Show me your anvil
That was actually my plan, and it will not get touched by a grinder. Still gotta deal with that bar they welded across it, but it is an anvil and looks to be in decent shape. Thanks Thomas and JHCC
  • Replies 3.8k
  • Views 846.5k
Most Popular Posts
  • Not done yet but this was cut from 4" plate. Horn was roughed with a O/A torch the finished with a 7" zircon flap disc. Feet cut separate and will be severely welded ;)
  • This is a 80# piece of drop from cutting a hole in a steel plate. No one said an anvil has to have the standard anvil shape.
  • DocsMachine
    DocsMachine
    140-lb pre-1910 Peter Wright. Aged, badly abused, and severely chipped, but no cracks or large chunks broken off. Stand fabbed from scrap angle, strap iron and some fresh 1" square tubing. Two "cutout
Carefully cut at the upper part of the weld right at the bar to remove it then grind the remaining weld off the faceplate. It will probably have lost a little hardness in that area but it should be fully usable.
Awesome score for free. I agree with Thomas. Make him a nice gift.
Sounds like a plan. Gonna make him a hunting knife and his wife a kitchen knife.
  • 2 weeks later...
Just picked this up, 146lb swedish anvil, think it is Soderfors but can't confirm... Real nice, excellent rebound as well.
Sure looks like a Soderfors but may be one they cast for a different brand or one of the other cast Swedish anvils. What's on the other side?
If you dust it with chalk, flour, etc. and wipe the surface details like the lettering in this pic will show up better. If you use oblique light to take pictures surface details will stand out better as well. I never use the camera flash on metal unless it'd corroded or covered in dirt. A piece of tissue paper over t he flash will help but any shine will reflect directly back into the lens and hide details.
I have a 125 lb. Soderfors and have never worked on better. About 30 miles from here there's a 450 lb. double bic Soderfors sitting in a yard as a decoration and the owners won't sell for any price.
<sigh>
Heh heh...and the police don't understand when you sneak into the yard in the middle of the night to give it a gentle wire brushing and BLO either...not that I would know from experience. AHEM...
You see officer, I was just trying to preserve...why no, there's no need for handcuffs...
I've been using these things:
it's a piece of rail (I don't think it's from a normal train, it seems too small) and the back of a weird vise/anvil/drill.
I'm liking the vise back thing, it's strangely quiet when I'm hammering on it. On the side, it says "PATENTED SEPT 22, 1914". Here's an ad for what it looked like when it was new:
image.png.16eb6c37905b4438caa7e5b812606b28.png*not my image, just found it on google*
I don't think I would risk damaging such a cool old thing if I had the front jaw assembly, but I'm thinking it's pretty unlikely that I will ever find one. From what I can tell from researching it a bit, they were not very popular and were not made for very long.
True: they were more a marketing gimmick than a real tool. Turning your bit of rail on end might help a bit, but definitely keep your eye out for something more substantial.
It's quiet because it's cast iron and so an ASO like object and prone to catastrophic failure if hit too hard.
I like your anvil Stevo, did you forge anything on it yet?
Marc1, Unfortunately no. Life has been very, hmm, interesting in the bad way last few months, and my gas forge is half built. I ditched the coal forge when we moved into this neighborhood, so I’m forgeless at the moment :-(
I wish I had been forging lately,  it would be a great distraction and outlet.
Well, It's what I have at the moment. I am kind of worried that it's just going to crumble under the hammer one day, since it's hollow and not that thick. Only weighs about 20LBS.
I've heard people talking about getting a drop from a machine shop, but I don't know of any close to where I live. There is a forklift repair company pretty close though. Would a piece of a fork tine make a decent anvil? And is there a fairly good chance they'll have an old one to sell?
Brooks Anvil; new to Smithing, going to do some blades and axes hopefully. Just picked this beauty up although i don't know much about it and I don't believe it's that old..20-40 years based on the 51 Kilos. I believe it's a good anvil and has hardly been used. Anyone know much about these Brooks anvils? Should I radius the edges? I plan on cleaning off the paint and keeping it oiled. thanks in advance. ..oh it was 350$ CAD which i believe is a great price as i was the first to say I'll take it and there was about 20 after me.
-cheers,
Julian
Looks great.
Use it a while as is before you do any modifying. Then you'll see if it needs the edges radiused more or not.
Good brand, "modern", cast steel, made in England.  I like the 1 CWT and 51 Kilos on it.  A good starter size.  Be careful as cast anvils generally are prone to edge damage---another reason people may radius the edges.  Excellent price, about US$2.38 cents a pound, that's bragging rights in this day and age and in that condition!
Thanks I'm very pleased with the price and condition. I'm not planning any large work at this point so we'll see how it goes whether I radius or not as I don't want any bad chips. Thanks for the response.
pretty sure I'm going to enjoy this forum
this one I have had for about 15 years
Hay Budden 152# picked up this weekend. No visible serial number. Routed the footprint in the base of 8x8's lag bolted together. I'll probably end up using all-thread eventually.
Nice HB anvil.  Treat her kindly, now.  Yeah, you might want to secure her down to your base lest it bounce around on you.
Yep, some latex calk around the base would do it and reduce the ring to a comfortable listening level. Looks like a very nice HB that only needs hot steel hammered on it to shine up that face.
Still working on what hold-down design I'll go with, and the caulk is a definite.
Just arrived today, 86 pounder made in 1899! Not the only anvil in the collection but definitely one of the coolest, the face is in great condition. Should clear up with a good brushing though.
