hydraulic press or power hammer
.......for real?
You might as well ask, which is better, a spoon, or a screwdriver... They are 2 completely different tools, one is better for some things that the other is not, and vice versa.
It all depends on what you want to do.
Get either...make work..sell work...buy the other one as well.
Ric
For general forging I'd say powerhammer because I've never seen anyone have enough time to say, draw a long taper on a press
But as has been said they both do very different things, maybe think of it more as which are you going to get first. Where I'd still say powerhammer because I think it'd be able to make its money back and turn a profit faster. Imo :)
Hope this helped
Both are better for what they do. O lack a hydraulic press in my shop right now. Helped a buddy build one and it was in my shop for about 8 months. Got to use it and was getting used to having it when he took it. I would like to have one again but lack the space and dollars right now.
Most of the big toys for smithing do not overlap their use cases well; so it's quite possible to need a Powerhammer, a press *and* a rolling mill and use each one for what it is best at.
If you can have only 1, a larger powerhanmmer is probably the most versatile.
In one corner you have the power hammer, like the anyang.
Pros
These have the power to move the metal fast and efficiently. They get the job done, and have worked for hundreds of years. Relatively maintenance if they are taken care of and oiled properly. I would also wager that a power hammer would have a longer life time than a home built press.
Cons
They have their limitations when it comes to control. If a large hammer (> 200 lb. ram weight) is to be installed, a large foundation is usually required. If the unlikely were to happen, I would assume that the repairs would take a specialist with specific tools and parts that may or may not be hard to come by. This is all the case if you can dish out the money.
In the other corner there is the hydraulic press, like many of the homemade models that are used in blacksmith shops and by bladesmiths.
Reading about this I found this quote from the thread
http://www.iforgeiro...ydraulic +press
Randy stated, "If I had to start all over again from scratch, knowing what I do now I think I would get a press instead of a power hammer."
Pros
These can be built in shop with readily available components. Maintenance would be easier than on a power hammer. The controlability is infinite. This is all available for a fraction of the cost of a power hammer.
Cons
The press is inherently slower, but it is still faster than drawing large stock by hand. The safety issue comes up, but most of these issues can be avoided with precautions and using ones heads (guards covering the hoses and hydraulic components from hot metal and scale, using a "less flammable" marine grade hydraulic fluid, common sense safe practices, ect.)
Are my arguments valid, or do I assume to much. This is a very big debate I have going on in my head right now.
I do not look at purchasing either of these yet. Just curious.
Grant gave this answer to much the same question, "which is the better vehicle to have, a racing car or a dump truck, answer, depends on what you want to do.
Phil
Friction screw press is another
but I want at least a couple of each
get both I had a power hammer and sold it because I use my presses but then I suddenly needed the power hammer so I had to go to my friends shop. I should have kept it.
