Show me your anvil
I imagine you could recess it in your table and use it to help when you punch holes in things.  Just as you would a Hardie  or Pritchard hole.  The end would have to be ground smooth, though.  You might get some good ideas from this thread that Charles started.
Chris
  • Replies 3.8k
  • Views 852.9k
Most Popular Posts
  • Not done yet but this was cut from 4" plate. Horn was roughed with a O/A torch the finished with a 7" zircon flap disc. Feet cut separate and will be severely welded ;)
  • This is a 80# piece of drop from cutting a hole in a steel plate. No one said an anvil has to have the standard anvil shape.
  • DocsMachine
    DocsMachine
    140-lb pre-1910 Peter Wright. Aged, badly abused, and severely chipped, but no cracks or large chunks broken off. Stand fabbed from scrap angle, strap iron and some fresh 1" square tubing. Two "cutout
Just read it and some of those are really neat. I have access to railroad scraps, and loads of them, so I will try and make more anvils for different purposes. I guess I’ll need to go and buy some disks for my angle grinder...
 Most likely.  :D
Chris
Keep in mind that removing anything from the RR tracks or RR property is a federal offense and on privately owned lines that stuff belongs to somebody.
Pnut
Hello all,
Well I have been thinking about it for awhile now, and I am finally going to ask if anyone can give me any idea of the production year for me anvil. I bought is about 20 years ago while I was still in school, at the time it cost me all I had. It is one of the best investments I ever made. It came out of a local factory that made shoe. My father worked there and let me know they where sell off equipment. I got lucky and brought this anvil home. It has been stored in several different locations throughout the years that I owned it. About 12 years ago I finally had my life setup and built my forge it has been in my shop ever since. The serial number is obliterated for whatever reason, I believe there is an 8 1 in it. It is a Trenton with Solid Wrought stamped under the logo the 392 is further down on the same side. It has an 1 1/4" hardy.
Have a great night,
W
Here's mine, brand new to smithing, found this up in Southern Indiana. Columbian about 100 lbs. Sweet ring and great rebound. Stump off a blow down from last winter. Paid $2.00/ lb. The face was in terrible shape, weld splatter all over it, very careful scraping,mild sanding brought it back.
I'm trying to find a larger anvil :). Maybe just go with a new small/mid size Ridgid Peddinghaus - tired of looking.
:lol: Yup, Gus Bird, I agree a larger anvil should be on your wish list. :D
Whew, I'll wrestle you for that Trenton, Steven. ;)  That's a nice lookin' one.
And you're gonna love that Columbian, Whiskeysup.  I've heard great things about them.
Or a much smaller hammer.
Or just specialize in using horseshoe nails as stock.
Pnut
Might not be hard enough for horseshoe nails - it's not great in the rebound department :).
And then with a smaller hammer - I could use the straight pein for the anvil? :)
Well, that would be one smurfy smithy
Pnut
What do you guys think of my little hoard?
That if you use them in that setup, you must be quite tall.
I'd recommend steel tipped boots + shin armour if you use them like that :D
Haha well, using may be a bit interesting but it is great exercise moving them around.....
Thank you gents. I picked up the big one on Sunday, haven't had the chance of using her yet.
If I may ask for some advice... A question of the Brooks, the 2nd image, I see that it is missing an o. Is that very out if the ordinary?
Thanks Chris,
Not sure I would take you up on that any more, back when I weighed 375 pounds and could bench press over 500, dead lift in the 800 for sets maybe. But not any more lol. I am a third the man I once was.
Have a good one,
W
Then again I would have to see what you where putting up on your side of the bargain :P.
Well, lets see..............if you could bench over 500 and are only a "third the man" you once were, that means you could probably press 166 pounds now.  I can't press that, so I'll let you keep your anvil.  But it sure is a nice looking Trenton.  (droo-o-o-o-o-l!)
I do love my anvil!!!
Also I must say I am very glad I found this site as I was getting ready to setup my smithy. I had originally thought to repair the "Damage" to my anvil. God knows what would of come from the ideas banging around in my head at that time. After reading many posts on this site one really stuck with me, "forge on it for a year then make decisions about repairing it" I am very glad I waited to repair my anvil. I have done nothing to it but clean it up and use it for the past many years, and as it turns out that is all it needed.
Have a great day,
W
I don't keep this at work as in this picture, it would not be wise. I had a small straightening job and it came right back home afterward.
Got me a new to me anvil. Fisher 200lbs.. Check out the base.  Look like old railroad ties and threw bolted with tounge and groove. Can't remember right now what its called when a groove is put in both sides and a separate piece the correct size is put in.
Very lively face.  Doesn't look like the hardie hole has ever been used.
That’s a spline joint.
Sweet anvil!
