It followed me home
  • Replies 16.3k
  • JHCC
    1836
  • ThomasPowers
    1600
  • Frosty
    1204
  • Daswulf
    716
I’ve visited a few antique shops/salvage yards this week, and came out with a decent few things... including a jack that I want to restore. The jack is a Drednaut No. 27 twin lift screw jack. I can turn the knob by hand and lift the jack all the way out (it telescopes), but I want to take it apart and restore it. I’ll probably start with an Evaporust soak.
Got word yesterday that Kim Thomas was getting rid of some extra materials from his smithing library. A quick text message, a couple hours of driving, and voilà! A bunch of books (some of which I have already, so I’ll be passing those on as well); back issues of “Anvil”, “Blacksmith’s Journal”, “The Anvil’s Ring”, “The Hammer’s Blow”, and “Ornamental Metal Projects”; a couple of exhibition catalogs; and some other assorted bits and bobs.
Also stopped at the flea market and got a little oiling can and a small tap wrench for a buck each.
Das, last time I was driving through PA, I found the roads were actually about 10% potholes. Made for interesting driving. I also found that the number of disabled vehicles on the side of the highways was much higher than I'm accustomed to seeing.
This followed me home from... my home. The man we bought this place from had done some smithing through his life. He gave me a pair of flat bit tongs he made and a pry bar he made from a buggy axle when he was in high school in the 60s. He was a "collector" of things and I can assure you, he most certainly was! There's been a lot of just junk and trash to clean up, but we have found lots of usable hand tools, t posts, fence, etc. He gave me a big machinists vise and an old post drill. I have found lots of metal for the resource pile. Sucker rod, horseshoes, leaf spring, and some differing sizes in square, round, and flat bar and all kinds of goodies I can use. Anyway, I had a pile I had started for cleanup. I had found some files and screwdrivers in it already. But I was walking past it after feeding the goats this morning and these tongs were just laying there. How did I not see those before?!. Y'all reckon I can save them or are they too far gone?
from the local building material salvage place. I'm guessed the ring was a part of an anchor chain or maybe some dockside hardware (wearing a buddy's anchor forging project T shirt might have been an influence), but thinking on it a bit, I think its from  some lifting or rigging gear.  Might be a useful shape in the smithy, might just end up as a tarp holdown weight.
That ring will be great as a form for sinking bowls and other hollow shapes. If it’s weldable, weld on a stem that fits your hardy hole or can be clamped in a vise. If not, I suppose you could drill and tap it to bolt something on.
Can we get a side view?
I have a couple rings from a ring and pintle tow hitch and one like that with the tab.
  With the big angle grinder I cut off the part sticking up to make a dishing form without that projection in the way.  (Being associated with armourers you can't have too many dishing forms or ball stakes!)
