Everything posted by Richard Furrer
Weight of a Chambersburg 300
I do not, but my 3B Nazel is 13,300 and change...anvil and frame and motor. (book on it is 10,500 so it is a bit more than the catalog weight). I have the Chambersburg catalog, but no weights are given. As far as I know Chambersburg closed and auctioned about a decade ago. I hope someone else is of more help. Ric
Wootz steel ingots
Dr Verhoeven and Al Pendray have their own research. I have met Pendray several times and I like him...he is a deep well. Crucibles: I suggest purchasing silicon carbide to start. You can make your own crucibles later, but it is best to have one variable at a time. Ric
Wootz steel ingots
I'm around yes. There is a steelmaker in Kiwiland by the name of Andrew MacKinnon near Taranaki. He has done more with local NZ ores than anyone I know and is a good man. His specialty is Japanese style work, but he is up to speed on other things. He is a bit of a recluse, but may speak to you about this. I think in the long run you would find it more satisfying to use local ore, smelt it to steel and then make crucible steel from that. A quick search of me on youtube will turn up some of my past classes on wootz. I think there is enough there to get you started. As to travel..I have a man coming in from Australia in a few months....so some folk do move a bit to get here. I would not mind doing a few classes in NZ if there was interest...you guys have some good smiths and knifemakers. Ric
Time to build a new forging press...
I'm building a few presses as well. I bought one of these cylinders: http://www.amazon.com/gp/product/B005CWJZZC/ref=ox_sc_sfl_title_10?ie=UTF8&psc=1&smid=ATVPDKIKX0DER But the price at the time was $360 or so..the day after I bought the price jumped $225. I'd like a 200-300 ton friction screw, but they seem oddly expensive at that range and larger. Ric
Future purchase
As for US makers: Traditional: Louis Mills of Michigan Modern: Howard Clark of Iowa The two above are top of the trade with more time making them than most have in the craft. ....then everybody else you see online. Ric
making a rifle in 58 minutes
Great video. I bought this from the Williamsburg store online last year. ....sad to see folk are posting copy-written material online. Why don't we all go through our video collections of smithing videos and do the same? I'm sure nobody will mind. Ric
Un-plugging a Pritchel hole
A few small drips of nitric acid a few times a day for a few months. or solid Bronze rod a bit smaller than the hole wanted with course grit diamond dust (lapidary store or ebay) and water slurry on low setting under your drill press. Hang a weight or spring off the feed handle on the drill press and walk away. Clean out the hole every five minutes and add new dust/water. Be done in an afternoon. Ric
blacksmith image with latin phrase
I tend to like this type of art, but having a handle on a sword whilst forging the blade is just poor. Happens in films all the time because it is simpler to buy cheap swords and use them as props...without removing the hilts. It is much like "blacksmiths" who hit the anvil first and bounce it off the horseshoe with the rebound blow. Ric
not a good day heat treating
For most modern steels you can quench right into the low temp salt....the structure and hardness depends upon the "S" or "TTT" curve of that particular steel and the temp of the salt pot. Keep in mind that martensite can keep forming well below room temp and is retained in solid solution on high alloy steels in large percentages with higher temp quenches and non-cryo tempering. So: I suggest you go from high temp to low temp and keep the salt pot at about 450F for the above steels. Pull it out to straighten after 25-30 seconds or so and then back in for an hour. Quench to room temp and back into the pot. The second temper can be higher temp or longer if required. No loss of hardness by letting it slow cool after tempering vs dipping it in a water or oil bath....well a point CAN be made for any time at temp having an influence, but the theoretical reality is not enough to worry about....just don't burn yourself on the 400F+ item. You can also quench from high temp into oil and then use the low temp pot as a tempering cycle only. The chemistry and physics of heat treating can get very involved. If you are into that sort of thing then dive in..if not then best not to do anything but dip you toe...the pool of information out there has a way of puling you in. Ric
Safety glasses for forging...
I recall shade three was what the American Welding Society used to recommend for general forging. I use these..or one very similar: http://www.ebay.com/itm/Spirite-Safety-Glass-Shade-3-Welding-lens-/190779854308?pt=LH_DefaultDomain_0&hash=item2c6b5d8de4 For forge welding I place a clear face shield over these. I wear prescription safety glasses with side plates and the above shade three overtop..then a face shield as needed...usually AFTER a juicy slag blob burns my beard. If I did not need glasses to see I am sure I'd be blind by now...I was far too careless in my youth with proper eye protection. Now I treat it like steel toe boots (with leather laces)....they go on before I go out to the shop. The work is dangerous enough without inviting issues. Ric
Mine is a mild steel tube for low temp..have a vertical and horizontal. You can use stainless, but I did not. The horizontal: Made a capped on both ends 4" square tube with a slot on the top and hinged lid. That sits in an insulated (inswool) box and has underneath inside the insulation a 3/4" pipe with 1/8" holes every inch. I plugged the far end of the 3/4 pipe (flatten and weld) and placed a furnace venturi burner on the inlet with a gas line and fine turn valve. I also have a ball valve on the same line so I can leave the fine tuned valve set and just run 5PSI it the thing from the tank. It looks like a 36 port bunsen burner...or ribbon burner. It is 40" long and takes about 60 minutes to come up to temp...longer if not fired and water gets in as the water boils off first. It will temper swords and knives well. There is no flame sensor so you do have to make sure a breeze does not snuff the flame and allow for gas to fill the floor. I have a stainless long neck thermometer set into the bath....surplus on Ebay or such. You can use an inconel thermocouple as well. I find this simpler for long items than a vertical unit. I have thick wire set as hooks to place the blades...they hang above the floor of the pot in the middle of the bath. The whole unit is on a $20 moving dolly and I roll it under the layout table when not in use. Ric
Old N Rusty!
Larry "the Hammer" Harley knifemaker theme song
Hello All, Larry Harley has a Hillwilliam Bluegrass theme song. http://www.youtube.com/watch?v=gnnZOOJKfAo Ric
The Bleeding Edge
Neo, Other than a modern material sword....what is it you are after? Many folk wish to combine materials...be they titanium,coppers,nitrided steel,diamond or plasma coatings to blades, but most of this is done to add another hook to marketing and has nothing to do with performance. If you see a performance issue which needs a solution then we may be able to point you in a direction. If I could have anything work in sword form I guess I'd want a high KW hand held laser or a light saber..never needs sharpening,will not bend or break and the beam at least would not rust. As to available steels...Howard Clark's use of L6 or his 1086modified blades are rather hard to beat. In addition to spending several decades honing his work in forging, geometry and heat treatment he also has a no-nonsense attitude. Ric
- The Bleeding Edge
Dumpy cross pein hammer
Owen I have only known you for, what, five-six years? What I see is his own man...not too beholding to anyone. I have seen many tens if not hundreds of folk shown the same information you have gone after and done nothing with it....such is not the case with you. You can feel content that you have good friends, but I would wager when you turn around in your shop...there is nobody there. Your work is all your own. Ric
high speed cutlers power hammer project.
That is a very wasteful use of that machine. They could use a hot rolling mill and get a huge improvement in product and process. Ric
Punching 30 degress holes
I thought this was a very good way of doing large piercings. With a proper guide and supports I would think many angles could be made well. http://www.youtube.com/watch?v=JWUNUZPhh08 Ric
Shearing many small pieces..need a fab shop contact
waterjet company claims that the thin material (14,18,20 and 60 thou) will float under pressure of the jet...so no go. Ric
Hello All, Anyone know a fab shop who wants to shear some specific sizes from sheet for me? I have spoken to five shops in my area and been turned away by four and waiting a week for a quote from another. I'm not opposed to laser cutting, but feel this is a job for an automated shear. I may end up buying a small shear (minimum 1/8" x 24" capacity) for this gig and slowly doing it myself, but I'd rather locate a cnc shearing shop. I need 20,000 small pieces cut from sheet. Target size is mostly 0.25"x 6" from under 60 thou material...need them flat... not made into curls by a poorly tuned shear or throat-less Beverly type hand shear. Please don't bother telling me to buy slit strip from a supplier...the job is shearing these from small sheet not sourcing new raw material. It is a peculiar specialty job and it requires shearing. If I can not find a shop then I am open to a shear if anyone knows/has one for sale. Ric
surfacing freshly forged damascus....
Without knowing what tooling you have it is difficult to say the best way. Forging to shape, but a heavy 1/16th oversized is good....or 1/8 depending on where your skills are. I know some who have been making blades for years and 1/4" to shape is too close for them. If you have a large amount of scale then add flux on your last heat and wet wire brush (hand brush NOT a wet angle grinder cup brush). Remove scale: sand blast,vinegar dip overnight,angle grinder abrasive wheel Clamp a wooden or metal board in a vise Clam tang to board draw file with a 10-16" mill bastard file...there is a technique there, but to cover that would be a four page letter. should take about 20 minutes to get it flat and the bevels contoured on a 10" forged to shape knife. Forge Scale will dull the file teeth very quickly. From there move to a file cut file and then 150 grit sand paper. Then heat treat and straighten then sand paper to final finish etch and hilt. It will be slow at first and then faster. Use the old files as feed stock for your next damascus. If you are a hobbyist with means then get the best grinder you can. If you are a professional with need then get the best grinder you can. If your finding your way around in the craft of metalworking then hand tools are often the best route. They teach control, forces mistakes to happen slowly so they can be observed and learned from them AND they require less money to get working. That said.....I have four belt grinders and most of the other kit that I see as useful....or maybe useful. Ric
Iron Smelting with Ric Furrer
Dead, "He" teaches out of his shop and has a class listing on his website with dates. ;) That book Thomas recommends is very good. Thank you for posting images of the class Rusty. Have you had a chance to work on that multi-bar you made? Ric
hydraulic press or power hammer
Get either...make work..sell work...buy the other one as well. Ric
Ton per cross section
about 8 ton per square inch steel...double that for carbon stainless and triple for high alloy. More or less. As to 3" round...you want to make it into a square or swage it into a complex shape? It makes a huge difference. I suggest lubrication as well...makes the friction with the dies less. Ric
salt pot heat treating
I would use commercial heat treating salt. I got mine from Parker Heatbath, but they do not sell to "us" any longer. I suggest looking into the products by Houghton http://www.houghtoni.../Locations.aspx Ask them about the specific salts they sell. Some stuff on liquid bath quenching http://www.dfoggkniv...n_Quenching.pdf Ric
