  • Replies 26.6k
  • JHCC
    3163
  • ThomasPowers
    1935
  • Frosty
    1681
  • Daswulf
    1655
Goods, thanks, for the mouse hawks I use 3/16 X 1 X 7 mild steel for the wrap and insert a HC bit, most times 5160 from an old leaf spring
On a full size hawk I use 1/4 X 1 1/2 X 11 mild for the wrap and insert a HC bit
The handles are from Dunlap
Tonight I picked up 2 sheets of cement board for the corner walls where the forge is expected to be. Then I sorted out the finished charcoal (that I started on Sunday) into buckets.
Was hoping to get started on the letter opener tomorrow but might be visiting a friend in the hospital instead.
Yes, a empty space between the insulation and the cement board.
Seal off the insulation with something like drywall, sheet metal, corrugated tin etc to keep it from getting dirty.  Depending on the type insulation you use, pink fiberglass insulation will shed insulation dust or particles that you do not want to breathe.  Other types of insulation may be a fire hazard if it gets hot.  Then leave an air gap between the material and the cement board.  At this point we should ask what type wall construction and what type insulation you are using.
The air gap creates a natural chimney to cool the cement board and keep the wall cool.
Make sure that there are openings at the top and bottom of the gap for the air to flow through, otherwise you won't get the desired chimney effect.
Using paper faced (yellow I think) fiberglass insulation in the walls because I have a bunch leftover from the basement remodel. Using foam sheets in the roof. I also have a roll of carpet pad that I was going to add on the walls not near the forge - to help absorb sound as well as increase insulation. On those walls, the layers would be: metal shed wall - 6mil plastic - fiberglass insulation - carpet padding (hung from rod) and then whatever I've come up with for the inner wall. Was thinking I'd hang welding blankets from a rod toward the front (where there's heat) & moving blankets or denim blankets from a rod toward the back (no risk of heat back there). You messaged me about cutting 55-gal drums to create 3x6 sheets of metal - I like that idea as a wall covering but I'm not sure that the two inner metal strips would be enough to secure it with. Getting closer and closer to just scrounging up some 2x4s and building a dang frame to attach stuff to appropriately. Sometimes trying to save money and cobbling stuff together just creates more mess than it's worth!
Good tip John. Or you could buy one or two rolls of Foil backed fiberglass insulation and hang it foil side towards the forge. It isn't as effective as having a reflector as close to the fire as possible but it helps.
Personally, I feel thats a lot of over kill for a coal or charcoal forge. There just isn;t that much heat to cause a problem. Your hood should be cool enough to touch and if yer belly isn't getting too hot, neither will the wall behind it.
I think they're just erring on the side of 'no such thing as too safe' - I agree about the heat though. I can pick up my rivet forge with bare hands within a minute of spreading the coals after a session and carry it to put it away. And if the heat radiated to the edges then my stock would be getting hot at the end as well - which doesn't happen.
But I don't disagree to set up as safely as possible. Never know when I might change things up and introduce a propane forge to the mix and then I'd have to redesign to accommodate if I didn't already account for it.
Practicing axes again, i need to focus on the eye more and make a proper sized drift to make the eye less wonky, als the bit should go a bit further in the body before welding it. Wrapped eye with a piece of mild steel between the Earl to boost the weight, an old file for the bit.
Total weight is around 900 grams.
IMG_20221026_213219.thumb.jpg.cf5d8c03ecae3144c01f46a485435009.jpgIMG_20221026_213227.thumb.jpg.3fddfd1b1928d286497866dcd272ad9f.jpg
~Jobtiel
I don't have a shop, yet, but I've started the building process.
I ordered the small starter kit from Blacksmith's Depot and "The Backyard Blacksmith" by Lorelei Sims to go along with the first volume of Mark Aspery's book.  I'm still leaning towards the Mr. Volcano gas forge and I'm researching anvils.  I'm also working on where my "shop" will be set up in my back yard.
All this and I have The CFO's approval!  Hahahaha!
Made this in a lost hour between 2 jobs. Is a practice piece for a marshmellowroasterstick (try that on scrabble). A friend get married in december, last year they bought a firepit (a steel bowl more) from me, so as a small weddinggift i would like to make a couple of these.
Only instead of a round it needs to be a heart. And it needs to be longer, i underestimate the amounth of steel needed for the eye and wrap.
The steel i used is weird. Before very hard to bend, now you can almost get it bend if you wave to fast with it. Weird.
I have no idea about a good length to make these. I wad thinking 30cm or 12". Thickness, i like thin, this is 4mm (1/8") but 6mm (1/4") is maybe better?
Also for the heart i was thinking of making a round and than kink it in, but after some youtube it is not that simple.
Unlike in Dutch, we don't have a lot of long combined (smashed together) words in English. Here it would all be separated, "marshmallow roaster stick".
I have said to my friends before that scrabble in the Netherlands must be exciting, lol
I would have also tried to do the heart like you mentioned. Seems logical. But I also have no experience in it, lol
As for thicknesses, I would say quarter inch. The thinner the metal, the faster the heat travels up. You can always reduce most of the fire end and just leave the original thickness closer to the hand.
As for length, the ones I have at home for a campfire are 4 ft long total. The ones for a tabletop type "firepit" are by shorter - maybe 20-24 inches?
That may be an indication that it is a hardenable steel.  If it is and was hardened prior to your forging then you removed that by forging and returned it to an unhardened state. You can test for that easily enough by quenching a small piece to see if it will break rather than bend.
