- help me determine value and make before I make an offer
My resignation to black smithing.
stuarthesmith, I would do this. but then again I don't care if my neighbors are happy or not. they don't have anyway to control what I do or when I do it. they have called the cops many times when I am out shooting, and the cops always come by ask how i'm doing and see which guns I have out this time...but they never tell me to stop shooting. so if guns are not tool loud and obnoxious then my forge cant be any worse.
It followed me home
I found a great supply of free osage orange stakes, the kind used to hold up construction silt fencing. I have a dozen 3x4 stakes 4 ft long. that's a lot of tool and knife handles. I've already replaced the cracked oak handle on my first tomahawk. It is a nice orange color coated with linseed oil.
- forging a lead mold
forging a lead mold
ok, so first attempt, i got lazy and used my welder. i took an old tool and reworked it to make a set of handles. and arc welded it onto a large square set of blanks. then i took a piece of 3/8 round stoke and with a combination of my grinder and the ol hand hammer i made a small positive ball with sprue, quenched it it harden it as much as possible. next I heated the mold blank to red hot and hammered both halves around the ball and sprue. I call this my first attempt, because the handles sucked, the ball and sprue sucked and the mold section leaked, i made a great flat plate of lead with a ball and sprue molded into it...in otherwords, this is going to the scrap pile for now and I will start over. this time i think i need to source a few actual ball bearings, and i can always drill the prue
yellowish coating on copper
is is a plated coating of some sort, i was hoping someone with more experience than i would know what it might be. it is a goldish yellow coating(it almost looks like brass), i will try to get a picture tomarrow. as for the scratch and sniff chemist...i never said it, but I did avoid the fumes. I may not know what the coating is, but that never meant i was breathing it. i burnt it off is an open area
forging a lead mold
Ok guys, I saw a hand forged 38 cal round ball bullet mold on the net.. I am curious what you guys think, would this be difficult to make. I intend to go out in a few days and try it out. my thoughts are start with making the handles and leaving the jaws extra thick. and then heat the jaws and form them together around either a ball bearing or forging ball on the end of a thin rod for a positive mold. Off site link removed. We get no return from the buyer or the seller for linking to their material
I bought some copper flat bar from the local scrap yard, it looks like it might be a electrical bus bar of some kind. I intend this copper, as thick as it is, to be used for knife fittings. however it has a yellowish coating(or more accuratley a plating) on it. this coating burns off easily as i anneal it so as to make cutting and shaping easier. anyone have a clue as to what this yellow coating is.
My first attempt at knife making.
I've used your etching method with wonderful results. I made my rig from an unused motorcycle trickle charger, and I used fingernail polish as a resist. just paint it on, scratch off the pattern and the rest is the same. I have not settled on my mark as of yet, but I have a few knives that are in need of one. keep us posted, so far good work, can;t wait to see more.
Belt grinder question
I can see your point, but IF your intent is to buy this and then get a better one later, skip a step and start with the better one. even these disk and belt machines have thier place, but IMHO Bladesmithing isn't it. even as a stop-gap tool until better cn be aquired. files While slower and more labor intensive are a better stop-gap then the disk/belt combos like that.
