August 29, 20223 yr I remember one SOFA meeting 20+ years ago where a smith demonstrated a slack tub weld. Heated two pieces of steel to welding temp and threw them in the murky depths of his slack tub. Then he reached in and fished around and brought them out perfectly forge welded together!
August 29, 20223 yr Thomas, Good grief what was in that water? I bet the EPA would like to take a test sample or too!
September 20, 20223 yr This is from Frosty, and it is very true: "folk learn faster and remember more if they're entertained by the lesson, make them laugh and they never forget."
October 4, 20223 yr As opposed to optimal tweaking? Or the the obsessive tweaking we find to be nessisary?
October 4, 20223 yr What's the difference Charles? It's not really obsessive tweaking if it isn't tweaked to destruction. Is it? Frosty The Lucky.
October 5, 20223 yr Author You can tell the quality of a Blacksmith by the quality of his scrap pile! Anvil
October 5, 20223 yr Others You can tell the quality of the blacksmith by the quantity of their scrap pile.
October 6, 20223 yr A real blacksmith doesn't have a "scrap" pile, s/he has a research reference section to document previous experiments and provide future resources. Frosty The Lucky.
October 6, 20223 yr Good Morning, A friend of mine says "I don't bother looking in Neil's "Bish" (RuBish), when he puts it in that pile, there is nothing left worth lookin for" LOL Neil
October 19, 20223 yr Author A bullet can go almost anywhere; but a steel (weapon) is bound to end up somewhere. Dorthey Sayers
October 27, 20223 yr Author "Do not repair what is not broken." coworker of natkova The blacksmith version is, "If it ain't broke we'll fix it till it is." Frosty "And then redesign it to make it better." Glenn
October 31, 20223 yr Everything is a masterpiece in my head... just doesn't usually translate to the real world quite as well... - Wandering_Rogue
November 29, 20223 yr May the sparks of his forge light the fires in others. Thom - Student of Thomas -
November 30, 20223 yr Well said Thom, Thomas’s posts have always given me the courage to light my forge and correct my mistakes, with the wisdom he supplied or given me the courage to try a new project
