August 23, 20205 yr On 8/18/2020 at 5:29 PM, Arthur210 said: Simple ones made from 3/8" square. I dig simple, man. T
September 4, 20205 yr Made a few more rr spike openers in the shop the other day. The third one from the left I believe is wrought, never forged that material before, gonna try a different approach, maybe punching and drifting a hole is asking a bit too much of not only the material but my skill level.
September 4, 20205 yr That one is still salvageable! Cut off the nasty end and then draw out a long skinny piece and loop it around and forge weld it to the main mass to make the loop. Work it at welding temps and you can leave the weld visible as an "artistic statement". A light etc and a good coating of wax or BLO afterwards and you'll have one you can charge extra for! Drawing out, looping around and forge welding was often used with real WI to avoid drifting issues as WI is very sensitive to the difference of working with the grain and across the grain. So much so they even came up with rolling WI in two different directions 90 deg to each other to try to make it a bit more uniform in properties. I have some Byers bidirectional rolled plate---instead of stringy breaks it has platey breaks! (Actually if you are comfortable forge welding you could probably forge weld the end into rectangular stock as it stands and draw it out as needed.)
September 5, 20205 yr That is what I would do, fold the bad end and weld it back together, then draw it out and loop it. I learned to weld W/I when drawing out reigns of a tong that feathered on me at too low of a heat. To me it welds easier than mild steel.
September 28, 20205 yr Nice twist, Firemedic. You like the s-hook opener style better than the ring opener style? Just curious. Still need some tooling before I attempt an opener. Taylor
September 29, 20205 yr I do like that style. I like the aesthetics of it better. It seems to be less common. I have never made the ring style opener though. So I can’t speak for which process that I like best.
September 29, 20205 yr Nice opener, especially for a first, Firemedic, I'd be pleased too. Very pleased. I've found doing the twist before forging the rest of the product makes for nicer transitions between twist and smooth sections. Not always but it generally works well for me. That's just a twist tip, not a criticism. Frosty The Lucky.
January 9, 20215 yr This is the most recent bottle opener I've made, for the fifth National Bottle Opener Swap. Here's another one. It's called Oldman
January 9, 20215 yr Nice openers Morcy, you even got the dolphin's nostril pinched closed! Excellent bit of detail. The old man looks like he sat on something pointy. It's a great expression for an opener, a real attention getter. Well done, I like. Frosty The Lucky.
February 4, 20215 yr That is really cool. I love the details! I get the fingers, but how did you do that thumb???
February 4, 20215 yr Ah ok, I zoomed in a bit and I see now. I thought that bend fell further toward the palm than it does.
February 8, 20215 yr Typical wizard. I keep trying to make them and my dragons look fierce but apparently I have the curse of the happy/goofy wizard and dragon face.
