Mothman_c3w Posted April 16, 2023 Share Posted April 16, 2023 I scored some scrap stainless steel perforated sheet from work this week. This is 3/16" thick, with 1/2" diameter holes. I cut a few pieces out and made some little dishes. I really like how they turned out. I'm going to to find some stainless bolts, stick three of them in a pattern through the holes, and tig-weld them on as feet for stability. I may also just put a nut on the bolt to let customers adjust the feet as they like. I was surprised how well it formed, but there is a lot of open space in the pattern. Stainless has almost a "gooey" feel to it under the hammer. Quote Link to comment Share on other sites More sharing options...
JHCC Posted April 17, 2023 Share Posted April 17, 2023 Ooh, nice. 2 hours ago, Frosty said: Hydraulic tubing requires a double flair. Ah, well. Maybe I'll just replumb the propane lines on my gas forges. Quote Link to comment Share on other sites More sharing options...
Kdash Posted April 17, 2023 Share Posted April 17, 2023 Those dishes turned out pretty cool. Quote Link to comment Share on other sites More sharing options...
JHCC Posted April 25, 2023 Share Posted April 25, 2023 Stopped by the industrial surplus place and picked up a couple of organizers on sale. (Convenient timing, as I’ve been sorting out my supply of nuts and bolts.) FYI, here’s a panorama of about 1/3 of the place: Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 25, 2023 Share Posted April 25, 2023 WOW, you have a bigger garage than I thought John! I'm still thankful I don't live close enough to go shopping! Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Scott NC Posted April 26, 2023 Share Posted April 26, 2023 (edited) That is huge. I'd like to visit it. Not comparing, but just a memory, as a kid when I first started buying tools, there was a place called "Marv's Bargain Barn", a quonset hut filled with pure junk surplus and tools. I remember to this day buying a wooden handled screwdriver set. They just pressed the driver shaft into a round hole, no glue, ferrule or anything. The handle just turned on the shaft. I tried glueing them but it wouldn't hold so I used a vicegrips on the shaft and the blades bent and the phillips heads sheared off. Edited April 26, 2023 by Scott NC Quote Link to comment Share on other sites More sharing options...
JHCC Posted April 26, 2023 Share Posted April 26, 2023 When I first moved to NYC, there were a number of surplus hardware stores down on Canal Street, the quality of whose wares was … variable. I did get some really good files there, though. Quote Link to comment Share on other sites More sharing options...
Scott NC Posted April 26, 2023 Share Posted April 26, 2023 Yes, Marv had some good stuff as well, can't go wrong with a rubber mallet..... Quote Link to comment Share on other sites More sharing options...
M.J.Lampert Posted April 26, 2023 Share Posted April 26, 2023 mail call, some leather supplies and belt material, as well as a speedy stitcher ( the best stitching device in my opinion for heavy materials) M.J.Lampert Quote Link to comment Share on other sites More sharing options...
Goods Posted April 26, 2023 Share Posted April 26, 2023 I stated out using a speedy stitcher, but I had a lot of problems with heavier leather and keeping the stitching pulled even. So, I switched to punching and even marking/drilling heavy three layer leather sheaths. Then, using a saddle stitch. Ended up looking better (not good yet!) and I’m pretty sure it’s stronger. (Just my thoughts and experiences…) Keep it fun, David Quote Link to comment Share on other sites More sharing options...
M.J.Lampert Posted April 26, 2023 Share Posted April 26, 2023 we use them for fast repairs in the back country as on horse gear or packs they work great as long as you don't apply side pressure (breaks the needles) I noticed that this one I bought isn't set as deep in the wood as the older ones that my father owns (could just be years of use that pressed it in deeper) Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted April 26, 2023 Share Posted April 26, 2023 We use the pro sewing awl which has the spool of thread exposed so you use your thumb to control the stitch tension. Works like a charm once you get used to setting the stitch length. On hard/thick leather soaking it in water makes sewing a breeze with a sewing/lacing pony. Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 26, 2023 Share Posted April 26, 2023 Oh great my Speedy Stitcher IS one of the old ones like your Father's! Heck mine is a Speedy Stitch it's so old the company was to small to afford the er! When I want even and solid I use my awl, triangular needles and a saddle stitch. For a while we had fun altering stitch patterns by alternating holes and or reversing direction, I liked the around the edge X pattern though the chevron was attractive too. It's been so long I'd have to relearn them. I need to make a cover for the Hawk a friend bought me for Christmas. Maybe I'll start playing with stitch patterns. I wonder if I can find my edger and groovers. Hmmmm, down in the basement. . . DRATS! Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Kdash Posted May 3, 2023 Share Posted May 3, 2023 I need to look into that speedy stitcher. Here is my newest acquisition. A 40 watt, water cooler laser cutter/engraver. Was the perfect price, free. Quote Link to comment Share on other sites More sharing options...
Paul TIKI Posted May 3, 2023 Share Posted May 3, 2023 Nice find Kdash! Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 3, 2023 Share Posted May 3, 2023 SWEET! Does it work? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Kdash Posted May 5, 2023 Share Posted May 5, 2023 The previous owner passed away but his wife said he had used it shortly before. It looks like the printer input has been upgraded. The old input board was in the case and had just a printer cable input. The one that is installed has printer cable, SD card input and its own power supply. It came with the water pump, coaxial fan and flex duct so I can install it indoors. There is an SD card with it so may have some usable files. I hope to check it out Sunday. Quote Link to comment Share on other sites More sharing options...
Kdash Posted May 5, 2023 Share Posted May 5, 2023 I also just inherited my sister's bead collection. I can use some to dress up my sheaths but I had no idea how much she had. Quote Link to comment Share on other sites More sharing options...
Purple Bullet Posted May 6, 2023 Share Posted May 6, 2023 Wow! That is a bead stash! Cool to have your own laser engraver, too. Quote Link to comment Share on other sites More sharing options...
George N. M. Posted May 6, 2023 Share Posted May 6, 2023 Kdash, I had the same situation after my wife passed away with all her fiber stuff (spinning and weaving). Some went to musems and libraries. Some went to her friends. And some to the local fiber group to be divided up amongst her friends there. I suggest that you high grade the ones that you think you would use (I really lust after that box of blue ones shown in the photos) and then donate the rest to a craft or beading group. You could put her name on each box so that folk woud remember and think of her when they used them. I am assuming you inherited them after her passing, not in the sense of "inherited" when she was downsizing and passed them to you. My condolences for her passing if that is what happened. George Quote Link to comment Share on other sites More sharing options...
Kdash Posted May 6, 2023 Share Posted May 6, 2023 Thank you, she hasn't passed yet but only has a couple weeks left at best. She wanted me to have them so I drove from Michigan to Southern California, over 5000 miles round trip, in my 20 year old pickup to say goodbye and pick them up. My daughter and niece has expressed some interest in making some things. These are mostly high quality beads, alot of natural stone. Quote Link to comment Share on other sites More sharing options...
masonred Posted May 8, 2023 Share Posted May 8, 2023 A fish belly wrench. Not familiar with this tool picked it up as a novelty but will use it to twist a square bar or something. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted May 8, 2023 Share Posted May 8, 2023 Weld a short handle to the moveable jaw to make it easier to twist. I can't control the wind, all I can do is adjust my sails. ~ Semper Paratus Quote Link to comment Share on other sites More sharing options...
Scott NC Posted May 8, 2023 Share Posted May 8, 2023 On 5/5/2023 at 5:48 PM, Kdash said: also just inherited my sister's bead collection Maybe you could use some of the nicer beads to adorn something you make, whatever that may be, for family members. Quote Link to comment Share on other sites More sharing options...
Kdash Posted May 9, 2023 Share Posted May 9, 2023 Yea I was planning to do that. There are some ceramic beads our mother made from an impression of our grandmothers jewelry. She used to give all the grandkids ornaments for Christmas. I am going to use those to make ornaments for them all. Quote Link to comment Share on other sites More sharing options...
