ok, I'm here....as Colleen said, her anvil in not purple but lilac....distinctly different shades. These are purple....
http://www.iforgeiron.com/gallery/image/30329-dividers/
http://www.iforgeiron.com/gallery/image/33851-swivel-stool/
http://www.iforgeiron.com/gallery/image/25441-finnrs-tongs-and-jj-tongs/
http://www.iforgeiron.com/gallery/image/24495-portable-forge/
http://www.iforgeiron.com/gallery/image/23329-purple-hook/
http://www.iforgeiron.com/gallery/image/20298-ole-no-148/
I could go on but that` should be enough to make the point.
:P
Colleen..carry on and bless you....
Make a jig that fits over the power hammer bottom die to hold the hammer blank in place, then it will be easier to get the punch set right....or you could make a jig the holds the blank and the punch in line together
Dave, methinks you should just send me that hammer for proper training and start over to incorporate all the suggestions previously given. What are you using to punch the eye?? With a flypress I take that many heats.```` -_-
at times during a forging session, you rake through the fire to remove any hardened clumps of assorted trash that mysteriously accumulates to clear the way for the air to get to the coal to burn. Several theories have been proposed to explain this phenomonon (sp). Perhaps one of the most widely held beliefs is that a Dragon sneaks by when your head is turned away from the fire and snots into the firepot. That is what is found as a clinker. A few think that a clinker is just the residue from burning coal, but they are a minority methinks. :)
I use collars with a hex locking screw welded to a length of steel. Put the letter stamp in the collar, lock it in with the set screw, hold onto the handle and whale away. You can see exactly where you are putting the stamp and can hammer it hard without worrying about your fingers. Also works great on large pieces where the heat is too great to get your hand near. Position the stamp in the collar for either right or left handed use.
one thought: a box trailer outfitted with a generator for electricity, a workbench, portable forge , etc......drive to where you can work...the trailer is your shop, get as big a one as possible (parking, storing, etc)
most of the store bought hammers I have found are in the 1045 - 1060 range and can be tempered to suit your purposes...too soft is not good for the everyday hammer. Get 'em cheap...make 'em to what you want.......heat treat to temper....piece of pie
Oh...nice work on that hammer
splitting firewood?? get an electric hydraulic log splitter if doing only a couple cord a year....more than that or as the source of home heat...get a gas run splitter as big as you can afford. Splitting mauls? Not after age 45...... -_-
