  • Replies 26.4k
    3155
    1935
    1668
    1649
Is there anything near it you can anchor a towstrap and ratchet style come-along to?    .
Or if you have a snatch block you can gain even more mechanical advantag in combination with the come along.
The snatch block would require cable or round webbing. I don't think you can thread a flat tow strap through it.
I just tried the sledge, and it did the trick very nicely. About a dozen good whacks and it was free. Now I feel rather silly about all my overthought leverage antics with the digging bar. I should have gone straight to the sledge!
Thank you for the suggestion! It worked like a charm. :)
Think of it as breaking the ice, which is the wood to ground connection.
I have seen vehicle tires freeze to the ground and trap the vehicle. If you can break them loose, they are flat sided until you travel enough to break off the ice and the tire flexes or warms up enough to become round again.
If it is really frozen you can tear the cords..     Around here when it gets down to the minus numbers you can feel the tires flat spot.. Its not a big deal, as pointed out just in use they will warm up enough to get round again..  But if the tires are stuck in the mud 3 or 4" and tromp on it to get the 4X4 out you can do damage..  My 7.3L diesel has more torque at idle than most gasers do at a higher rpm..    When I plow I don't even give it throttle.. This truck could tear the tires off if they were frozen deep enough..
that is such a shame..  How do you even respond to that..  You dump the clutch and in an instant..
by the way.. It's figurative (joking) that the truck could literally rip the tires off..   the cords would break on one side of the tire and ruin the tires which would eventually lead to a failure..   When the cords break you will see a bubble on the side wall which looks different than a pinch..
Finished off making this long-legged bird thing today. I call them crazy birds because they have a quizzical look. I like to be able to see the makings - my old fence pliers for the head, garden fork crest, speed brace neck, pulley block body, horse shoe wings, some old wrought bar for the legs and U bolt and bolts for the feet.
His beak has the look of a jabiru stork so I forged a small snake from threaded rod for his catch. The head rotates on the handle of the speed bar.
Wow, you move fast JHCC!  I’m still stuck where you last saw my forge.  Thankfully, I have spots opening up in my life that will allow for a little bit of shop time.  Perhaps we will both have gas forges going soon.  Can’t wait to see your first burn.  Remember that it may require adjustments once done.  You may have to back the mig tip away from the mixing tube (or file it back) to get the right burn.
Anarchist58 no, from what I understand, it was dated to around the 1920's? French pattern and quite hefty. Weighs around 100lbs I believe. But my extreme curiosity led me to pick up a crane type digital scale. So I'll know better once she's weighed on it.
Thank you jlpservicesinc, I purchased through a very kind fella on Instagram. Happened to see a post of him restoring a vise, and turns out he does it regularly. This is a 6inch French vise, one I'm not super familiar with. But the threads are crisp with no damage as far as I can tell to the internals of the bell housing. Looking forward to using it, as a tiny bench vise doesn't cut it.
I discovered a small crack on the very end of the bell housing. After asking the seller about it, he graciously offered to replace it. But being so minor, I decided to grind it off as there was still plenty of thread on it.
Most of my shop time was spent cutting up pieces of square tube, to build a hammer and tong rack. Then trying to piece together some scraps I had for the vise stand. Having a small 120v flux core welder has been quite a limiting factor.
