Show me your anvil
Brand spanking new JHM Legend, 215#.
Sooo nice to work on after my old, gifted 83# Trenton.
  • Replies 3.8k
  • Views 846.6k
Most Popular Posts
  • Not done yet but this was cut from 4" plate. Horn was roughed with a O/A torch the finished with a 7" zircon flap disc. Feet cut separate and will be severely welded ;)
  • This is a 80# piece of drop from cutting a hole in a steel plate. No one said an anvil has to have the standard anvil shape.
  • DocsMachine
    DocsMachine
    140-lb pre-1910 Peter Wright. Aged, badly abused, and severely chipped, but no cracks or large chunks broken off. Stand fabbed from scrap angle, strap iron and some fresh 1" square tubing. Two "cutout
Congrats on the new anvil! I have a 125# JHM Journeyman that I picked up used a few years ago, nice anvils.
I fabricated this out of S50C, hardened face plate.  Came in at 90 kilos.
Interesting. How’s the rebound?
So far seems excellent.  Face plate is RC 56 approx.  Anvil 90 kilos, stand close to 120 kilos.  This is my first prototype, and I will make some adjustments in the next one.  I would like to market these if I can sort out the shipping logistics.
I happened to have seen this on Instagram this evening and was curious about it. Is the inside solid?
Yes this is solid, Kind of put together like a big steel sandwich.  1 1/2" steel plate.
Have you done a ball bearing test?
For the next go think about making the stand with the wood pieces oriented vertically, (any internal layers of steel as well if they do not have a full penetration weld between layers).
There is some flex between boundaries and so with them vertical you have anvil:stand + stand:floor rather than  stand:top layer, top layer:second layer, second:3rd , 3rd:4th,....11:12th, 12:floor.  If it's solid then it's the same amount of wood; just cut differently.
@neilyeag sorry but from what I can tell the weld seams in the back or heel show vertical lines..  So this is a composite  or a laminated anvil with plates welded together to get the size and mass?  and then the top plate welded on?
Were the plates used in the base through welded or just around the blocks as a perimeter weld? Were the welds scarfed out? Gouged for a deeper penetration weld bead?
Was the top plate heat treated after welding  or was the whole thing welded out of the same material as the face?
Inquiring minds would like to know.. :)
Yep, I kind of thought about this after it was all done.  The top two layers of the stand are oriented at 90 degrees, but should have made them grain up.  But this is removable so I could change it.  The rest of the stand is kind of like a box.  It is filled with gravel and sand.  So it is pretty darn solid.
See the other reply on the anvil.
Not yet, will check that out in a couple of weeks when I am back up country.
On 12/27/2017 at 9:28 PM, Origins of Iron said:
Brand spanking new JHM Legend, 215#. Sooo nice to work on after my old, gifted 83# Trenton.
JHM.jpg.203f1830298cf4c31ee038a215de0053.jpgJHM.jpg.203f1830298cf4c31ee038a215de0053.jpg
Hey Biggundoctor...I know what you mean; just got mine 3 days ago and it's sweet! I'll be bolting to the 1" plate this weekend!
Picked up this anvil yesterday. It was my grandfather's. it's has been sitting in my uncles shed for years not being used.
Awesome Baxter, it's in nice shape. Put some use to it.
  Love the story of grandfather's anvil, in the uncle's shed, nice find. When I was little, I thought there was a monster in my grandparents basement. Here in the states 255# is borderline monster. Should have looked for the monster in the shed, live and learn.
        N.N.F.             Beautiful, Manchester, Michigan. USA
I acquired these two Italian Anvils last year. The little one is 31 lbs and the bottom one is 140 lbs. I’m gping to build a stand for the bigger one and put it to work this month. The little one is forged and the bigger one is cast most likely from the 50’s? It’s a SFB if anyone here has any info it would be most appreciated.
Are these Italian or French in pattern?  The Italian ones I have seen have more stout bases which are nearly solid.. The French I have seen look more like what you have there.. Curious myself..
These are Italians , one of the main   Differences is that the French have a side exiting hardy and the Pritchel Hole is in the flat horn where the Italian patterns have the pritchel on the round horn with hardy on the flat horn . During certain time periods it seems they shared a similar style “pigs” feet . I believe the more recent style Italian patterns have a more blocky  style base as you pointed out. I’m far from an expert , but I did become familiar with these while traveling and working in Italy.
On 1/7/2018 at 2:36 AM, BIGGUNDOCTOR said:
neilyeag, that wood in the base looks beautiful, what kind is it?
It is a local wood called Mae Daeng.  Very heavy and dense.  It is tough to even drill a pilot hole for a screw!  So perfect for this application.
Nice thanks..  I forgot about the side mounted hardie holes on the French models..
  • 4 weeks later...
 Made this myself nothing special just a crane track    Though it was cool for my first “anvil” lots of time in it though
Rather than spending the money, effort and time cutting and grinding a horn on that why not forge a Bick?
Excellent question!
