Glenn Posted September 26, 2008 Share Posted September 26, 2008 How do you store your coal? Do you use a bin, bucket, barrel, or just have it laying out on the ground? Quote Link to comment Share on other sites More sharing options...
Max Mulholland - Tetnum Posted September 26, 2008 Share Posted September 26, 2008 5 gallon bucket by the forge and some 50# bags in the garrage Quote Link to comment Share on other sites More sharing options...
Sabre Posted September 26, 2008 Share Posted September 26, 2008 i got 1000 pounds free so i just filled my homemade trailer for my tractor. Quote Link to comment Share on other sites More sharing options...
DenK Posted September 26, 2008 Share Posted September 26, 2008 Still in the bag,out of the weather. Quote Link to comment Share on other sites More sharing options...
Pipeliner32 Posted September 26, 2008 Share Posted September 26, 2008 5 gallon bucket here also, also store 2 50 lbs bags in shed Quote Link to comment Share on other sites More sharing options...
jayco Posted September 26, 2008 Share Posted September 26, 2008 I have a pile of lump coal out in the open.....on the ground. The problem with that is that the coal tends to sink into the ground after a year or so. I also have numerous plastic and metal 5 gal. buckets filled with coal.......also outside. The problem with that is that the metal buckets rust out rather quickly.....and the plastic buckets fall apart after a time. I guess I need to either build a coal bin.......or use the coal faster! Quote Link to comment Share on other sites More sharing options...
civilwarblacksmith Posted September 26, 2008 Share Posted September 26, 2008 I have a wooden bin that will hold 700lbs of coal plus a box close to the forge that holds 200 lbs. Quote Link to comment Share on other sites More sharing options...
ironrosefarms Posted September 26, 2008 Share Posted September 26, 2008 Currently keeping it in the white plastic type feed sacks. I have two bags that are pretty nice dime sized lumps that I keep in the garage, I have a lesser quantity that is outside in it's bag that is almost all fines that I am trying to use up right now, keeping it outside keeps it moist and seems to help it coke up better? Have plans for a coal storage area made of brick and wood that should hold about 1000 pounds plus a storage area near the forge that should hold about 200 pounds. Though I am really considering doing some trials with some charcoal and if it goes well I will build a storage area for it as well or subdivide the coal storage? Quote Link to comment Share on other sites More sharing options...
Rob Browne Posted September 26, 2008 Share Posted September 26, 2008 In bags in the shed at present but when I extend the shed then it will go into a purpose built bin. Quote Link to comment Share on other sites More sharing options...
Finnr Posted September 26, 2008 Share Posted September 26, 2008 Plastic buckets for the time being. Finnr Quote Link to comment Share on other sites More sharing options...
mesquiteforge Posted September 26, 2008 Share Posted September 26, 2008 55 gallon plastic drums that were used for food grade products (olive oil). They have a screw on lid and will hold about 400 pounds each. They can be readily purchased for about $5-$10 each. Works well, but in a humid climate moisture tends to build up inside with the lid closed. Quote Link to comment Share on other sites More sharing options...
the_sandy_creek_forge Posted September 26, 2008 Share Posted September 26, 2008 Half of a 300 gallon gas barrel (split longways) with a scrap sheet of galvanized steel roofing over the top. I believe it'll hold a little over 1/2 ton, but the most I've ever had in it is 750 lbs +/-. If you live in the midwest US it seems like every farm has at least one of these barrels laying around that has a leak in it. No good for gas, great for coal (and making hog roasters:) ) -Aaron @ the SCF Quote Link to comment Share on other sites More sharing options...
JerryCarroll Posted September 26, 2008 Share Posted September 26, 2008 6 of the plastic 55 gal. drums--4 steel 55--2 30 gal. by the forge all inside the barn. Several small tubs taken in trade for work setting around under tables and the boat. Quote Link to comment Share on other sites More sharing options...
Ted T Posted September 26, 2008 Share Posted September 26, 2008 1. Large Chunk Coal in a 4' x 7' x 3' high wood bin with open top. 2. Coke in 30 Gallon galvanized cans with lids. 3. Liquid Coke in my refrigerator. Ted Quote Link to comment Share on other sites More sharing options...
rustyshackleford Posted September 26, 2008 Share Posted September 26, 2008 One of these and various five-gals. I need to invest in some 55 gals for the coal mentioned in another post.Copyrighted photo removed and replaced by a link. Quote Link to comment Share on other sites More sharing options...
Trollhammer Posted September 26, 2008 Share Posted September 26, 2008 My day job provides me with plastic 55, 30, 25, 15, and 5 gallon barrels/buckets. I just cut the tops off and rinse 'em out. They're easy to move in and outside, and keeps my shop partner from throwing a fit about the stuff laying around the shop or the yard. Mickey Quote Link to comment Share on other sites More sharing options...
Jmercier Posted September 26, 2008 Share Posted September 26, 2008 30 gallon galvanized trash canhttp://www.tharkis.com/images/shop/coal.jpg Quote Link to comment Share on other sites More sharing options...
Frosty Posted September 26, 2008 Share Posted September 26, 2008 I built a coal bin (bunker?) from pallets, two wide, one deep, one high, three sided, plywood lid, tarp rain fly. Holds a pickup load easily. 5gl. bucket at the forge. I'll build something more proper at the new shop when the time comes. Frosty Quote Link to comment Share on other sites More sharing options...
rthibeau Posted September 26, 2008 Share Posted September 26, 2008 60 gal plastic barrels and 30 gal metal barrels, all inside. Quote Link to comment Share on other sites More sharing options...
hammerkid Posted September 26, 2008 Share Posted September 26, 2008 Currently my coal is in a 55 gal plastic barrel and in a 30gal gal. trash can which is beside the forge. I`am currently building a bigger shop and am going to build a coal bin for inside the old part . Quote Link to comment Share on other sites More sharing options...
John Martin Posted September 26, 2008 Share Posted September 26, 2008 55 Gal metal drums. Holds around 550-600lb. of coal, about 400 of charcoal Quote Link to comment Share on other sites More sharing options...
SK-Buckwheat Posted October 30, 2008 Share Posted October 30, 2008 I currently have 7 tons stored in a coal shed to keep it out of the weather. Walls, roof, etc. Don't have to find it under snow or anything that way. Quote Link to comment Share on other sites More sharing options...
divermike Posted October 30, 2008 Share Posted October 30, 2008 Because our group meets at my place, we have about 7-8 ton sitting in a big pile just outside next to the pole barn, we have 55 gallon garbage cans placed next to the 5 forges in the barn, gets tough in the dead of winter when it freezes, so we tarp it. Quote Link to comment Share on other sites More sharing options...
MRobb Posted October 30, 2008 Share Posted October 30, 2008 Don't have any yet. Hope to soon. Still using gas. By the way some of you are storing it ( by the ton(s) ), I better do it soon before it's gone! LOL Quote Link to comment Share on other sites More sharing options...
unkle spike Posted October 30, 2008 Share Posted October 30, 2008 Mine is stored in the neighbors coal shed, until I need it, then I take my yard wagon behind the lawn tractor and get a load. I keep the wagon parked under the lean-to roof I built over the tractor and other lawn stuff. Quote Link to comment Share on other sites More sharing options...
