Irondragon Forge ClayWorks Posted May 31, 2018 Share Posted May 31, 2018 At one time I drove an '86 Honda CRX and many an item(s) followed me home in that mini work horse. One time 400 pounds of sucker rod taxed it but it made it home. Sadly a girl failed to yield while making a turn in front of me and totaled it. luckily I wasn't hurt. Quote Link to comment Share on other sites More sharing options...
JHCC Posted May 31, 2018 Share Posted May 31, 2018 Automotive adventures aside, the grinding discs were the real prize: at five bucks for fifty-nine of them, that’s less than 10 cents each! Quote Link to comment Share on other sites More sharing options...
JHCC Posted June 1, 2018 Share Posted June 1, 2018 Just picked this hunk of bar up from the side of the road. About 1/2” x 2-1/2” x 28”. Despite the location, it doesn’t look like leaf spring, so I’ll try a spark test when I get it home. Quote Link to comment Share on other sites More sharing options...
Owen Hinsman Posted June 2, 2018 Share Posted June 2, 2018 A couple of weeks ago I picked up 70+ lbs of random hardware. I also went to the NEB Spring Meet today and picked up some other stuff. WARNING: PIC HEAVY Quote Link to comment Share on other sites More sharing options...
MK286 Posted June 3, 2018 Share Posted June 3, 2018 I found this in a tool box at that I bought at a garage sale today. Does anyone know what it is called or used for. Also got an air compressor as well as some casters, hacksaws, and some random steel. All for $30 btw. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted June 3, 2018 Share Posted June 3, 2018 I believe that's for adjusting the teeth on a saw blade. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 3, 2018 Share Posted June 3, 2018 "saw set" still sold new; just google it. Quote Link to comment Share on other sites More sharing options...
Marc1 Posted June 3, 2018 Share Posted June 3, 2018 You are all wrong ... it's a compressor Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 3, 2018 Share Posted June 3, 2018 That red thing's an operator---says so on the side! Quote Link to comment Share on other sites More sharing options...
MK286 Posted June 3, 2018 Share Posted June 3, 2018 Thanks a bunch. I will have to look for a victim... I mean patient to practice using the saw set pliers. TP- I agree with you. The red thing is an opperator of pneumatic devices. Quote Link to comment Share on other sites More sharing options...
Hans Richter Posted June 3, 2018 Share Posted June 3, 2018 Didn’t buy the earlier shown vice & stand from CL for the mobile forge equipment but found this beauty next door (village). It’s a full functional 4 ½ in jaw vice and fully forged if you look at the lock plates, chiselled eyes for the screw box and rivets. The vice is only wire brushed and passivated with linseed oil. Greased the screw, dressed the push spring and made a new wedge for the join pin. Was so glad to find this nice piece of equipment that I give the seller (20 dollares) one of my fire pokes to say thank you. Build another vice stand in advance which is movable. Will finish (weld & paint) him today. The big ‘b’ on the foot is a standard left over sample (2 ½ in plate) from edge hardness measuring to certify the gas-oxy cutting process from one of my clients. It’s add extra counter weight (55lbs) and balance to the stand. If the weight is not enough I will drive extra ground anchors though the holes in the ground or between the joints in the road stones. Hope this little old guy will do his work very well. Cheers, Hans Quote Link to comment Share on other sites More sharing options...
MC Hammer Posted June 3, 2018 Share Posted June 3, 2018 Went to my local scrap yard for a quick run yesterday. I was early enough to beat the truck that hauls it all away every day so I had nice piles to pick through. Found some nice coil springs, hay rake tines and something I've never seen before. The pointy pieces slowly get wider as you go from the point upward. I have no clue what they are so if anyone here knows, please let me know. I plan on using the pointy pieces to make hardy tools. What I do know about them is that they were long piece cut into several pieces and I think the very top piece was threaded and was quite large at something like 2 or 3 inches. I also had a 3/4 inch steel rod as well that is not pictured because it was so long. $5 for all of it. Quote Link to comment Share on other sites More sharing options...
SLAG Posted June 3, 2018 Share Posted June 3, 2018 For the next picture, I suggest that you put a known item beside the unknown one for comparison purposes. Like a quarter, dollar bill, hammer, et cetera. It then becomes much easier to visualize. Just sayyin', SLAG. Quote Link to comment Share on other sites More sharing options...
MC Hammer Posted June 3, 2018 Share Posted June 3, 2018 Ah, good point Slag. The pieces in question are roughly an inch by inch square near the point and increase to almost 1 1/2 inches toward the top cut-off part and the longest one is a little over 2 feet in length. I hope that helps. Yeah, how dumb of me they could be nails for all you guys know as the picture really gives no idea to size. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted June 4, 2018 Share Posted June 4, 2018 Hans, you should have flipped the "b" over so it would be a P because P is for post vise.... Quote Link to comment Share on other sites More sharing options...
ironartforge Posted June 4, 2018 Share Posted June 4, 2018 On my way home from church I noticed the local Fire Department loading a dumpster so stopped to inquire. They said it was all junk and to take whatever I wanted. I got the siren off the building roof, several old Scot air tanks, a lot of aluminum plate, about 50 pounds of brass fittings, and some turnout gear. Plugged the siren in and it works fine... It was a good day for dumpster diving. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted June 4, 2018 Share Posted June 4, 2018 Cool score ironart! Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted June 4, 2018 Share Posted June 4, 2018 Your taxes bought that stuff so it seems fitting you can get some when they no longer need it. Good score on the siren. Quote Link to comment Share on other sites More sharing options...
the iron dwarf Posted June 4, 2018 Share Posted June 4, 2018 this lump of WI came home with me yesterday, at a guess about 120 lb Quote Link to comment Share on other sites More sharing options...
blacksmith-450 Posted June 4, 2018 Share Posted June 4, 2018 Now i have to find a large grinding stone ! Quote Link to comment Share on other sites More sharing options...
BryanL Posted June 5, 2018 Share Posted June 5, 2018 Scored a plasma cutter at the NEB meet. Pumped to learn to use it. Quote Link to comment Share on other sites More sharing options...
Mellin Posted June 5, 2018 Share Posted June 5, 2018 Followed me home I feeeeeeeeel like it should be a foundry. Like it is asking me to fufill its destiny and upgrade it from a fryer broaster thing. Quote Link to comment Share on other sites More sharing options...
JHCC Posted June 5, 2018 Share Posted June 5, 2018 Hmm...commercial fryers rarely go much above 375°F/191°C, which might be a bit cool for foundry work. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted June 5, 2018 Share Posted June 5, 2018 Take a look at how much that cost new....they are not inexpensive. I would sell it off and get something more suitable. Well, I probably wouldn't as I am picking up used commercial kitchen equipment to use for their intended purposes. Quote Link to comment Share on other sites More sharing options...
sfeile Posted June 5, 2018 Share Posted June 5, 2018 Got some new belts, epoxy, and some axles from a silverado today. Thinking some hardy tools and punches out of the axles. Quote Link to comment Share on other sites More sharing options...
