September 8, 20214 yr “Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away.” — Antoine de Saint-Exupery ~JHCC
September 21, 20214 yr "There is nothing half so permanent as a temporary solution." ~ Thomas Powers & JHCC
September 29, 20214 yr “It isn’t the mountains ahead to climb that wear you out, it’s the pebble in your shoe” -Muhammed Ali by rockstar.esq
October 4, 20214 yr Author Sometimes even the unreasonable is reasonable. As is the inconceivable becomes conceivable. jlpservicesinc
October 11, 20214 yr Author I tell students that my job is to help them make new and improved mistakes and not the ones I already know about. Thomas Powers
October 13, 20214 yr Author Never lift an anvil up until you have a place available to set it back down! Thomas Powers
October 14, 20214 yr Complex and demanding is what any blacksmith can turn a simple project into. ~ Frosty
November 12, 20214 yr Put all the options on the table and then choose the one that best works for the job at hand. ~ Glenn
November 15, 20214 yr I suspect there are shop gremlins whose goal in life is to cause (or intensify) insanity in anyone focused on a project. ~ Buzzkill
November 15, 20214 yr Why working late on a project can have poor results---NEVER feed them after Midnight!
November 23, 20214 yr A solid foundation in the basic techniques gives you the freedom to improvise later on. ~ Sifu Joel Rodriguez (JHCC's late Ying Jow Pai teacher)
November 27, 20214 yr Author Machining is removing material, welding is adding material, cutting is removing material, forging is moving the molecules of material. swedefiddle
December 3, 20214 yr Author When making multiple items: They aren't perfect, they have personality. Daswulf
December 11, 20214 yr Author I have used cad (cardboard aided design) to lay out the project. Machine Shop
December 12, 20214 yr Author Not my version of CAD, but I do like the way he thinks. Credit goes to the member called Machine Shop.
