November 16, 20187 yr This is the Peter Wright I picked up earlier in the year for $500. I had made arrangements to buy this from the owner, but could not get it until after ABANA in Richmond. I still have it on the same chunk of wood but removed the bark.
November 17, 20187 yr Hey, I know that anvil.. got to do some forging on it down at the conference.. Nice.. Just the right amount of sway..
November 23, 20187 yr I just bought this one today. Five hour round trip, lunch with my wife at cracker barrel, and $500 for the anvil. It has 85-90 percent rebound the length of the face. The stamped weight is spot on.
November 24, 20187 yr Nice old Mousehole. If you are interested in the history of Mousehole anvils and the Mousehole Forge in England, I recommend you borrow or buy Richard Postman's book, Mousehole Forge. Fascinating reading even if you aren't a history buff...being a smith is reason enough.
November 24, 20187 yr The Undisputed King of Anvils! Exactly the same vintage as my own, and just one pound more. It will serve you well.
November 24, 20187 yr Today it will get BLO applied and hot steel worked on it keeping it ready for the next generation. I have intended to get AIA through ILL, now I will get it done. Thanks
November 26, 20187 yr What a joy to work on. I spent 8-9 hours on it Saturday working different projects. The difference in rebound from what I had been using cut the fatigue factor down. I would have been out there yesterday except for blizzard conditions. I have contacted the local library to see if they can find a copy of Mousehole Forge.
November 26, 20187 yr Author There is nothing wrong with using make do tools, as the cost can be minimal. If you decide you want to continue blacksmithing, or want to move up to better tools, you have time to look around and get the best you can afford. All the practice and hammer time you invested into the make do tool is experience, and working around any problems. You can get spoiled quickly after you get to know the new tool, and figure out what it can do.
November 27, 20187 yr Here's my anvil, it's a truncated Wilkinson's Queens Dudley. From the weight stamp, it was 213Lbs originally, before it lost it's heel. It's right about 185Lbs now, so still a nice weight. (I've since taking these photos cleaned up the face a bit with some hot steel ) It is really nice to use compared to the piece of rail I was previously using, and I got it for 125$, which seems like a good deal to me (67.6 cents/lb).
November 27, 20187 yr I like it. Truncated anvils were on my list, but I couldn't turn one up. I TPAATed my rear end off and nothing. Now that I have made the investment they will probably start coming out of the woodwork.
November 27, 20187 yr 13 hours ago, Chelonian said: I got it for 125$, which seems like a good deal to me I wouldn't have passed that up, and I already have 3 anvils.
November 27, 20187 yr Me too. Have you seen my picture of a truncated anvil with a large C clamp holding a bending fixture on it's face?
November 27, 20187 yr I've seen a photo of your truncated anvil but it didn't have a C-clamp on it, so it must have been a different photo.
December 2, 20187 yr Here are some pictures of a new beautiful French “rhino piggy” I have recently acquired! 340 pounds
December 2, 20187 yr Ethan, She is a beaut.. Congrats.. Looks like you took her for a ride all ready..
December 2, 20187 yr On 11/26/2018 at 5:33 PM, JHCC said: Anvil quality is all in the de-tails. Hardy . . . harhar. Sorry I must be slow today, I'm sure there's something punnier I could say. Frosty The Lucky.
December 11, 20187 yr Kudos, very nice anvils can be seen in here. For me this isn't possible just yet, but have made my own starter anvil from a piece of railroad track. Hopefully it's okay to post this here too. First picture is a collection of my diy starterset, clean and painted, second is mounted on the stand and trying a few starter projects.
December 13, 20187 yr On 11/5/2018 at 3:52 PM, Kellerbomb said: Routed the footprint in the base of 8x8's Use your router and go deeper. Deep enough to put an inch or so of sand in the bottom and the base is seated at least half its height. The sand will deaden the ring and makes it easy to level your anvil. You should not need any other fasteners to hold your anvil in place.
December 31, 20187 yr Check out this beehive anvil I bought at 150 lbs. Have you ever run across a cone anvil like this? Thx. John in Phx
December 31, 20187 yr 3 hours ago, phxfirefighter said: John in Phx We won't remember that once leaving this post, hence the suggestion to edit your profile to show location. Also there are members from all over the world and will not know what PHx stands for. I agree with jlp probably for a power hammer but it is an anvil for sure.
