February 15, 201016 yr What makes for a better cutting plate that will lay over my anvil, copper or brass? and why? I've got access to some decently cheap brass.. and i'm just wondering if that's to hard.. or are they pretty close in hardness?
February 15, 201016 yr I would vote brass over copper, its just a bit more stout and still wont ding up your work or tools, why brass hammers are used for not denting up a nice steel surface. I cannot see a reason why copper would not work other than I wouldn't want it leeching all my heat away like a giant anvil radiator :P
February 15, 201016 yr I dont think it really matters as long as its softer than your hammer and anvil Mine is a piece of 3/4 thick aluminum plate with a hardy shank bolted to it with a 1/2 inch flat head machine screw Mike
February 15, 201016 yr if you have an anvil with the step... you could just use that softer steel instead of doing what was said previously. my 2 cents as they say.. alec
February 15, 201016 yr Author okay cool.. than you all for the advice.. I think i'm gonna go with the brass. :)
February 15, 201016 yr Author On 2/15/2010 at 5:03 PM, Rob Browne said: Just make sure its thick! how thick are we talking about? 3/8's, 1/2? 3/4?
February 16, 201016 yr The trouble with using the step on the anvil is that it will eventually get chisel marks on it which will mar the underside of the work. The advantage of a plate is that it can easily be replaced.
February 16, 201016 yr Hot rolled mild steel it's much cheaper and your chisel should be hard enough that mild steel should not dull it. Softer backing plates can cause burrs on the back of what you are cutting.
February 16, 201016 yr Hot rolled mild steel it's much cheaper and your chisel should be hard enough that mild steel should not dull it. Softer backing plates can cause burrs on the back of what you are cutting. I'm with John. I use a 3/8" mild steel plate and it works just fine. If it's going to be a sacrificial cutting surface, then cheapest makes more sense to me. Not to mention that mild steel is easier to get a hold of that brass in the same thickness (at least for me - your mileage may vary ) Sam
February 16, 201016 yr I use mild hot rolled steel for a cutting plate. I welded a couple tabs on the underside so it sits over the anvil like a saddle. I've used it for a number of years now with no ill effects. Put a chisel on the step of one of my anvils and I'll say HARSH things to you. Copper, brass or al would work fine but draw off heat quickly as well as deform more than a few chisel cuts. I'd also be using the copper and brass for projects unless a very soft tool was needed. A cutting plate is a tool, a bottom tool to be more specific. Frosty the Lucky.
February 16, 201016 yr Author I don't have a cutting plate on my gladiator and I would throw a ninja star at anyone who even looked at that anvil wrong. It's worth more than my car. Maybe I'll try the bronze or the mild steel. As an expendable tool I don't want to spend to much on it, but it will be nice to have. Thanks all for the good suggestions.
February 16, 201016 yr Use any scrap of mild steel that you have around. Throw it in your scrap pile when it gets cut marks on both sides. The old cut marks will leave a mark on your work.
February 16, 201016 yr I'm using a split piece of sch 40 pipe right now. It's on the thin side, but it seems to work well. Phil
February 16, 201016 yr Francis Whitaker, IIRC, says to use a mild steel plate. Softer materials will give causing a less crisp cut or punch.
July 7, 20187 yr Having come into possession of some chunks of structural steel, I made up this cutting saddle that covers almost the entire face of the anvil. Works great for any job, but I especially like it when making split-rein tongs with the treadle hammer. Basically a big piece of angle iron: And flipped around to show the extra piece welded on the open side: Note that the pritchell hole is not covered, so I can still use a hold-down.
July 9, 20187 yr Been using a little piece of 5" channel as a cutting "saddle" for a couple of decades now. No complaints so far. .
July 9, 20187 yr My only complaint is that it's REALLY loud. If I've forgotten my hearing protection, one hit to the chisel, and I remember!
July 9, 20187 yr 1 hour ago, JHCC said: My only complaint is that it's REALLY loud Same with my saddle plate. Try a little masking tape or duct tape on the underside, it helps a little. It will need removed and reapplied on occasion.
July 9, 20187 yr put a piece of hard rubber belting under plate it works well & will kill some of the noise - Rock crusher belt works really good
July 9, 20187 yr Now I'm thinking that a very thin layer of silicone would work well, especially if I first cover the anvil with plastic wrap to keep the plate from sticking. I also have some inner tube rubber that could work. Ideas, ideas....
July 9, 20187 yr Short knap carpet, preferably with a rubber (or rubberized) backing. You can get scraps or cut-offs from a carpet installer, usually for free. Use silicone or other suitable glue to attach the carpet scrap to the underside of the saddle. SLAG.
July 9, 20187 yr I would vote mild steel as well because both copper and brass will work-harden. Also, brass has a tendency to leave residue on hot steel. Maybe not a big deal, unless you're welding. I wonder if anyone has ever tried sinking a mild steel plate into a wooden stump for a cutting anvil. That seems like it would be pretty quiet.
