how bad the information they were promagulating was to show up again under that name.
June 2, 20197 yr Way too scientific for my feeble old brain. Let me just just sneak in here and say this..............as a wood carving instructor, the very last grit after sharpening is 3 levels of leather strop abrasives, last of which is aluminum oxide............. .5 micron.
June 22, 20196 yr I just went on a trip through their titles and clicked on a video here and there. That hurt my brain. They apparantly claim that Iron and Aluminum aren't elements, but that water is, that salt, NaCl contains water, and that the Philospher's Stone is real. This isn't even good alchemy.
