March 11, 201412 yr heres my vice its a lil bit high but when the smithy gets put up ima put the wheel into the floor a bit
March 18, 201412 yr I found this 5" Columbian in the back of an antique shop, paid 80$ for it. I took it apart, cleaned and greased it good. Just have to get it mounted up now
April 7, 201412 yr Heres my vise i bought with no post had to weld round stock back on for a leg and made the stand today i dont know how ive got by without it vice in the forge ive crambed stuff in the hardie hole to bend
April 9, 201412 yr I will make a new wise, and I shoult have some nice drawings. Some good ideas? Her is av wise I make for many many years ago: Have you seen somthing like this?
April 9, 201412 yr Welcome aboard Torbo, glad to have you. If you put your general location in the header folk won't have to keep bugging you. Looks like a jig for making hearts. Without seeing it in action I can't say for sure but it LOOKS a lot more complicated than is helpful. Of course that's just my opinion I could be wrong. Frosty The Lucky.
April 10, 201412 yr Torbo, That looks very specialized, what do you use it for? Bill If you have things in vices that are not on line, or irregular, semicircular, etc. then the slopes (or what you call it), which are loose, set so that they get in touch. Then lock the slopes of levers and then hugs you to (screw it fast as normaly). Comprises attachment uneven thing at several points and then it becomes easier to work.I must admit that I have not used it as much, but it was nice to create something special.
April 10, 201412 yr Here is another procect: (big kids play best) or what? I should also maka good press hydraulic may be? Some good ideaes?
April 27, 201412 yr ..............and now I have a 6 inch added to the collection as well, I will have to forge a spring and mounting plate for the old girl.
April 27, 201412 yr I will make a new wise, and I shoult have some nice drawings. Some good ideas? Her is av wise I make for many many years ago: Have you seen somthing like this? Welcome aboard Torbo, glad to have you. If you put your general location in the header folk won't have to keep bugging you. Looks like a jig for making hearts. Without seeing it in action I can't say for sure but it LOOKS a lot more complicated than is helpful. Of course that's just my opinion I could be wrong. Frosty The Lucky. We had a vise similar to this in the Drill department. We didn't use it very often because it was, indeed a pain to get set up properly, but for small, irregular, shapes (or even small regular shapes) that nothing else would hold sufficiently for accurate production drilling, it was a life saver! :)
May 2, 201412 yr Here is one of my wises that I make for many years ago: Vise with adjustable and lockable slides (hardened), which can take hold all parts in the "all" shapes. Has anyone seen anything similar?
May 3, 201412 yr this is my post vise. I bought it today for only 22€. it seems almost perfect! now I have to set it up. probably I'll go with a car rim because I need to move it from inside (shop) to the outside (forge)
May 11, 201412 yr Torbo, That looks very specialized, what do you use it for? Bill To day I use the wise til drill some foundament til my lathe.
May 25, 201412 yr Picked up a new vise today. Couldn't believe my luck. Columbian with 6" jaws. Everything works, it is nice and tight, and very heavy. Replacing this cobbled together one: With this:
June 1, 201412 yr That is a very nice looking vise. German made? I have one very similar going for sale soon.
June 11, 201411 yr I picked this monster up last year on the way home from the spring conference. The guy I got it from said his dad used to clamp differentials from big rigs in it for rebuilding. It measures over 16 inches tall and 27 inches long the jaws are 6 inches. Very heavy, I took it apart to carry it into my shop.
July 1, 201411 yr My three leg vises, the left is my 3 1/4" traveling vise for demos. The right is my 4 1/2" shop vise and the monster in the middle is my "new" 8 7/16" Peddinghaus vise I just finished the stand for yesterday. The stand is all scrap yard finds, like the floor plate, it's a miss-cut jig table from someone, 250lbs though! All together it weighs around 500lbs.
July 17, 201411 yr Was my great, great grandfather's vise, been in the family probably since vise was bought. 5" jaws, this is a Goldie vise, with one broken mounting bracket. Inherited from my grandfather, and I use it all the time in my metal shop - I do metalsmithing and silversmithing these days. have a newer vise I found at the local dump, but not mounted.
July 20, 201411 yr I put my post vise together late winter and have been using it now for a few months and it works great. I mounted it on a 4 inch square post that has half inch walls. The base is a 3 ft circle of quarter inch plate It. I built the tray based on the vises I have used at the New England School of Metal Smithing in Auburn ME. For general use this has turned into one of those things that I wonder how I did wthout it for years. When I really need to "reef" on it standing on the base makes that possible. I welded it together with my old Montgomery Ward stick welder. (I know I'm dating myself with that little nugget of info.)
July 28, 201411 yr Loneronin, your vise looks almost the same than my 7" post vise. I bought it second hand a few years back but gave it the good once over recently. I do not have a "before" pic but the cleaned up version is quite nice to look at and bonus: it does work without too much play or jaw offset. I have one question though: the inner diameter of the "donut" between crankbar and front jaw, is quite a bit larger than the outer diameter of the "screw". How much play should the "donut" really have?
