BeaverNZ
352 -
Everything posted by BeaverNZ
If budget is a proplem have you looked at a rolling mill they could be made for a small amount with some talented scrounging and from what I have seen of them they work very well
C41-150 Installation
BeaverNZ replied to c.costabile's topic in Power Hammers, Treadle Hammers, Olivers
Looks like you are already mostly done, follow the manufactures recomendations and dont scimp on concrete volume Cheers Beaver -
Manipulating a big hammer, installation
BeaverNZ replied to Jspool's topic in Power Hammers, Treadle Hammers, Olivers
Are those wire rope handles on the bench for tooling I had wondered about doing some thing like that myself as it would be a good way of lessening any shock from miss hits -
Its all done very pleased with the outcome though there are still some faults it will be a servicable knife. I went for Jarah wood with copper pins and danish oil finish
What Robs said is a valid point If I was doing this and had access to a forklift I would try to lift it back up as shown in my scrible this is lifting close to the load centre mass and care would have to be taken when the load tips foward that the pipe doesnt roll forward and you drop the load, Lifting like this also gives you a low lift. Just be carefull take your time and think about out comes before you get commited and past any possible point of no return Cheers Beaver -
When I was doing my power hammer instal I had a quote for mat by Tico anti vibration pad part number MGTP2500. These were quite expensive as well and they were 300x300mm sq and $266 NZD each and needed six of them, I didnt end up using that and used wooden blocks instead. Cheers Beaver
I have got my blade heat treated and etched Im very pleased with how it has come up. I may of left it in the feric chloride abit long and it may be too strong but its all good I am thinking of using jarah for the handle but I keep changing my mind
Industrial Ajax Spring hammer HP?
BeaverNZ replied to Krush's topic in Power Hammers, Treadle Hammers, Olivers
Some one years ago jokingly told me that its not electricity that makes things go its smoke, and when a motor won"t go anymore its because the smoke has leaked out and you have to take the motor back to an electrical service place and get it filled up with smoke again. Black smoke is more expensive than grey smoke. Electric lights are actually dark suckers and the dark comes out of your toaster and makes your toast dark and the excess dark comes out of the power station chimneys. Electricty is just a way the man takes your money off you ITS A CONSPIROUSY LOL cheers Beaver -
Nice, I like the look of both them simple and clean lines Cheers Beaver
Since you have a hole in the back now you could put a grease nipple or zerk as you guys call them and hydrulic out it with a grease gun most lever type grease guns will develope up to 10000 psi. I also agree with Frosty but you have to heat the female part quickly or they both expand if they both heat at the rate Cheers Beaver
The pump just wont develop the design pressure and the smoke will quickly all leak out of the motor and it wont go any more
Collaboration thick chef's knife between Dave Schmitt and myself
BeaverNZ replied to TheoRockNazz's topic in Knife Making
Wow Im going to try coffe if it makes the colours pop loike that, Beutifull blade by the way Cheers Beaver -
I like that alot it looks like an Xray
The problem you will have is the ram you have because of its lower design pressure to get the same tonnage it will have a larger bore which means it has a greater displacement so it will be slow. That pump because of its high design pressure and lower flow output is intended to work smaller dia rams which have a smaller displacement but because of the high pressure still will have a good speed AND tonnage. The trick with hydraulics is to have matched components, You need a ram designed for the pump to get good performance otherwise it will be a compromise. Because the rams design pressure is about one third of the pressure to get the same tonnage a matched high pressure ram could produce it will need three times the piston area with means three times the displacement which means one third of the speed a matched system would have. DONOT TRY 10000psi in the ram Cheers Beaver
Very nicely finished Congrats Cheers Beaver
Frosty Thankyou very much for compressing all that great info into one area there are several things that you have enlightened me in that I have been trying to find about ridgidiser use and when to cut the burner ports now i have some specifics I will finish my gas bottle forge. Cheers Beaver
i need suggestions about putting a bevel on my blade
BeaverNZ replied to BeaverNZ's topic in Knife Making
Hello Thomas Hmmm I thought someone might say freehand and thats probably what will happen and my officail work title is a fitter welder A so i have a foot in each camp welding and machining and now Im doing my best to add forging which is a lot different in how you think about how to make things, Volume instead of size. I think it may be time to bite the bullet and make my smaller variable speed linisher that I have been thinking about for ages Cheers Beaver -
I am at the point of the final finishing of my blade and I am torn which way to put the edge on my blade, its all heat treated and almost as polished as its going to get before etching but I am wondering on how to stop the distal taper from affecting the width of the bevel. All the beveling that i have seen on youtube have been quite thick blades and parallal my blade at the thickest where the bevel will start is about 2.6mm down to about 0.9mm at the point. If I use a diamond imbeded flat cutter and a Heim/rose joint set at the correct height and point or maybe one of those little finger belt sandes/power files guided by the same means I have alot of time in this now and dont want to stuff it any suggestions would be good thanks Beaver
With hydrualic presses when the press is loaded up with pressure and released there is a spike of very high flow and pressure thats what would of burst the hose you had at the start. The flow may be well over 100 lt min just for a split second. Pressurised oil from a burst hose/pipe is exremely dangerous as you and others have said, when I had bulit my press I was setting the relief valve and the steel pipe blew out of the base of the ram it made a very big bang gave me a hell of a fright it was at about 3000psi. I thought it was my fault by not tightening the fitting correctly so I redid that fitting and checked all the others then cotinued and got to just over 4000psi and the same fitting came apart. There was an explosion this time the pipe wrapped itself around the oil tank, filled the workshop with oil mist and i had lost all faith in the fittings but it turned out that the hydrualics place had steel pipe that was hard and the fittings couldnt imbed into the pipe to get the proper grip .The hydraulic supplier let me use their test bed to pressure test all the fittings after that which helped restore my confidence a bit The fittings I used were aeroquip and they normally never ever do what happened to me I have covered all the fittings with steel guards just incase it happens again as some are head height. The max pressure with my press is 4300 psi with an 8" dia ram Cheers Beaver
The Low hydrogen rod run correctly would be just as effective and alot faster as the tig weld but thats up to you, The mosture that you see when preheating is just water condensing from the flame fuel gas hydrocarbons burning and turned into water and Co2
Nice not too many people have a partly tig welded press frame
I believe from others coments that speed may be as important as tonnage see if you can find the max pressure it will develope as an example a 4" ram at 3000psi will develope 16.8 tons if I remember correctly read through what others have put my shop press has 100 tons but is a bit slow and I used to loose alot of heat to the tooling from my work Cheers Beaver
Just make sure its actual tonage they are quoting and not some BS psi force at the cutting edge, some of the wood splitter maufacturers work the force on the cutting edge area. So say they had 10000 pounds force which isnt that much but Im making it simple if that had one sq inch that would be 10000 psi if you worked it out with 1/2 sq inch then it doubles the psi force makes it much more impressive on the sales broacher Go for at least a 3.5 or 4"-75or 100mm ram bore that would give you 12 to 15 tons depending on the hydraulic pressure developed Cheers Beaver
