11,866 -
Looks like I have some catching up to do
Irondragon Forge ClayWorks replied to BIGGUNDOCTOR's topic in Everything Else
Had us worried, definitely missed ya. Car owner virus has me in it's grip too, have 5 in the stable. My pride and joy is a 1987 Cavalier port fuel injected Z24 hatchback all original with 233,890 miles on her and still runs like a NASCAR. -
pattern welded jailhouse shiv
Irondragon Forge ClayWorks replied to George N. M.'s topic in Knife Making
I don't know what happened but I can't open the attachments. -
I have three of them, the oldest is a Milwaukee which was given to me years ago, because it wouldn't run. All it needed was a set of brushes and the gear box greased up. It has been going fine now for at least 5 years. I keep a flap wheel on it and the other two have a cutoff wheel and grinding wheel, that way I don't have to change disks as often, just pick up the one for the job at hand. Like others have said show it a lot of respect as should be done with any power tool and be sure to wear PPE. If you didn't get a manual with it, I bet it would be available free online. I always recommend to RTFM. (Read the Field Manual)
Welcome aboard, If you would please READ THIS FIRST It will help you get the best out of the forum, with tips like editing your profile to show your location, as so many answers require knowing where in the world you are located. Other tips on doing the best search and some may help flying under the moderators radar. A good looking Trenton and a fantastic deal. The number 245 is the weight in pounds as when it was made + or- a little. The other number is the serial number and I bet someone with a copy of AIA will be along to let you know about when it was made. I hope you have read about not doing any grinding, milling or welding on the hardened face.
Another scrap chair/bench
Irondragon Forge ClayWorks replied to ausfire's topic in Metal Sculpture & Carvings
I don't know what happened to my reply (seems to have disappeared) but I said it's stunning and as an old gear-head, I love it. -
That's how we removed the valve from the tank, strapped it to a tree and used a 4 foot cheater bar on a wrench I made to fit over the valve. You can see the wrench on the right of the forge.
Have you read this yet? READ THIS FIRST - It will help in getting the best out of the forum with tips like editing your profile to show your location to show it as so many answers depend upon knowing where in the world you are located and others may help in flying under the moderators radar.
Welcome aboard... I always suggest reading this to get the best out of the forum. READ THIS FIRST - It is full of tips like editing your profile to show your location as so many answers depend upon knowing where in the world you are located. There are many other tips too, some will help in flying under the moderators radar. To upload pictures you need to resize them by 50% so the forum will accept them. Maybe someone who is using charcoal will have an idea about what the stuff is.
Yep... ya done good, should last for generations of smiths.
- 101 replies
- anvil
- identifying anvils
(and 2 more)
Sweden Anvil
Irondragon Forge ClayWorks replied to Foxman's topic in Anvils, Swage Blocks, and Mandrels
How is the ring & rebound? Should ring like a bell. Great find. -
Casting forge
Irondragon Forge ClayWorks replied to Legamin's topic in Smelting, Melting, Foundry, and Casting
Welcome aboard... Have you read this yet? READ THIS FIRST It is full of tips like editing your profile to show your location, as so many answers depend upon knowing where in the world you are located and some may help in flying under the moderators radar. -
Hello from Mexico
Irondragon Forge ClayWorks replied to Missionary Farmer's topic in Introduce Yourself
Going from memory, the blade is 3inch wide leaf spring about twelve inches long with the point and cutting blade drawn out and holes punched then normalized. The bolts through the blade are 5/16 inch (3/8 would be better) all-thread flattened, with the through bolt holes punched. The through bolts & nuts are also 5/16 inch. The haft is just ash 2X2 with the hand portioned planed round four feet in length (can be longer). I gave the one I made to a friend and he loves it but one of the all-thread bolts broke and he keeps forgetting to bring it in to replace the bolts with 3/8 ones. Now that winter is over I bet he will remember it. -
Hello from Mexico
I have the perfect hoe for you. It is called an Ozark hoe made by my mentor Isaac (Ike) Doss. It consists of a leaf spring blade, held on to a wood haft. Perfect for dry and or rocky ground. Here is a couple of pictures of them. An original on the left and a copy I made on the right. -
Along with the propane bottle, which would last about ten minutes with a 3/4 inch burner.
Building my shop
Irondragon Forge ClayWorks replied to Owen Hinsman's topic in Building, Designing a Shop
I remember where I've seen them on Amazon, mostly good reviews too. -
Building my shop
I would probably mount it a little farther away, just to be safe. Is that one of the blowers made in Russia, I've seen some good reviews about them. Now that I think about it those were hand crank blowers.
