11,858 -
My comment would be, move that propane bottle and maybe cut a larger opening for your stock. Can't tell if there is an exhaust opening in the other end but it needs one.
Flintlock project
Irondragon Forge ClayWorks replied to Dabbsterinn's topic in Gunsmithing, Muskets, Flintlocks etc
You might benefit from this forum about traditional muzzleloading, Especially the gun builders sub-forum a lot of knowable folks there who are willing to share their knowledge. If the link doesn't work it's www dot muzzleloadingforum dot com http://www.muzzleloadingforum.com/fusionbb/fusionbb.php -
Not all knowledge comes from college. Something my grandfather told me in the early '60s which still applies today.
- 50 replies
- knowledge
- experience
(and 2 more)
Source for quality flap disks
Irondragon Forge ClayWorks replied to Farmall's topic in Blacksmithing, General Discussion
I once bought some expensive flap disk's and found in the fine print "made in China" so now I just get mine from HF and get just as much mileage from them. -
I always listen to "experts" and learn from other's mistakes because I will never live long enough to make all of the mistakes on my own.
- 50 replies
- knowledge
- experience
(and 2 more)
As I've said before. "An expert is someone who studies more and more about less and less, until they know everything about nothing".
- 50 replies
- knowledge
- experience
(and 2 more)
A couple of pictures would help figuring out a fix.
Our shop started out life as a "bunny barn". At the time we were raising fancy show rabbits, but it became a chore so the bunnies had to go and the 10' X 30' was converted into the shop.
It followed me home
Irondragon Forge ClayWorks replied to Glenn's topic in Blacksmithing, General Discussion
See, I told everyone, we can learn something new here every day... -
Mute the ringing
Irondragon Forge ClayWorks replied to The Alchemist's topic in Anvils, Swage Blocks, and Mandrels
Don't know about that. Without the blacksmith, the stone cutters would not have the tools to cut the stones. -
Newbie with hopefully not an aso
Irondragon Forge ClayWorks replied to Belshe92's topic in Anvils, Swage Blocks, and Mandrels
Just thinking out loud here but wonder if for some reason the factory failed to weld the steel plate on it. Something like when most steel was going to the war time effort in WWII.- 46 replies
- rough casting
- unknown
It followed me home
I thought she was wearing the sweater so whoever was wearing those house slippers wouldn't feel bad. -
When my grandfather passed away, I wound up with all his tools and used them all the time even though they were "old". Then one day some miscreant broke into my van and stole all of them except for his 2lb cross peen hammer, which I still have and use. Another 60 years of use and the handle gave up last month. I re-handled it but it just doesn't feel the same. Every time I used that hammer, I felt connected to my grandfather and his wisdom and knowledge.
- 77 replies
- blacksmithing
- hammers
(and 2 more)
Trailer hitch ball's as domed anvil hardies.
Setup help & introduction
Irondragon Forge ClayWorks replied to JamesSr's topic in Tools, general discussion
Good score on your first anvil. Quite an ingenious anvil stand, I love it however you will find it gives some when forging steel. I would suggest making a stand that is more solid, a tree stump or 4x4's banded together. Another suggestion for searching the forum is use google with a search like this ("iforgeiron" anvil stands) without the brackets, the search function of the forum leaves a lot to be desired. -
Thought I was the only one to use them.
Einstein obviously forgot to calculate Mercury going into retrograde.
Yep, my poor choice of terms. Clean up the threads would be more appropriate.
I would carefully cut the weld and re-thread the stud.
What kind of steel is this?
Irondragon Forge ClayWorks replied to setlab's topic in Blacksmithing, General Discussion
Spark testing still will not tell you what type of steel beyond carbon content. Found that out the hard way. Scroll up one post... -
Pet Project Guidance
Irondragon Forge ClayWorks replied to Finite's topic in Blacksmithing, General Discussion
The search function on the forum lacks a lot. The best way to search is put iforgeiron in quotes like this "iforgeiron" then your search on Google. You will be surprised the number of threads that come up. Another thing that may surprise you is if you put your location in your profile, there may be quite a few Smiths that are within visiting distance to you. With Damascus the etching is usually done after shaping/machining. -
Doubt you will find dryer hose that small. Just cut up a coffee can, wrap it around overlapping it and secure with radiator hose clamps, call it good.
heated steel debate
Irondragon Forge ClayWorks replied to J's topic in Heat Treating, general discussion
Mystery steel… gotta love it. Today I decided to make a “hoop” to hang a very large caldron. I had a half circle ½ inch round bar that would fit the bill so I began drawing out the ends and putting hooks on them. I finished the first one and quenched it in water so I could work on the other. While drawing the second end a piece of the first snapped off. I thought ok high carbon spring steel that doesn’t like water quench. I reformed the end and let both cool in air. I then began to heat the center with both ends up, planing to swage a hump for the chain and when the metal got to orange heat it fell apart. A spark test showed it is high carbon steel and it has a very fine grain and rings like a bell. Any ideas? Never had metal just fall apart while heating it. Photos were lost in a forum up date.- 32 replies
- heat treating
- forging carbon steel
