Everything posted by Cedar Crest Forge
Forge: Pipework for coal fired forge
Yes, I agree with the others, I don't see a clear solution with the design you have, and without seeing the finished work, I will throw out an idea. You could design the pipe to be act like a clinker breaker. I am thinking of the old buffalo forge design. So in your case the pipe would slide though both sides, with a handle on one end to turn it. The " in the forge " pipe cross section could be changed to triangular, or weld something on. The air would be fed from the other end. Then you would have to figure out how to design the holes along the length to get air to flow evenly.
Problems with Forge Welding spring steel
Good point, thanks Steve! I should stay on track to what my books say. I did recommend Jim Hrisoulas's books. Hopefuly that is still on point...The copies I have are quite old now. Hmm, I did say at a minimum, but yes it was not clear that I was referring to getting it to weld, not how well it would cut,
- Workshop scissors
how big of a shop do i need
This thread reminds me of George Carlin's take on "stuff" I guess this applies to blacksmith shops as well. "Sometime's you have to get a bigger shop. Why? Too much stuff."
3rd real knife
Really? I didn't notice that. It looks like a nice, comfortable handle to me.
Folding steel into a throwing knife is Damascus making, not the original definition, but the modern anachronism(pattern welded steel). Have you studied how to make modern damascus steel? May I suggest reading some of Jim Hrisoulas's works, or go to youtube. As Thomas has mentioned, it usually takes alternating layers, usually of high and low carbon steel, to make a good weld for damascus. At a minimum, throw in some mild sheet steel, or better yet, nickel steel from a knifemakers supply house (example 15N20) , in between your layers next time. Save that current piece for a paper weight. Even if you manage to weld it, and weld up to 500 layers of one type of steel, there will be no alternating contrast except for the weld line, because it is all one homongenous piece. It will etch at the same rate. So, your effort will not have the look you envision, or that your efforts deserve.
Any ideas about this anvil?
And Remember the old adage on anvils...Beware the painted lady
What is this stuff?
If you start posting in half sentences, we will know it was lead.
Start of failed bottle opener
Must have been really cold if it was mild steel. Or maybe you meant it was too cold outside, so you left the forge area. Just kidding, Did you try to include a video? The video is blank for me. Try a picture or two instead? And I am not sure if you are asking a question, (how to fix the situation) or just making a general comment. :)
How not to use a drawknife.
About the "Use Neosporin" , I have found it to be an amazing product! If they had this in the medieval ages, many a knight might have lived on. Not all of the types work the same for me though. Or maybe one was expired, haha. Crazy Glue? Wow. Good to know if you are stuck in the backwoods, but honesly, a trip to urgent care is not that expensive either , and should be considered over losing a finger. Don't forget about keeping up on your tetanus shot. Hopefully that draw knife was not rusty. Gloves have saved me multiple times. I use quality leather ones, not the cheap imports with the cloth on the back. Kevlar gloves may be another option for the future. My post is not medical advice, and I specifically excluded how I treat my own cases. Seek professional advice Slag, be careful about giving medical advice. Even if you are a doctor, you have not examined his particular condition. p.s. from the website: "Today cyanoacrylate is used in specific formulas developed for medical use. Note: Krazy Glue products should not be used for wound care" http://www.krazyglue.com/faqs/was-krazy-glue-invented-to-seal-battlefield-wounds#.XNjtfopMGhA
Buy a 4” Post Vice that needs a spring for $100
This thread needs more pictures
Iron City post vise numbers?
Hi MetalBeard. Your vise looks interesting as I usually see iron city vises with the newer triangular shaped mounting bracket. Maybe you have an older model, 1800's? ... or maybe someone switched out the bracket to make it fit the stand. Either way, Nice vise! As for cleaning, remember that these are antiques. A simple wire brush will clean it up without taking the patina off.
- Crack repair of hardened precision vise
I wonder why this has not been answered yet, I am sure there are welders on here. Maybe because you did not specify the type of steel that was cracked? I am not a welder, I would most likely give bad advice. Hmm, with those grooves in the handle, it looks like it was meant to be hand tightened, rather than wrenched.- Employment situation
May that something else be even better than the last...- My first mill! What usage?
Good point! I've been looking for a Bridgeport mill for that exact reason. I already have the steel set aside. 500$ for a powerhammer die is a bit too steep for my taste, and the ones with interchangable dies are even more expensive.- Tooling for my anvil
Interesting. Once you have all the tools made, what is the plan? How will you be using them? Cutlery?- Peppie's Propane Puffer
Nice forge. What kind of tank(s) do you need to keep this 24 port 2 inch diameter forge running all day ?- 1st cable knife
Is there any reason for boiling it, other than a faster reaction? I've been using PCB etchant, which is working fine for me, even diluted.- Garden shed to Blacksmiths workshop
Cool. It has one interesting feature...you can match the tongs to the work by sliding a new rein in. Holding half rounds, for instance, could be done by using half a flat pair and half a round pair.- New at this
Cool. Why wait a month? Maybe you can find a heavy ASO at the scrap yard.- Parallelogram problem
Yes, you probably just need pracfice. It does not take years. However, just to get the basics out of the way: Are you right or left handed, and which side is the round horn of your anvil pointing? What style is your anvil, two horn north german? Old anvils were often resurfaced, to extend industrial use. However, they were not always resurfaced parallel to the base. I think this was done to prevent digging in to the round horn. So, if old, measure height on both ends of your anvil (to the table/stand it is on), to see if anything is off.- Tie down anvil with ratchet straps?
In addition to the good comments already made, also consider "theme"and "atmosphere". If you are planning on making 1800s tools, for example, a traditional looking forge area may help with the flow of producing traditional looking objects. Design creates design. This may not be a normal topic, but If I may re-paraphrase the definition of Feng Shui: "The purpose ... is to get your environment in alignment with who you are and where you want to go—to harmonize your energy with your shop's energy." So, consider not using Chinese made blue or yellow straps if you are going to be making traditional hand crafted objects, like 1800's styled bowie knives etc. Look at Daswulf's stand, for example. The attached curved spoked wheel hasn't been produced in over 100 years.- Terrified of quenching O2 knife
Nice post. I think you meant just the 02 for "normalize = air cooled", as some tool steels like A2 do not normalize that way. I am not the expert on tool steel; just clarifying the topic. https://www.engineersedge.com/materials/normalizing_annealing_tool_steels_13253.htm Gustav, as for the knife, if there is terror in your process, then may I suggest working with some smaller test pieces until you get your process refined. Take some strips of steel ,bevel them, and process.. Break a few at the end of the process, to view your grain structure, etc.- Blacksmith Elbow
Good points on this thread. Diet can also help relieve symptoms, in my opinion. For blacksmith elbow, try a Mediterranean diet. Or search a related topic like 'arthritis meal plan'. For tinnitus, search 'tinnitus meal plan'. - Crack repair of hardened precision vise
