Everything posted by arftist
Advice for optimizing my shop built hammer
Way too slow. Number 1 problem. Leave the stroke alone. Only make one change at a time or you lose control. After you nearly double the speed, if you still need more performance, add to the tup weight. Free space should be at least 1" above the work, not the dies. That is the best way to maximize stroke length and the reason for the turnbuckle on the Pittman arm.
ethical question
If you are using 6" long Chinese adjustable wrenches you are certainly using scrap by any definition.
Power hammer anvil requirements
I bit the bullet and bought a piece of 9" diameter hot rolled round bar. Can't say I ever regretted it. A bit over $500 back in the day.
What is this?
Wrought iron does NOT rust like that.
My shop built power hammer, Photo heavy
Zero need for a VFD in my opinion.
Tire on a little giant?
DuPont style hammers will work with a slack belt clutch. I know of one rigged that way, so, yes you can make it run.
Old acetylene oxy rig- looking for advice
Do not try to modify the regulator, just buy an adapter.
- Cast Iron Kettle
- wrought hook
Is this top Fuller repairable
Mushrooming of the struck end of tools is more from lack of maintenance...a soft pad on the end will mushroom even faster and mushrooms lead to shrapnel. Preventative grinding means making the struck end look like the lower segment of a cone then also creating a small radius at the very end. I could fix that tool far quicker than I could build a new one. All that said, a hammer head is so easy to anneal. Note that I am not advocating a harder struck end, just trying to add complete info.
Antique Bender??
That does one(1) of hundreds of bends the hossfeld will do. I make most of my own dies (some are so cheap from hossfeld and so hard to make that they are not worth making) I have made dies for 1" OD thin wall stainless tubing up to 2" pipe and 1)2" by 3" edgewise (hard way). My tube and pipe dies will bend to a tighter radius than factory dies without flattening, because of a very simple modification I figured out. Anyone can figure it out if they think on it enough, since there is very little room for change in a pipe die I have made scroll and c-scroll dies when I need a bunch and want them perfect. The hossfeld is the most versatile bender available.
Antique Bender??
Joel, if you are getting spirals you are not inserting the stock "planarally". If the stock is inserted at right angles to the frame it cannot twist...I often run a hossfeld with a helper. My hossfeld, which I built myself, is one of the most used tools in my shop. I had formal training on it, which took the mystery out of it initially, BUT, on the rare occasion (very rare) that I have a problem, I call Hossfeld and they will spend however long needed, however many phone calls to set me straight. Please, before bad mouthing one of the most elegant, beautifully engineered systems available, learn to use it properly. If you find your #2 to be " bendy and twisty" the problem is you, not the hossfeld. Sorry to be so direct but that is just the truth. When used properly there is no twisting.
Weird welding rod ID question
Note the mention of the Henrob torch. Never seen cast rods welded with regular torch.
Orientation of a Striking Anvil, Other Questions
Definitely best to have your anvil 13 inches thick. Not much point otherwise.
Fontanini vs Nimba
Hi Mike. There is a comparison thread already. Kudos to you, be an American, buy American. Both are great anvils, both made from the same alloy. (Early Fontanini anvils were made from H13, almost ridiculous overkill unless one solely worked stainless.) The Fontanini has a couple extra features, the prices are very similar but one can buy an unfinished Fontanini and save a couple hunge.
Cast iron
Braze away Rene
Designing a 50lb guided helve hammer.
Great job! Frosty once said my hammer was "a real beefeater" but yours has mine beat hands down. Love the 1200# anvil...totally awesome. You done well son, and I appreciate that my design was inspiring for you. Would love to see those vids.
Shop Class?
Have to agree with Biggun, Never seen a set of plans calling for 10-24 that wasn't improved by changing it to 10-32. When I was in Highschool we had two Delta Unisaws, one with a dado blade. Fellow cut the tip of his thumb off his junior year on the table saw. No lawsuit, he knew HE screwed up. Next year same fellow cut the tip of his other thumb off in the dado saw. Same ambulance ride, same self responsibly, no law suit. Shame on this litigious society. A final thought on tapping; Most of the called out tap drill sizes are TOO SMALL. They would work well in free maching brass or dead soft steel and are calculated to provide about 70% thread. A quick google search will bring up a " theoretical percentage of thread" chart. Using such, one can figure the best tapdrill to use by considering the following variables; hardness of material being tapped. Aluminum can be tapped safely at 75% thread, stainless steel should be around 40% Thickness of material especially compared with tap diameter. A 1/4 nut is a 1/4 inch thick. A half inch nut is a half inch thick. Material thicker that the diameter of the tap can be threaded with a lower % of thread, thinner should have a higher percent. In general 50% thread is the most that is required so most specs are wrong and have you drilling too small a hole and breaking taps. Again this is especially important with stainless steel and other hard to tap metals.
How to Make a Hardie Hole
Triangular drill bit, cuts a square hole. Grey cast iron is essentially free machining, much easier than steel..
Power hammer forging rivets,
My thought as well.
Beginner steel stock
Frankly you will have much more fun with 3/8"s or 1/2". 1/4" has so little mass that it only holds a heat for a few seconds, You will spend all your time reheating unless you hit it extremely hard and fast, not exactly beginner skills.
Take along a hack saw. The 12 foot bars are cold rolled. Don't think anyone supplies hot rolled 1/4"
stainless question
Yup, ideally, since a panel is hard to quench. if it is just fabbed and welded then you can get away with acid passivation of the welds alone. Another option is a good sand blasting with clean, new blasting media but obviously leaves a dull finish. Sorry I read project as panel. While we all know it will not happen, S.S. should be worked in a seperate room than iron. At least do the best you can keep the stainless and the area clean from iron filings and dust. This includes but is not limited to covering steel benchs. (I use an aluminum bench for all stainless except commercial work) Lining saw tables with tape or leather or vinal or plastic Use only new saw blades and especially only abrasives. Tape up clamp pads or use protective scrap be it wood plastic or aluminum. Especially important, do not grind or sand iron while your stainless job is in progress or even still in your shop.
stainless question
Stainless doesn't scale, scale is oxidation. Stainless in other languages is inox or nonox. I was specifically discussing austenic grades of stainless which have very low levels of carbon and unlike martinetic grades, cannot be hardened. Stil I am surprised you have never heard that before. As usual you are correct Sir
Upsetting width to thickness limits
Dude, you know so little that it is ridiculous to attempt a sword. Firstly try a simple upsett in mild steel. When you realize how extremely difficult it is you will throw away your scrap leaf springs right away and buy stock the correct thickness. NEVER USE USED LEAF SPRING FOR ANYTHING OTHER THAN WEAR PLATES Don't care how much time you have, not enough time in the world to die young from stubbornness. The main give away is your concept that the hard part is keeping it straight. That is the easy part. Straightening is a skill you clearly don't have yet it is the most basic of skills. What you are proposing is possible but barely so. When our boss (Glen) says buy new, just buy new or don't do the project.
