aessinus
Everything posted by aessinus
  1. That's how I'd go, with the caveat of upsetting the corners good & square on the outside to maintain the crisp lines. Upsetting tiny stuff tests your patience; 1/4"square might be a tad easier. For keeping the heat localized it's sometimes less frustrating to break out the OA & a little brazing tip. Just my 2 copper
  2. Try turning your cypress on end & jst see if you can tell an addition to rebound. Where are you? Might have to try your scrapper.
  3. I used Brownell's OxyphoBlue on one blade for sure, for my young lad. As a cold blue, it's a touchup, but I kept heating it in boiling salt water each application and polishing with steel wool. Ten applications, at least. For old tools I've restored, I've used a phosphoric acid etch also, then regular cold blue to (steel hot as you can stand) in multiple applications to get the tint and consistency to suit. Hardware store phosphoric, muriatic and cider vinegar are my goto store-bought etchants. They sometimes yield quite different results on a given piece of steel, even more so with different alloys. Home leached tannic sometimes works when nothing else does. It always seems to turn into a chemistry experiment..... Go outside, use PPE & stay upwind.
  4. Charles, I worked them when I lived in PA. Lovely animals, and the power is amazing. I'm a mule-man myself....
  5. aessinus replied to muddawgchuck's topic in Vises
    Yar, anvil forging videos! Glad to have you. For the sake of myself & the other "experienced" members, please add your country at least to your profile. (user settings) If you ask or answer a question, the resulting series of posts may be location specific.a question.
  6. on a forged blade with impregnated manure from the neighbor bull.. Would that be a real BS blade?
  7. Try putting paper on the anvil side & do a charcoal rubbing. I swear it looks like there may have been raised letters there once upon a time
  8. Same here. I bed the anvil level in caulk. I can't say zero vibration, but the one in my living room is quiet enough to watch/hear a movie while I'm working
  9. 1: jar lifters 2: yep, milking hobbles 3: anvil stake for a sawyer's anvil 4: wrench for a buried valve, (forged crowfoot )
  10. Thanks for the link. I might make one of those for the shop at work, We have a short, heavy 6" there already, but could stand another taller one for filing & oddball shapes. That vertical looks pretty adaptable, just not super robust. This one should fit the robust need at home pretty well. Got the hitch ball drilled & handle 50% done; planning to upset one end tomorrow at lunchtime & maybe thread a ball for the other. I'm still on the prowl for a big bushing that's already drilled for the bottom hinge. Carrying all the parts around in my truck, just in case I get some spare time to work on it.
  11. Only thing I have is grandpa's posthole diggers. Schedule 80 pipe handles & 3/4"square bar for a box hinge. Forged grader blades for the shovels. Those things will dig thru pure shale or limerock, no problem, but you'd better have your big-boy britches on.
  12. Tongs - repurposed end cutters
  13. Is it flexible enough to ignore any anticlastic?
  14. Was in reference to his last sentence....
  15. Oh you can make money. Get hammering!
  16. If you can find one the Porter-cable is what I have for home. Trigger-lock & I can clamp in my 4"post vise. Dewalt at work, no trigger lock but I fabbed a wedge on safety chain. Has a built-in hanging hook that we can clamp up vertical for little stuff
  17. Please.Do.Not.Machine.The.Face. You should buy a lottery ticket. Add your location to your profile under user/settings. There might be a few members around that would like to see a 15 cents/lb anvil Just.... wow
  18. What alloy? If 300-400 series, maybe hot caustic soda and some salts, depending on alloy. Danger, danger, Will Robinson! Fume hoods, ventilation, PPE are in order...
  19. aessinus replied to Frosty's topic in Prayer List
    Anvil ringing, boss
  20. Bleach/hydrogen peroxide applied to the warm iron will patinate, as well.
  21. One of my buddies scored me a ball hitch that's 2 5/16; mounting stud is within 0.050" of the acme minor diameter, so welding should be fairly straightforward. Have to clean, anneal & bore it for a handle. As it stands, the jaws are 4", however, I could modify them to make them wider... I have a scavenged EDM machine way, 3/4"x 3"x16"long that is hardened. Could be cut to about 8" jaws and left unhardened. I would have to anneal and check for air-hardening alloy of course, but I'm not in any particular rush on this dude. Reduce some current jaw length (2"right now) & weld in place. Jaw width opinions?
  22. Welcome! If you put your general location in the header (user/settings) you might be surprised how many Iforge folk live within visiting distance. The search engine here is weak; use google with "Bradley strap hammer iforgeiron" as keywords. What are you aiming to do in a smithy?
  23. League of Extraordinary Gentlemen? Well done lads.
  24. Frank, is the mounting tang mortised through both the fixed jaw and the spring? If so, I am going to rethink my DIY plan. Drifting through liuft forks would be tough on my smaller anvils, but I have access to a mill & carbide mills. This may qualify me for some overdue vacation.
