Forged In Fire Tests
Been wondering about this also. With the numerous blades that have shown up with cracks on the show I would have expected these expert blade smiths to at least torch temper the spines. Based on the typical requirement for both chopping and slicing capacity I'd probably temper fairly aggressively. I think that is just as exciting to watch ( especially if they could capture the color change and have the expert commentators talk about why this is critical) as seeing yet another crossection reduced in the press or power hammer. It does appear like the smiths are often quenching their blades in the last 10 minutes of their allotted forging time. You would think leaving that 5-10 minutes to either torch temper or tong temper would be prudent. Of course what I would really like to see is demos of austempering, marquenching and Cryogenic hardening, along with detailed analysis and descriptions, but can see how that might not be as interesting to the general public.
11" Gyuto
Forging looks great. Hope you left enough meat in there to make it through heat treat successfully. Chef's knives on my bucket list for sure. Will look forward to seeing this one completed.
1095 & 15N20 Hunter
Can see why they are thrilled with this. Lovely work.
New to the forum, new shop question
Sidewall exhaust fans, set up high in the peak of your shop, are the bomb for venting the shop. They are best for high volume of air at low static pressure (basically the opposite of what is needed for a forge blower). Get one with a back draft damper/louver if possible to keep out the cold in the winter. I now like the Greenheck SBE line (belt drive, steel prop), but there are plenty of others out there. To get the recommended 10 air changes per hour in a 10' high shop of the size you mentioned you only need 800 CFM. That is a 2' square fan with a 1/4 HP motor. I think I originally got mine from WW Graingers. Remember to have somewhere for the air to enter the shop as well...
If you ever plan on moving/lifting anything substantial, you may want to consider bulking up your framing in one section of the shop where you could hang a cheap electric or chain hoist . Sure wish I had something like that in my shop.
20lb anvil or Railroad track whats better
RR Track (2'length at least) set vertical with the "end" surfaced flat tied onto a post firmly mounted into the ground. Search this site for rail road track anvil info (best I've seen for general use is here: http://www.iforgeiron.com/topic/42290-another-rail-road-iron-anvil/ , but you can certainly get away without the extra work making a horn).
break drum forge questions
Suggest that you take a beginner class or two first to find out if you have the bug for blacksmithing, rather than build a forge. Getting some of the fundamentals down from a competent teacher is orders of magnitude better than trying to reinvent the wheel (though it does appear that you have been doing some good research online as you were aware of the depth of your fire being an important part of forge design). There are a bunch of other fine nuances for constructing a coal forge (method for introducing combustion air - including flow rate, orientation and configuration, vent stacks, clinker breakers and ash dump), but you can certainly get by on a shoestring with a blow dryer and capped steel pipe with small holes drilled in it placed in a shallow trench in the ground if need be. If it were me I would try to experience using some coal forges that have been well constructed before putting any significant effort into building one, but each to his own.
Flame comes mostly out of air holes
This is a very dangerous operating point. I have seen similar burners operating properly and working very well, but perhaps not by the same manufacturer. I would contact the manufacturer and get a replacement rather than futzing with it further. From the photos it appears that the ventauri effect to entrain air at the gas mixer is not working properly. I am more familiar with blown burners than atmospheric type, but in my experience this is usually related to orifice size, gas pressure and/or orifice location in the mixing assembly. It does look like there is a set screw in the side of the burner to adjust the nozzle location, but you should get direction from the manufacturer for the proper setting. They can be a bit tricky (and if the orifice is obstructed with any flash from drilling the behavior of the ventauri can certainly suffer). Also in looking at your photo it appears that the nozzle assembly is not set inline with the overall burner. Was it dropped at some point or damaged in transit? For most naturally aspirated burners it is very important to have the nozzle perfectly centered and aligned to operate properly. Since you went to the expensive of buying a commercial burner I would go directly to the manufacturer for resolution.
What are your opinions on this anvil?
Do you really classify a 3 lb. hammer as a sledge, or was that a typo? I use a 4.5 lb. rounding hand hammer on my 128 lb. Peter Wright regularly without any apparent bad effect (admittedly it may not be as efficient as it would be on a heavier anvil and I'm always careful to work over the center mass when using a full swing). I've also used a 16 lb. sledge with a striker, carefully, on the same anvil and so far avoided any incident (never over the horn or heel though).
Begginer Projects
He means in your search term. If you search beginner projects correctly you will find a lot of info here.
some kind of knife
Lovely little utility knife, forged from pretty unforgiving steel. Like everything about this one, proportions, construction, fit and finish, handle design, forged finish... Only thing wrong here is I didn't make it myself
What materials to forge for a beginner?
A lot of these questions have been asked and answered before. You should try cruising thru the site and reading some more so you have a better basis for asking your questions. Junkyard steel is a mixed blessing. Mild steel can be used for nails and some tooling (like tongs for instance), but knives and struck tools should probably be made of high carbon tool steel. With the time invested in making knives, it is probably worth purchase of steel of known quality, but a fair source for tool steel are automotive shops that do a lot of modding of suspension. If they have cutoffs from new coil or leaf springs these can be used for making tools and knives. You should probably consider starting with more basic projects to get the initial techniques down before assaying something as complicated as a knife, where esoteric things like proper heat treatment can make or break you. Check out the many posts on beginning blacksmithing as well as the "stickies".
What oil should I use for quenching?
Be prepared for curmudgeons to come down on you a bit for spamming the same questions on multiple places on the board without even bothering to do any of your own basic research on this site and in other areas where this info is readily available.
A lot of these questions have been asked and answered before. You should try cruising thru the site and reading some more so you have a better basis for asking your questions. Weight is a more typical method for evaluating anvil size. Does the anvil you are looking at have a number on it (typical for Fishers, this will indicate the weight range)? Put yours on a scale and ask again. Generally speaking though it looks in good condition (but rebound test would certainly be helpful) and should be adequate for knives, small tools and nails (some forge knives on much smaller anvils, even upturned 12 lb sledge heads).
Insulation Cracking
Did a softbrick forge just like you have pictured for my first construction. It lasted through only 3 firings, but that was probably because I used older softbrick that may not have been rated for the elevated temperatures (I'm not completely certain that any softbrick is available that is rated for over 2,300 deg F). It started melting opposite the burner flare. Softbrick also has a bit more thermal mass than the insulation blanket, so will take longer to run up to heat, but will hold that heat a little better. As far as I know, softbrick is also prone to damage from contact with hot flux, though not as much as the glass blanket. If you are a scientist it is pretty easy to calculate the relative heat flux out the sides of your forge with a variety of insulating methods/materials. All you need to know is the U value for the material, the dimensions of the forge and the heating capacity of the burner. To get the actual heating characteristic is a bit more complicated due to door openings and flue losses, but the relative proportion between two insulators can be addressed without too much trouble. Monolithic refractory castings are pretty strong, when cast properly and not subject to extreme thermal cycling. As I mentioned before the refractory is a lousy insulator, and thickness matters a lot. There are also castable insulation materials, but they don't expand and contract the same as the refractory typically.That is why I recommended the intervening layer of glass fiber if you go that route. You would also be able to use a cheaper castable insulation. IF I were making an industrial forge for major production of pattern welded billets I would look into getting a section of high alumina precast tubing for an inner liner. Then cast a larger ring out of insulating castable with a 3" gap on the interior of this new ring from the outside of the precast tubing. I would pack the interstitial space with high temperature blanket and go to town. The only difficulty would be to make a burner port in the precast, but that could be drilled out with either a diamond hole cutter or the old silicon carbide slurry and rotating steel tube method. Something like that should last for years if properly used. Otherwise realize that a forge interior is also a consumable and run with it. Small cracks in your inner liner are not a bid deal provided molten flux doesn't find a way to enter same. Yes it can, depending on the thickness of the material. Even though the castable refractory is not a good insulator, on thicker sections it is possible to have a significant difference between the temperature at the interior of the material and on the outer walls. Depending on the material, the thickness the configuration of the casting and the heating/cooling rate some pretty significant stresses can be evident. Check with the material supplier for recommended firing/cooling rates.
Insulation Cracking
Please be aware that most high alumina castable refractory (that is resistant to flux) is very dense and does not work well as an insulator. So you will certainly need a good insulating layer behind the refractory if you want to have any level of efficiency in firing your forge. As an interior liner, like used by DanielC it should work well. It is also somewhat subject to thermal shock , which it will experience given rapid thermal cycling. This propensity to cracking under thermal stress gets worse the thicker the layer of refractory you install. Note also that the coefficents of thermal expansion between the castable refractory and insulation tend to vary, so a layer of high temperature glass fiber insulation between the two is a good idea (unless your insulation is the glass fiber blanket...). I have in the past added stainless steel needles to the refractory mix to help with this, though any exposed to the surface burn out and it is a real bear to mix up the refractory with those needles. As far as I know these high temperature refractories were designed for forges, kilns and furnaces that operate continuously for long periods of time and users slowly heat them up and cool them down.
New guys forge build pics and a ? about ITC-100
Might want to consider use of a bubble alumina or high alumina ceramic brick (more flux resistant, but very expensive). I have a half brick of same in my forge and it doesn't appear to degrade, but yours gets a bit hotter than mine.
Screwdriver and chisel?
Thomas, do you know whether those plumbing packing chisels were typically made from decent tool steel? I recently picked up a box of around 50 chisels that look a lot like the one the OP posted and would like to know whether they are worth reworking into forging chisels. Some of them appear to have broken away ends, and the grain size looks a bit large. Haven't had a chance to try forging same yet, or even spark testing, but that is the next step. Thanks,
I Had To...
Very nice first knife. Quite a challenge to heat treat one that thin on your first go around without getting any warps. I especially like the faceted handle. You have obviously done some woodworking before to get the complex shape so well rendered. If you don't mind a bit of constructive criticism from another beginning bladesmith, there are two aesthetic issues that might be worth consideration on your next knife. The first is the plunge cut (where you transition between the ricasso and the beveled portion of the knife blade. Making this is arguably one of the more difficult parts of knife grinding (I still struggle with it a bit after my dozen or so knives). You have a very "soft" transition, and a more pronounced transition is typically the accepted standard. The other is a more objective point. For a kitchen "paring" knife I would prefer less of a bulge in the blade above the handle where the blade and handle meet. I probably would have ground an eighth inch or so off the spine of the overall blade when profiling. You are off to an impressive start. Make sure you keep this one so you can judge your progress. I made a very similar kitchen knife, but with a full tang, that I gave away, as my 4th knife, and have regretted if since.
tire hammer
Just had a workshop with Clay this past week. Lovely man, with a lot to teach, particularly regarding tips and tricks for tooling and jigs that work for complicated assemblies (we did the gothic casket workshop). He does appear to be on the road a lot, so that might be part of the delay in his getting back to you. He really is dedicated to passing on his hard earned knowledge, so I'm sure he will get back to you once you formally get in touch.
Anvil Stand preference
Tripod from 3 leg stand is easier to make stable than a 4 leg, particularly if you are dragging it to different positions in your forge or if you fabricate it in a different area. I like the ones with stacked hardwood in a framework that allow you to raise and lower the anvil face incrementally. Like others I've used anvils of a variety of configurations on a range of stand types (stumps, cast concrete blocks, sand filled containers, steel legs with wooden supports...). My current stand is an old stump set on a metal framework with small, solid steel wheels. I got it when I bought the anvil, but it seems to hold up pretty well and not jump around (128 lb. Peter Wright). Have to spend a bit of time and change the strapping method, as the stump cracking has loosened the stove bolts in the end grain, but any time I get in the shop I tend to want to smith rather than repair. Search the site. Lots of good stand designs pictured here.
Is converting my Harbor Freight 6x48 worth it?
You can try to blow it out with compressed air, but if the motor windings are compromised by existing conditions it is likely not worth the effort. Metal dust in unsealed motor bearings, bushings and armature are not any better. I'm no expert, but I'd replace the motor.
Lots of info on belt grinder builds on this site and bladeforums. Search for the No-Weld Grinder kit online as well. I've even seen some belt grinder builds with wood frames. If motor on your HF unit is crapping out possibly because it isn't a TEFC motor and is getting loaded up with metal dust you may be able to salvage things like bearings, but those aren't all that expensive. Depending on your scrap pile you may be able to do a build for between $500 and $800 (depending on motor selection, pulley/drive and idler wheel availability, choice of platen type and how well you can scrounge). Typically they cost more, if you use less sweat equity. All depends on what your time is worth. If you are really creative there are alternatives that may be cheaper, but a good, stable, belt grinder is a godsend for making knives. On the other hand, you can always break the scale off with a 4- 1 1/2" angle grinder with a floppy wheel and draw file...
Just Starting Out: Stock Removal
Also the hardware store is an unlikely place to source the kind of steel you should be using for actual knife making (high carbon tool steel). As all others have said, you need to do a lot more research before safely attempting knife making, much less swords. Stock removal is a great way to start making knives. You can even start with some already profiled kits to focus on the finishing aspects of knife making. As far as time for a sword goes, I just completed a 5 day class where we learned something about rudimentary sword making. We all worked very hard, a minimum of 10 hours per day, on much simpler swords than you have pictured. Without an instructor helping us every step of the way I doubt anyone would have gotten done. Grinding is a challenge, but properly heat treating such a long blade without warping it is more like an art. Certainly could not have done that without a lot of hand holding (and most of us had been bladesmithing for at least a half dozen successful knives). If you want to learn sword making, take your time and don't skip steps. If you just want to own a sword, the cheapest way is to buy one already finished. You can do a lot with relatively simple tools, though a lot of extra time should be budgeted if you won't be using a quality belt grinder. The most critical tool you need is knowledge, and that one will save you a lot of time and grief in the end run.
Let there be light!
My shop has pretty insufficient lighting, to the point where I was having trouble seeing what I was doing at the grinding and polishing "stations" even on overcast days, not to mention at night when I could get into the shop to work most often. Just mounted an inexpensive task light (garage sale cheapo drafting lamp) onto my 2 x 72 grinder with a nice halogen spot bulb and can't believe how much that helps. All I can say is, if you don't have good lighting at your "cold working" stations you are missing out. Heck, I think I may even get some additional fluorescents for the forge zone...
