Future purchase
Thanks for the info I will look into them. Give Rick my best wishes, I hope he does better. Well I would if I didn't need the sword a bit sooner than 20 years from now and if I wanted to become a professional blade smith. I need it for a Japanese martial art and it needs to be of a better quality than I can hope to make before I am forty. I will look at the website that you posted. Look at my response to Glenn. 2nd vote for Howard 3rd vote for Howard Will take a look at this website. ________________________________________ So so far the two main options that have received the most responses are 1) to purchase one from Howard Clark and 2) Learn to make one myself. I will look into Howard Clark and I have already listed why learning to make my own is not really on the table at this time. Does anyone else have any other suggestions? Does anyone else have anything else to say about Louis Mills of Michigan or JPH of atar.com?
Future purchase
I am looking in the next two to five years to purchase a katana. I was hoping that you fellow members can help point me in the right direction in getting a real blade and not a 'wall hanger' as it were. For those who are thinking to themselves "Here is another annoying kid who wants a magical sword for cheap," I do have $3000 stashed away for the purchase. I am reluctant to commit to anything for at least the next year as I am waiting to see if a job I am applying for will pan out. ~Ne0spartan
- The Bleeding Edge
The Bleeding Edge
@Richard: For now I have been trying to keep the discussion in what many would consider the 'real world' but your mentioning of beam based blades circumvents that. Remember this is just for fun and to challenge our creativity and knowledge. Okay how does this sound for a purely hypothetical challenge. Creation of a "heat" blade. Essentially a metal blade that is heated to high temperatures to assist in its cutting. Metal would need to be a alloy which will retain its qualities of sharpness and resilience at higher temperature.The blade would be heated either with electricity or though a chemical process. Application: Make sword that can cut through another sword like butter. Reason for Creation: Because it would be a challenge. Your thoughts on how to do it? @ThomasPowers: I still want to hear more about this special forge :)
- The Bleeding Edge
The Bleeding Edge
As I have stated before the Katana was just an easy example to start the discussion not the end point. Though the information about the sword smith is helpful and I will look at . @Everyone: This is just a place to throw ideas around and not even a planning stage. I put forth a hypothetical sword design that has been floating around my head in order to get everyone's creative brain juices flowing. I am not going to go out and try to make this sword as like Kearnach said I would need deep pockets and I will admit I don't have those (yet ;) ). Plus I want to just build up to other ideas and concepts that are truly bleeding edge but this discussion so far hasn't moved enough forward for that.
The Bleeding Edge
I understand about heat treating. My father worked at a steel mill as a metallurgist and my grandfather worked as a blacksmith at the same steel mill repair shop, he eventually became the head blacksmith there (unfortunately that mill has been mostly shutdown). Working metal seems to be in my blood which is why I am here. That we can get so much just from changing the temperature that a metal is exposed to in one area is astounding and should not be looked down upon. Can you go into more details about the methods used? @Everyone: Remember steel is just a starting place before we get into more exotic materials; don't just focus on it but if you have constructive imput then please post it.
The Bleeding Edge
@Both: Like I have said the Katana was only an example of a sword with multiple parts. The Chinese have been doing the same thing for at least 3 thousand years, starting with their double edged bronze swords which would have a core/edge bronze of higher tin content sandwiched between two layers of bronze with a lower tin content (they were also the first to use chromium to treat a metal). @Basher: I understand that European blades have been thrown under the bus in regards to modern preference for the Katana. And from what I have studied a well made European Blade from the late 1500's would easily been as good as quality as well made Katana. Also the reason for the flex is to prevent the cracking in the first place; make it bend in like a reed in the strong wind instead of shatter like a tall tree (or something along those lines). @ThomasPowers: The term best blades refers to the blades that were made the best and not just munitions blades; it has nothing to do with what type or specific way they were used. I understand that different styles/types of blades are better at different tasks; a straight blade is better than a saber for thrusting but the saber is better at slashing, a short thrusting blade is better in a shield wall then a long cutting blade but the long cutting blade is better for one on one fighting, and the list goes on and on. There is no perfect fits all situations blade but that is not what I was trying to do here. ------- All in all I would say that this is getting off to a good start (at least no one is outright attacking me :P) and you both have given very good points without making me feel stupid :D . So lets again look at my idea but focus down some more specifically on the style of blade being made. So a straight singled edged (except for 3 inches near the tip which is sharpened for thrusting) backsword that has a blade under three feet with a handle that can be used with both hands if necessary. It would have a hard yet durable alloy for the edge metal (I am still open to a carbon steel for this as it is the best steel for holding an edge I personally know). And then I was thinking of using maraging steel for the core and a mangalloy steel for the skin steel. Remember the goal is to push the sword tech to the bleeding edge (similar to the cutting edge but even more advanced).
The Bleeding Edge
Okay I made a bad pun with the title so sue me :P What I want to look at here is information about modern technology and techniques that can be applied to sword smithing. This is just a theoretical idea thread not a "I am going to go make it now" thread so don't get agitated and attack me okay. I just want to tickle people's creativity and have a little fun, if we can actually come up with a usable concept then its a bonus. I though about posting this somewhere else on the forums but this was still the best to do so in. The first idea I want to look at is... Making a "Modern" metal blade. Okay so what do I mean about making a "Modern" metal blade. Well I mean a blade that takes advantage of the wonderful modern alloys that have been developed. The meat and bones of my idea though revolves around a concept found in the best blades, different parts. I am going to use the very basic example (basic in that most people who have exposure to swords should/might know this) of the Japanese Katana as a starting point, specifically the Honsanmai assembly method. Assembly structure With the Honsanmai assembly method you have a hard steel edge, a soft steel for the core, and medium steel for the skin. Please view the diagram to see the specific assemble structure... So instead of just using steels that have a varied content of carbon I was wondering about using a larger variety of steel alloys or not using steel altogether. Using a metal that holds a good edge in place of the edge steel, using a more malleable metal in place of the skin steel, using a metal that has good flex in place of the core steel, etc... Is this a understandable concept? A starting concept So to start things off the design that has been floating around in my head would be to have a hard yet durable alloy for the edge metal, I am still open to a carbon steel for this as it is the best steel for holding an edge I personally know. And then I was thinking of using maraging steel for the core and a mangalloy steel for the skin steel. Any thoughts on these materials or other materials that might be better?
Armor Scales
I just might try part of this, thanks for the information. The ringlord doesn't carry the scale design that I posted above.
Armor Scales
Hey thanks ^-^ Sorry for taking so long to get back to you, I have been busy with finals and term papers.
Armor Scales
I just might go with your method but I would still like to hear Brad's as well, I like like to be informed of different techniques.
Armor Scales
Sorry for not getting back to you before the weekend, I would really appreciate it if you could finish the press diagram. I am also looking forward to your die information as well. Thanks for the help ~Ne0spartan
Armor Scales
I know of this forum and I looked on there for information before I came here (I usually go to Armor Archive for helmet stuff). The reason I am asking here for this bit of info is that I am not looking for period accurate information or techniques (the scales I want are from The Last Samurai for crying out loud XD ) I am looking for general metal working advice which this site has in abundance. Thank you for the suggestion though.
Armor Scales
Well I don't have a hydraulic press but I might know some people people who have one. Could you go into more detail about this rubber press process? I might need to make more of them so this process might be helpful in the future. I was just giving the two months as a reference for when they have to be finished, not how long I need to make them.
Ne0spartan
