It followed me home
  • Replies 16.1k
  • JHCC
    1806
  • ThomasPowers
    1600
  • Frosty
    1193
  • Daswulf
    703
Scott, yes, chain shot was a thing but it was used more for naval warfare to cut up the rigging and sails of an opposing ship.  During the 18th century it was thought that it could be used in land warfare against cavalry but by the time of the US Civil War it was not an issue round for either the US or the Confederacy.
Bar shot was similar in use which was 2 half balls connected by a bar, sometimes hinged.
GNM
Nah, commercial farms put them in the feed hoppers to bust the clumps of feed up so the auger can take it down the feed lines,
where I live there’s 100s of commercial poultry farms Tyson, Cobb, Simmons, George, ect… a single broiler farm is usually 5-10 houses 400 foot long and 40 foot wide, with feed lines running down both sides,
we used to have 25k chickens per house but regulations have since knocked that down to 19k birds per house, because someone somewhere felt that chicken destined for the butcher plant in 8 weeks of life needed more space to run around for the farms to be considered “humane”
anyways, you got feed towers outside every chicken house and there’s an auger at the bottom with a ball to bust the clumps, then a line runs into the house and dumps into a feed hopper attached to the feed line and there’s another ball in that hopper that bust up clumps again,
commercial farms undergo retrofitting every so many years and there’s always a farm shutting down an goin under, so there’s a never ending supply of those things laying around
Twisted Willow, I think your whatsit may be ( with a huge emphasis on may be)  a homemade  log drag - they could hook the end of the log and hook the heel chain from the horse to the piece on the end of the device.  Then hold on to the handle as the horse dragged the log.  Or maybe for fence posts - but definitely a drag of a sort - the placement of the ring in the middle of the hooks says drag to me.
  Whatever it might be it's interesting.
Found these, $3 at local resale store. A point is slightly bent but seems sharp, I'll try it before I do anything to repair. If it works, it doesn't need attention on the other hand would just a little time with stone or sander be best approach? These will be better than looking for can or something round when laying out cuts.
Dividers like that have a lot of uses around the shop.  If you take the bend of the tip down with a stone you should do the same with the other leg.  Dividers work best when both legs are the same length.  If it were me I would try to bend the point back into line on the edge of the anvil with light blows.  It was probsbly bent out of line with a lateral force and should be able to be restored the same way.
Good find at a good price.  A person has to look through a LOT of junk but those rare nuggets like this one make it worth it.
Dividers are great for transferring dimensions from a drawing to a piece of hot metal and back. When Aislinn Harris and Mark Sperry (blacksmiths from Colonial Williamsburg) demonstrated at Quad-State a few years back, they were constantly using their dividers to check their progress.
A business trip to Maine took me within visiting distance of both Liberty Tool and Hull Cove Tool Barn. Both were sadly lacking in smithing gear, but I did get a few goodies: a chisel with a very cool cross section, a jeweler’s riveting hammer, a barrette file, a replacement plane blade, a small punch, a spring clamp, two die holders (one with a rather cool set of square holes cut tap shanks), a set of small drill bits, a pipe reamer, and a drafting aid. About $40 for everything.
The file has teeth on only one side and angled safe edges and back for detail work.  843DF6F4-FED4-4466-B6F5-47DD0B0F7F64.thumb.jpeg.faa5d95da5ed28afedb572ba29c9c9cb.jpeg
$1.65 isn’t bad for a Grobet.
John already knows this because he picked up a pair not long ago but if anyone ever gets an opportunity to pick up a pair of proportional dividers do so because you will wonder how you did without them.  You can use them as regular dividers or you can adjust them to get a fixed proportion, say 2 to 1 or 3 to 1 or 2.5 to 1.  They are availble on Ebay and Amazon for prices from less than US$10 to several hundred.
I first learned about them for map making in geology and the military.
Went to a farm auction today, bought a truck load of really cool antique junk but the one thing blacksmithing I grabbed was a Buffalo blower for $15,
it’s missing the original gearbox and someone replaced it with a gearbox of one of those old hand crank bench grinders, which is actually a pretty good idea! Lol
but i bought it for parts essentially, I wanted the stand for a canadey Otto blower and I wanted the impeller for another Buffalo blower project I got goin
