June 12, 201213 yr Was basically gonna post the same thing Brian did. I can't see any real benefit you'd get from it unless you were welding your stacks drop tong, on piece at a time :)
June 13, 201213 yr I just had a class with Gordon Williams at the NWBA Spring conference. He showed us a flux called Black Magic that is great for propane forges because it does not harm the refractory in any way! Nice stuff. I tried it at the conference but haven't sent off to buy any yet.
June 13, 201213 yr I tried it today. It seems to work well. I'm wondering if the iron powder behaves like a solder and sticks the pieces together.
June 13, 201213 yr More proof it isn't impossible to weld in a propane forge! Looks good Gerald, so what's your flux formula? Frosty The Lucky.
June 15, 201213 yr Here are some pics of the meeting with the MS Forge Council in May. Brian did the demo with the flux and a several of people tried it.https://picasaweb.google.com/LDWynn/MSForgeCouncilMay2012?authuser=0&feat=directlink
June 15, 201213 yr I had a chance to see Brian's brother Ed use it the other day! Man that stuff sure is neat...... I would have to say it gives a beginner like myself a bit of encouragement.
June 15, 201213 yr As most of the professional pattern welders use only propane forges even at mile high+ altitudes I didn't realize this was an issue. I thing the thing is pretty much any solid fuel forge can weld; but you do have to use a propane forge optimized for it.
June 16, 201213 yr Worked ok in the gas forge today (very old NC Whisper Daddy). Didn't jump out as outstanding performance but just did a quickie, I didn't have time to set up an identical test to the one I did in the coal forge.
June 16, 201213 yr I decided to have a go at forge welding this weekend. It's one of those things that loom on the horizon, you know there'll come a time to tackle it. well, today was it for me. I figured I'd do like normal and tackle a big job to start with, (built a stone BBQ once and reckoned that qualified me to build a stone house, which I did :huh:) so I decided to make a tomahawk with a spring steel blade welded in. I'd seen a Youtube doco of someone doing just that and thought "Why not". So, I took an old rail spike, the really old round ones and I forged the head a bit before splitting it with a hot-chisel. I then forged an edge onto a piece of leaf spring and cut a bit off it. I held the cut off bit in the vice and using a cold chisel, cut small curls into the edge, so it would 'hook' into the rail spike. I heated the spike to bright orange, scrubbed off the scale and sprinkled with Borax, before putting back into the fire and brought it up to a near-white-yellow. I dropped it into my home-made swage block and tapped in the spring steel. The spring steel was cold. I tapped the sides of the spike closed along the spring steel and then re-heated everything, de-scaled, Boraxed, and brought it up to "really hot" again and started blending them together. After about four repeates, the magic happened and it was one piece of metal! I kept peering closely to try and find the join line....and there wasn't one!! (Remember Tom Hanks in 'Castaway' when he finally made fire? Well it wasn't quite like that , but I felt pretty good all the same :D) I then went on to finish the 'hawk, and that's when things went pear shaped. I squared the shank of the spike and used a hot chisel to slit it for drifting. I noted a 'crack' along the side when I slit it. I thought maybe not enough heat, though it was pretty bright when I used the chisel and it just got worst as I went. I tried 'cooler' temps and back up near melting point, but to no avail. The XXXX spike just kept 'tearing' for want of a better word. I'm sure someone here can enlighten me as to what went on with this spike. I thought I'd perhaps got a dud, so grabbed another of the round spikes, heated it and started to shape it and it too fell to bits. Definate head scratcher. I welded the head, but could do bugger-all with the shaft. So, disappointed that my first welded 'hawk didn't turn out, but at the same time, pretty XXXX chuffed that I've forge welded.....
June 16, 201213 yr While it may still be the heat that you were working at, that looks to me more like wrought iron delamination, or linear splitting at the grain boundaries of a rolled steel. A true tear would just be jagged and head towards the side. That is the problem with dealing with mystery metals, every piece is a challenge. If it was a leaded or sulpherized free machining steel, it will never forge without cracking.
June 16, 201213 yr Hi Whirly , Great effort mate, Im with John on this looks like wrought iron to me . Chris .
June 16, 201213 yr Wrouht has a tendency to split along the grain. With wrought iron it was more usual to make the eye by folding and forgewelding. However wrought welds up nicely, and it should be no problem to forgeweld the crack back together.
June 16, 201213 yr Very cool wrought iron can be tough if your not used to it. that splitting on the end is from working it to cold and or rolling the work instead of working it from 4 sides.
June 16, 201213 yr Ok, thanks for the info. So I gather if I'm using wrought iron then we're talking much higher temperatures than usual? I haven't had anything to do with wrought prior, but if that had been a square RR spike, it would have shaped up fine at the temps I was trying out. (and the head didn't crack-up, but apart from the splitting, I was operating at welding heat, so I guess I answed my own question.... :)
June 17, 201213 yr Wrough iron for sure in my opinion. So now draw the end out and flatten to a flat bar shape wrap it back on itself and weld your eye. Problem solved. If it starts to become dull yellow stop and reheat.
June 17, 201213 yr when it comes to welding temp, the stuff behaves as would be expected, it is the low temp begavior that is unique..
June 17, 201213 yr The wrought iron produced from raw ores in a coke fed blast furnace of our grandfather's day is a whole 'nuther animal than today's computerized scrap fed electric furnace continuous cast mild steel. That is one of the reasons going by the directions laid out in books from before about 1950 do not produce the same results. It's like trying to make flakey biscuits out of corn meal: not going to happen. The ingredients shape the process, and help determine the outcome. Salmon red would be a medium forging heat for modern low carbon steels, but is too cold for wrought and will cause delamination. Wrought *has* to be forged at what would be considered a welding heat to burning for most steels: lemon yellow to white. It *is* a welding heat, because you are constantly welding the self fluxing bundle of fibers we call wrought iron back in on itself. If you punch or drill wrought, you weaken it by cutting the fibers. You want to slit and drift "frog eyes" along and not across the grain in the metal, or wrap it back on itself and weld it.
June 18, 201213 yr MO, John, thanks for the info. I had a go at fixing it, but no joy. I had it up to 'Sparkle' heat by the end and still couldn't get that sucker to stick back together. I'll hang it on a nail for future investigation, and put the rest of the wrought spikes to one side also. When I become more proficient at forge welding with less taxing materials, I'll come back and have another go. John, thats a good progression photo of the wrapped tomahawk, thanks for posting it.
June 22, 201213 yr I agree with Frank. Also sounds like you are working too cold .."when its yellow, its mellow, when red its dead." Dont be afraid to get it hot. Forge at a yellow, finishing heat is red, and forge weld from a good yellow to light sparking,,and finally, hit the durned thing.
June 22, 201213 yr I describe the weld setting blows as "firm rather than sharp" You want to push the metal together not bounce one piece off the other. And once set heavy hammering is good for a weld (as long as it's still hot)---why you can weld and draw out in one heat on a powerhammer
June 22, 201213 yr I've never welded chain, but when a weld doesn't take I only blame two things, heat or scale. How fast can you pick up your wire brush and then hammer? I'd imagine welding small bits might be easier on a large hot piece of metal too.. but that's a dance I'm not personally confident it pulling off.
June 29, 201213 yr Matt you still have'nt told us where you are, you could be just down the road from me, or you could be in the top end of WA somewhere. Australia just doesnt narrow it down enough, we can fit more than a couple of whole european countries into some of our states. There are a lot of us here, sure one can help you. Phil
June 29, 201213 yr we have the east coast covered, from cairns to melbourne, so if you need a hand just give us a cooee!
