ironwolfforgeca
6 -
Everything posted by ironwolfforgeca
Rotating Kiss and Die
ironwolfforgeca replied to Sanderson Iron's topic in Power Hammers, Treadle Hammers, Olivers
nice Idea -
Black steel does not mean cold steel
ironwolfforgeca replied to natenaaron's topic in Everything Else
I have a lg slack tube right next to the propane forge I Always !! cool down tongs after Each use ! & on long bars that dragon breath like to heat the hand ends up - after working bar the hand end 'go's in the tube for a cool down then back to the forge for next heat this take No time at all to do ! another trick I do once in awhile is put a very wet rag on the end of the bar to help keep it cool BUT like I always say All steel is hot until you Know it isn't ! I don't wear glove's much if you see me wear a glove there's a good reason ! also have a slack tub @ the anvil & change water often Just in case someone needs to dip there hand in clean water Steve's Welding & Fab -
the Simple Rule I Consider ALL!!! Metal Hot in shop until ck by the back of my hand & have never so far got burnt yet & have been welding since 1976 & smithing for 20 + years LOL now watch me Goof up also I have 3 lg slack tubs in shop & use often to keep tools cold & Hot work is under the forge or in it -
forge a new one out of SS steel Gee or TIG it !
Nice sander with 2 belts THAT'S Cool !!
for my two cent's worth 2x3 is not enough I would do 4" sq tube - 3" min & maybe rebar in tubing & cement if posts can't handle wt well you'er Done ! I have a friend that does BIG gates often he will weld legs to posts run I beam across and bury & cement the hold support frame across to the other post - also rec tube will bend more than Sq tube Steve's Welding & Fab
- 13 replies
Portable Blacksmith shop
ironwolfforgeca replied to jlpservicesinc's topic in Building, Designing a Shop
nice set up !! how about a pic of the inside ? to -
there Ti framing hammer work as Good as my steel framing hammer the same size @ a tenth the wt So makes me wonder ???
I ask this ? a few years back & the subject came back up LOL some carpenters I work for have Lg titanium framing hammers they use all day long there not cheap $$ but they are sweet !! they don't work you like my Lg steel framing hammer does ! So anyone ever seen a smithing hammer made from Ti ?? or use one ?? Tomas if I remember right you had a piece of ti & was going to try & forge a hammer ?? did you ever do that ? ALSO anyone know what kind of Ti would forge well & work for this Idea I have helped make 1 set of Ti tongs @ a meet along time ago the metal forge well @ yellow heat & has a small working window I have No Ti right now I will have to start looking of a chunk from the Big city somewhere I would like to try one a see who it hammers
What electrode to use on wrought iron?
ironwolfforgeca replied to DannyD's topic in Welding/Fab General Discussion
here's my 2 cent's worth If welding o/a do you have or can find a Hemrod torch ??? they are a small hand torch that welds like a Tig torch just on o/a 4 psi I use mine for brazing all the time does much Better work than a victor torch hands down !! Very precise flame And there also a cast iron rod 1/4 x 1/4 available not sure you would want that rod but its out there / if brazing I would get a high tensile rod I can't remember the #No though I have used it often -- SO run a welding rod test !!! GOOD Luck ! & tell us what worked when done Steve's Welding & Fab -
Hay frosty & All have fun !!! Marks Demos are always fun & busy been there
witch hammer depends on what you're forging ? a new 88 gota to be around 10 G ?? a used 165 ? $$ - is it a one piece or 2 piece ? A two piece is a bit more work to install myself I am a more power guy can you test run the 165 ?? or get near a 88 ? I have never heard of the heat problem you talk of unless its run Hard all day & then some all hammers get warm / hot depending on use a hard day on my 33 & you can't hold you're hand on it and yes I push the 33 when needed ! I need the 65# up & running
I think I am done adding stuff to it -- That's a Joke right LOL
Long heat, big material.
ironwolfforgeca replied to Starlight's topic in Blacksmithing, General Discussion
you mite set up a hand air hammer to use to texture plate work to -
Alan i weld a ss bolt to the top of the v-grip bolt on my welding table ground lead works good only problem is when you Forget to take it off the trailer you.re moving out of the shop LOL !! I have seen welding eqt follow the trailer out & welding tables last time I did it I tore off a nice alum rope tie down on the boat I Just fixed with customer moving trailer out - well short story put trailer back in & come back in an hour or so lol fixed it on my dime yea my stuff is bolted to the floor a friend of mine dump his Lincoln 6' H onto the floor twice just scratch the paint tough machine red box ac/dc
Fuel Cost
ironwolfforgeca replied to Forging Fever's topic in Solid Fuels: Coal, Coke, Charcoal, Wood, etc
crescent city ca reg gas $2.89 propane $199 coke or coal about $18.00 per 50 wt & are gas was $5.00 when things were high Texas $5.00 ???????????? you guys make it ! then ship it -
take it to a welding shop that has a LG cut off saw 16" or 2' wheel or bigger & be done - worth the cutting fee thats what I have here & how I do that PS don't think band saw will cut it ?? to hard or you are going to need a VERY $$$ !! good blade
Modular Forge And Metal Work Components
ironwolfforgeca replied to 7A749's topic in Tools, general discussion
Nice set up & well thought out ! I am steeling some of you're fixture Ideas = the hammer & tool rack & vice on the side of the table years ago I installed hitch tube brackets under my 8'x8' welding table I can plug in a 12' - sq-t 2x2 & able to adjust as needed I use them as saw horse I have plug in legs for the ends It triples my work area when needed I mite think about cutting a sq hoke in the top of the table Now LOL also on my brackets I drilled hole & welded 5/8 #8 nuts theres 2 each on the side & on the bottom tighten with a T wench and & whatever is there will not move -
I was born with a 9" grinder in my hand !! Ok started welding with one LOL for the price & long lasting G wheels I use flex-o-vit sp-? stainless fast cut they Chew stainless up !! steel done gone now ! I have done a lot of grinding in 35 years Ouch still doing it Ouch Steve's Welding & Fab
Are horses left or right footed?
ironwolfforgeca replied to Glenn's topic in Farriers and Horse stuff
I can see theirs going to be a lot of Horsing around in here -
Very Nice David trying to get less than 4" gaps on that takes time lol & a few beers !
was the Bot named Thor's Hammer
My uncommon forge, and how I built it (Video)
ironwolfforgeca replied to ecforge's topic in Gas Forges
Nice Forge !!! I have been considering building a brick forge for the last few years with a ribbon burner set up I like you,re design better !! You got me thinking about it again LOL -- Oops just move in the champion #65 power hammer last night to rebuild it LOL or I would be building brick forge I already have built the bass piece last year I am time POOR & Project Happy- 13 replies
- xl forge
- large gas forge
- (and 3 more)
VERY Nice piece !! Matto you need to take pics of process & tooling So we have Drool time LOL makes me want to see if I can do something like that in my 65 ton press
To "repair" an anvil?
ironwolfforgeca replied to Slyfox's topic in Anvils, Swage Blocks, and Mandrels
Slyfox ck your message box if anvil was down here I could fix it to new condition but you are a good 8 Hrs up Hwy 101 from me if you can weld there is ways to repair anvils Right !! Steve,s Welding & Fab- 13 replies
