what can you make from a bolt?
ausfire
  • Replies 137
OK, I've been trying to make a bolt bottle opener like a snake. I've only ever made loop openers, and lots of them, but I wanted both the head and tail.
Started with a threaded section of a coarse thread bolt. Took a bit of messing around with the bending to make a comfortable fit in the hand, but it looks OK and, importantly, it does actually open bottles!
Perhaps there are other ways, and I'm open to suggestions.
Well, I tried my first split cross from a bolt. Actually my first split cross ever. I did it but boy is it ugly lol. A band saw would be nice. :rolleyes:
I'll try again later. This was just playing around after working on other stuff. Maybe my failure can inspire someone else.
That's a hefty sort of bolt for a first split cross, Das! I think with these crosses it's important to get a good clean cut (Yes, a bandsaw is the go) and to make the cuts cross a good length so that you get a well-defined diamond. Try something a little smaller or maybe a rail spike!
  • 4 months later...
Well done. Great workmanship and remember there are no mistakes if you learn something.( I certainly have learnt a lot from mine) :lol:
As usual this site has left me with a load of inspiration and a list of new ideas to try.
Thanks to all.
  • 3 weeks later...
These bottle openers were made from light aircraft engine bolts. I have a mate who's an aircraft engineer and he saves them for me. They are timed out I think, even though in perfectly good shape.
Not sure what type of steel it is but it's HARD, has a good ring to it, and takes a nice shine. The O-ring grooves make an interesting feature on the finished opener.
Edit:
(P.S. Yes, the original bolt has a cadmium look to it, but I burn that off in an open fire before it goes in the forge.)
