ThomasPowers Posted August 20, 2021 Share Posted August 20, 2021 Might be worth calling around some equipment repair places---especially if you have paperwork on them! Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted August 20, 2021 Share Posted August 20, 2021 They are made by one of the big names in bucket teeth MTG out of Spain. Not sure if these model numbers are still made. I cannot find them anywhere other than Epay. I have dropped a couple of messages with nearby mines, and a supplier to see if they use this style / size, or if they are now obsolete. Also got some info on Utah coal from up north. Bituminous with 11,000+ BTU , 11% ash and low sulfur. The market price is $35 a ton, but not sure what retail would be, but I asked about it as well. Quote Link to comment Share on other sites More sharing options...
arkie Posted August 21, 2021 Share Posted August 21, 2021 That's a great price even with a somewhat low BTU and high ash content. According to sources here on IFI, the Phoenix Mine in Vinita, OK is "importing" Utah coal to OK (since they are not mining now) and selling it for $225/ton......the Phoenix Mine price pre-shutdown had been around $70-$75/ton Quote Link to comment Share on other sites More sharing options...
Glenn Posted August 21, 2021 Author Share Posted August 21, 2021 When you get into the 12,000 BTUs and below heat value, get a sample and test it in your forge. The higher the BTU, the more heat. You can tell the difference in 1,000 BTUs . Most of what I see is high 13s, 14s, and Sewel coal is 15,000s BTUs. Ash is rocks and things that do not burn. You are paying for heat. Quote Link to comment Share on other sites More sharing options...
Bantou Posted August 23, 2021 Share Posted August 23, 2021 Had a pretty good haul from a boat shop and the mechanic at work. I see lots of bottom tools, drifts, tongs, and punches in my future (as soon as this dang rib heals anyway). The auger teeth are going to be turned into plank mounted bottle openers. Ignore the galvanized bolts, they are for my anvil stand (if I ever get around to building it) Quote Link to comment Share on other sites More sharing options...
Frazer Posted August 24, 2021 Share Posted August 24, 2021 Bantou, nice score! I found a free "broken" table saw. I brought it home and there was no continuity which left two options. I checked the motor and, while filled with sawdust, it was fine. I took apart the switch and some burnt sawdust had fouled the contacts. After cleaning them up with some sandpaper it fired right up. I ordered a new switch just in case. $8 is not too bad for a table saw. Quote Link to comment Share on other sites More sharing options...
jrmysell Posted August 24, 2021 Share Posted August 24, 2021 Nice! I will also be getting a free non-running table saw. My uncle used to do contractor work and has retired and moved away. I recently asked him how much he wanted for the table saw (Delta contractor saw), a jointer (Craftsman floor model) and bandsaw (also a Craftsman I believe 12") and he said he wouldn't ever use them again so I could just have them. The jointer runs, the table saw does not and I can't get to the bandsaw until I move the table saw. I should be getting them tomorrow. Quote Link to comment Share on other sites More sharing options...
Frazer Posted August 24, 2021 Share Posted August 24, 2021 Can't argue with free! Hopefully the problem with a the table saw is something simple. Bring a multimeter. Quote Link to comment Share on other sites More sharing options...
Donal Harris Posted August 24, 2021 Share Posted August 24, 2021 Moving back to the primary thread topic, one of the several ways I’ve paid the bills over the years was as a meat cutter. Used to be a reasonably steady source of income no matter what town you might be moving through, till Walmart decided pre-packaged meat was a way to put more money in their pockets. Anyway, our assistant market manager at the Winn Dixie in Marianna, Florida had been careless when cutting frozen pig feet. Cut his right index finger off the second joint. They were able to reattach it, but it caused it to be permanently fixed in place. It just kind of stuck out. He really had to pay attention anytime he used the bandsaw after that, especially since he no longer had any feeling in it at all. Although I suppose that would have been sort of a blessing had he cut it off again. His fault was the same as mine had been each and every time I’ve been stupid and hurt myself. You do something so many times you get to thinking about other things while working. That or trying to use a piece of equipment while someone has come over and I am too busy talking to pay attention to what I am doing. I suspect the same is true for just about every injury anyone here has had in their shop. I am just more easily distracted than most. On 8/19/2021 at 3:58 PM, ThomasPowers said: Another accident and he can become a Computer Scientist! Naw, he would need to lose three more if my math is right. He would still have his ten toes. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 24, 2021 Share Posted August 24, 2021 I was thinking octal; but hexadecimal works too! Quote Link to comment Share on other sites More sharing options...
Jobtiel1 Posted August 24, 2021 Share Posted August 24, 2021 Made a run to the coal dealer today, luckily I had just enough coal left to finish forging what I wanted to forge today. The last 75 kg lasted me more than half a year, let's see how long this one lasts with the upgraded forge. ~Jobtiel Quote Link to comment Share on other sites More sharing options...
jrmysell Posted August 25, 2021 Share Posted August 25, 2021 Not sure that Motor is gonna be savable. Also picked up also free the Craftsman jointer and band saw Both of those run. Band saw does need a blade though Quote Link to comment Share on other sites More sharing options...
Paul TIKI Posted August 25, 2021 Share Posted August 25, 2021 Nice find there! I have been coveting band saws lately. It's on my "Save cash for one later" list up near the top, right after a better anvil. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 25, 2021 Share Posted August 25, 2021 How much does that Jointer on it's stand weigh? I recently picked up a 1950's delta jointer that with stand weighs just at 200 pounds. I had to pay scrap rate for mine; 20 UScents a pound. I envy you the bandsaw as well... Quote Link to comment Share on other sites More sharing options...
Donal Harris Posted August 25, 2021 Share Posted August 25, 2021 Does the bandsaw do both wood and metal? I have an old Delta/Rockwell from the 50s. It doesn’t do both and I really wish it did. I consulted someone who sells old Delta parts to see how much it might cost to convert to a switchable model. He told me I would be many times better off just selling it and buying one that came from the factory that way. I suppose I could maybe do it with pulleys. (More accurately expressed as, “I could haul it down to my Dad and ask him if he can do it.”) Nice place. Most people in the US likely think that area of the country is flat nothingness. They are wrong. Quote Link to comment Share on other sites More sharing options...
JHCC Posted August 25, 2021 Share Posted August 25, 2021 1 hour ago, DHarris said: I suppose I could maybe do it with pulleys. I have a thread about my project to make a dual-use bandsaw with a regular motor for wood and a motor with a gear reducer to slow it down for metal. While I've encountered some problems with the gear reducer that I have not yet gotten around to fixing, you might find the discussion interesting. Quote Link to comment Share on other sites More sharing options...
JHCC Posted August 26, 2021 Share Posted August 26, 2021 Mail call, not a moment too soon. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted August 26, 2021 Share Posted August 26, 2021 They work a treat for me, always have some on hand. Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted August 26, 2021 Share Posted August 26, 2021 I had to google medi-lyte to see what it was, ive never heard of it or used it so I thought it was some kind of flux powder lol Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted August 26, 2021 Share Posted August 26, 2021 I found them when I went to the drug store to buy some salt tablets, like I used to get in the service. They told me about Medi-Lyte tablets which are better for dehydration and don't have the bad side effects of salt tablets when used as directed. Picked them up and never looked back. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 26, 2021 Share Posted August 26, 2021 When I lived in OKC back in the early 1980's I used to pick up time release electrolyte tablets at the suppliment store in the mall. Helped a lot when forging in the summer! Quote Link to comment Share on other sites More sharing options...
JHCC Posted August 26, 2021 Share Posted August 26, 2021 The last few times I’ve been in the forge, I’ve really been feeling the heat, despite hydrating like there’s no tomorrow. Someone mentioned this stuff in another thread the other day, so I thought I’d give it a try. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted August 26, 2021 Share Posted August 26, 2021 That was me I believe, I swear by them. Quote Link to comment Share on other sites More sharing options...
Bantou Posted August 27, 2021 Share Posted August 27, 2021 I need to look into that stuff. The last few weeks have been brutal at work between the humidity and lack of breeze. Quote Link to comment Share on other sites More sharing options...
pnut Posted August 27, 2021 Share Posted August 27, 2021 I can't remember the name of the electrolyte tablets they had placed around the rubber refinery, but I think it was the same brand. I used to take them year round. It was also mandatory to take your breaks in the air conditioned break areas. It was always hot in there. I worked second shift so all the machines and mills were running for at least eight hours by the time I came to work which made it even hotter. Pnut Quote Link to comment Share on other sites More sharing options...
