July 11, 20188 yr Christmas in July I posted the anvil I bought, which I thought was a nice present to me, but Friday I stopped at the local Habitat for Humanity Re-store and this was disassembled and wrapped up in plastic. For CHEAP! No names or identifying marks so maybe homemade. Unwrapped it and found a thermocouple and gauge inside it. The thermocouple works but I don't know how accurate it is. I can't get the photo of the single burner gas forge to load. I'll try again. Hawk
July 11, 20188 yr Nice bunch of stuff!!! Guys are making knives out of the pipe wrench handles these days. Too bad you missed out on the anvils. You may want to get the names and addresses of the elderly people who got them for sentimental reasons. They might get over their attachment after tripping over it a few times on the garage floor or when they see some real cash offered. You could start by just asking to see the anvils, and when they see you are a blacksmith and really like the anvil they just might feel you'd get more use out of it than they would.
July 11, 20188 yr Nice find, hawk18. Make sure you rigidize and line the kaowool before you fire it up, or you’ll be putting yourself in the way of a world of lung damage.
July 11, 20188 yr Hahaha, Das and I both zeroed in on the exhaust pipe flaring tool. There should be a couple of tapered end pieces and rod that matches the inside of the wedges. You slip it into the pipe, then expand the pipe enough to slip another one inside of it.
July 11, 20188 yr So it's not mine to keep but a friend has let me borrow this for the scout camp forging. It is a nice little anvil and really easy to lift about. I wondered if anyone might be able to hazard a guess on the make.
July 11, 20188 yr That is a nice little anvil. Wouldn't mind having that as a second. Might be a bit too small for dropping on a coyote, though.
July 12, 20188 yr Someone just offered me and old water tank. 10 ft by 3 ft diameter with 1/4 inch wall. Not sure what I would do with it. Ideas?
July 12, 20188 yr BigGunDoctor, Daswulf: that old thing was my biggest question mark. Makes sense though, the guy who owned it used to restore old cars. There were about thirty punches in that lot, the largest being 30” long and 1.5 inches diameter. A few of them were blacksmith made. I forgot to add the picture of the handled top fuller that I got as well. Being greedy I find myself mourning the fact that some blacksmith stuff must have slipped through the cracks...beside those two small anvils...
July 12, 20188 yr From a 3 ft. water tank, I see a fire pit from one end decorated with the plasma cutter and a side draft JABOD forge from the other.
July 12, 20188 yr 14 hours ago, JHCC said: That is a nice little anvil. Wouldn't mind having that as a second. I keep offering to buy it off him to help him clear some space in his workshop but he is determined to keep hold of it
July 12, 20188 yr A bosh is the water tank on a water-cooled tuyere. See my thread on the construction of my own forge.
July 12, 20188 yr BryanL, let's see, a 3'x10' water tank could become a catamaran if split down the middle lengthwise, a tall decorative fire pit with filigree up the stack, a really long BBQ, a smoker, feed trough, storage for bar stock, a bead blaster, cut into rings for decorations/paver molds, and a whole lot more.
July 12, 20188 yr You could do a pretty good BBQ fundraiser with a 3' x 20' pit. And the 10' sections would make it easy to transport.
July 13, 20188 yr Lou, "If you see something odd and can ID it for me feel free to do so." Looks like a couple body hammers in your pile. That blue and yellow chuncks of steel in the 3rd pic. Used to knock out dents and form body panels on cars. I have always heard them called hammers but they are more like an anvil. Hold one on 1 side on of the panel then beat the other side with a hammer. People who know how to use them are usually the same peole who still "lead" a panel on. I am jealous of the old masonry drills. Grandpa taught me how to use one many years ago.
July 13, 20188 yr 1 hour ago, BillyBones said: always heard them called hammers We usually call them a dolly.
July 13, 20188 yr Blue one looks like a dolly. The yellow/greenish one looks different from any i have seen tho i Do have a block like it with less pitch. Not sure on that. It could be used as a dolly on tight corners but again it's not like any i have seen.
July 13, 20188 yr Thanks guys, I was wondering about that as well. It sure looked to me like an anvil with a hand grip and I couldn’t figure it out. My cousin is a body man who still holds the secrets of leading in bodywork. He uses no bondo. I’ll have to give it to him. Plus, he’s the guy who gets me as many armored car leaf springs as I desire. I owe him more than an old tool.
July 13, 20188 yr So I went down to the scrap yard and traded in an old radiator from the house for the same weight in scrap. The spring is 20mm and the biggest piece is 35mm, so I am pretty happy and whilst I was there I also saw what might be the start of a treadle hammer build but didnt have my wallet so will have to go back on Monday and see if it is all still there.
July 14, 20188 yr Zeroclick, have no idea whatsoever for brand, but it sure looks old to me. It guessing it’s native to your area, it resembles the Yorkshire pattern anvils I’ve seen, but I’ve also seen some old French and German anvils that were similar (early 1800’s). Whatever it is it is really cool and I’d be happy to use it!
