  • Replies 26.6k
    3162
    1935
    1681
    1654
Dharris that looks awesome. And really nice tongs Michael.
I’ve got a question - does anyone know how much twisting square bar will shorten it? I mean, it does shorten it right lol? But the twist in the middle of this fire poker for example? Any educated guesses on how much it shortened? Overall length of the whole poker is about 34”. Thanks in advance for any answers.
Lol I’m not a high brow kinda guy but good call.
Ok guys wish me luck. Poker has to ship today or it will be considered late. I’ve got the four piece basket bundle finally welded to the shaft. There is a spot that’s thinner than I wouldve liked but it is ok. Going to follow John Switzers steps from Black Bear Forge on you tube for the rest.
Draw out the other end of the bundle to a taper so it ready to be made into the hook      .then do the twist with the twisting wrench on that taper for the hook
make the hook
selectively cool the hook and do the untwist from that end
Get all of that mostly in line and cooled then pray to god I cut it to the correct size so that when I do the forge weld for the poking end I end up with the around the right length
then put the twist in the middle with John didn’t do but that’s fine I really like that part and it’s relatively low risk
How much twisting square bar will shorten it would depend on the size of the square bar and the amount and type of twisting you are applying to the bar.
A coil formed by winding wire around a uniform tube to form a helix would certainly be different from say a pineapple twist or a just a plain twist.
No smithy today it’s been pouring down sleet, so mostly working in the shop
but today a little while ago I drug a sled on the ice for Max!
it’s not deep yet about 3/4” to 1” deep but it’s slick!
He had a ball! Infact he was half froze an still through a complete fit when mom took him back in! He wanted to keep going! Lol
Which leads me to a question, have any of y’all ever forged one of those old style sleds with the metal skids or skis or runners, whatever you call em,
the kind that had the wooden top but metal frame,
I just got to thinking that would be a cool blacksmith project!
I built a sled from a discarded set of children's skis once.  My kids were embarrassed the first time we went sledding with it---until they found it went considerably farther than the commercial sleds the other kids had.  Back when we lived in Central Ohio and snow was an expected part of winter...Taught my Daughters dumpster diving out there too!
  Consider a steering mechanism for downhill sledding.  I'm not sure if they tilt the rails or extend one of them.  The one I had as a child had a board you could pull back on one side or the other, depending on which way you wanted to go.  No fun riding straight into a tree.  Pulling around would be fine.
As I recall my Flexible Flyer sled that I had as a child the runners were slightly concave facing down and the steering bar flexed the runners left and right for steering.
I have seen photos of European sleds with pretty cool curves on the front of the runners.
One of the reasons that Thomas' sled using skis may have worked better is more flotation to stay on the top of the snow because of more surface area.  I recall my old sled cutting into deep snow because of the narrow runners.
Now thinking more on the runners, If you were putting a slight v curve shape to it,
would it be better to start with flat bar and put your v curve in it?
or would it be better to start with angle iron and flatten it as needed?
George, we don’t get many heavy snows here so it would probably work better to have wide runners,
If I was doing it I would start with about 3/4-1" flat stock and forge a slight lengthwise groove into it using a fuller and then weld or rivet supports to it for the deck of the sled.  And the edges of the runners should be sharp and crisp like the edges of ice skates (which are also concave, IIRC).
