May 31, 20188 yr On 5/28/2018 at 9:18 PM, BryanL said: Went for a double hook this time. Made a set of 5 to trade to a buddy for some engine work. Bryan, you will want to be careful about having such a drastic transition in cross section like you have on those hooks. The flat also has sharp edges, and the strength in that area is greatly reduced. Punching a hole in the round would spread the sides out and help maintain mass. With hooks the application also needs to be looked at in that with a hook that is not used much may be able to be somewhat narrow. A hook like a coat hook that gets used much more often may need some stabilizing in order to keep the screws from working loose. Lookin' good, keep at it.
May 31, 20188 yr On 3/25/2018 at 8:49 PM, Dylan Sawicki said: Some stuff from the past couple days: quote edited Nice job Dylan!
May 31, 20188 yr Biggundoctor, thanks for the feedback. I will try to punch the next set and report back how that goes. I need to practice reaching for the punch instead of just drilling. I tend to always rush to the next job but really, I should take the time to practice the basics. Bryan
June 1, 20188 yr Bryan, I've found it helpful to take a piece of round bar on round stock and make a divot in the hole spots. Then punch and use a larger diameter punch to counter sunk the hole so a screw fits flush if you use that type of screw. For flat stock no need for the round bar divot. Not my better work but an example.
June 1, 20188 yr Good tip, Das. Didn’t have much shop time today, but I did get in some filing on the blank for the small Bowie knife: Also added some leather uppers to the pair of steel toes I picked up at the industrial surplus place. Classy, right?
June 1, 20188 yr Almost finished the roses for the fair I'm selling at Saturday. Man could I use another couple days to make more small stuff. Hmm.. might have to call in sick tomorrow lol.
June 1, 20188 yr 12 hours ago, JHCC said: Classy, right? I think you've found the next big trend Haha.
June 1, 20188 yr 14 hours ago, Daswulf said: take a piece of round bar on round stock and make a divot in the hole spots If you use square bar to make the divot, you get a soft radius on a rectangular divot. It is a different look.
June 1, 20188 yr You know if you could source a set of used "flame design" cowboy boots to get the leather for the "uppers" you would have some *spiff* steel toed spats!
June 2, 20188 yr Again, very little shop time, but I did get the blade on the Bowie cleaned up, the rivet holes drilled, and the false edge ground. The O is looking more KS every day. I think we’re ready for heat treat.
June 2, 20188 yr Looking good John. Got my 6 roses done. Practically all packed up for the fair tomorrow. I'll get pictures of my tables once I'm setup. Larger sculptures are going to be a pain to load in and I'm really thinking I could use a truck cart next time. Most of this stuff just doesn't fit nicely in totes lol.
June 2, 20188 yr I predict none of those roses return home with you, Das. Saturday is over here, but just starting for you. Have a great day and report back.
June 2, 20188 yr I'm really liking that bowie JHCC! Nice sleek shape to it. Das those roses are great! Very nice Job.
June 2, 20188 yr 3 hours ago, Owen Hinsman said: , what fair are you going to? Pittsburgh Freaky Fair. The greater pittsburgh art festival is also going on.
June 3, 20188 yr I would have left a bit more meat on the bowie tip for heat treat. More grinding afterwards but less chance of failure! Das are you going to be dancing to the Masochism Tango with one of those roses? (another Tom Lehrer song...a bit rough for some modern sensibilities)
June 3, 20188 yr JHCC right on.. i can never hear this enough from younger Smith's. Practice makes perfect.... Back in the day i would torture test every blade i made.. simetimes i would use a blade for a week or 2 then throw it in the vise and see if i could snap the blade off.. Between friday and saturday at the NEB meet i must have done 100 forge welds.. while it was all well and good. The fun part for me was trouble shooting/fixing the bad welds others were having from a lack of experience. Stuff most would say is impossible to weld without grinding out yhe weld or cutting and rescarfing.. Everyone of the welds fixed got handed back to the student to finish up or brought to the next stage.. Lots of them were discouraged, but with a quick heat and a little more instruction as to what i was doing and why, had them finishing up the piece with more confidence.. This experince comes from having just a little bit more understanding of what is going on and this only happens with the freedom to know if it doent work, big deal . Ill just make another. Well said and kudos..
June 3, 20188 yr 14 hours ago, ThomasPowers said: Das are you going to be dancing to the Masochism Tango with one of those roses? (another Tom Lehrer song...a bit rough for some modern sensibilities) SLAG suggests that Herr Das use cast iron dentures for said tango performance. SLAG.
June 3, 20188 yr Both. There are some WIP photos up-thread. 1 hour ago, jlpservicesinc said: JHCC right on.. i can never hear this enough from younger Smith's. Thank you, Jennifer. Having just passed my 50th birthday, it’s kind of funny to be referred to as a younger smith! 1 hour ago, SLAG said: SLAG suggests that Herr Das use cast iron dentures for said tango performance.
