July 27, 20214 yr Can anyone recommend some drill bits that can cut through hard steel like 1095 1/8 inch thick? I am struggling to make some holes for the pins I want to put in my knife handle. I use a fairly powerfully hand drill and I’ve easily made holes in mild steel and rebar, but I’ve recently tried working with better quality steel like 1095 but have had no luck with the bits I have or have bought. I always start with the smaller bits and work my way up to a 5/16 diameter drill bit but I can’t get the bigger bits to drill through the metal. any suggestions or help is appreciated. Thanks btw this is the last set of bits I bought moolo Hex Shank Drill Bit Set (16 Pcs), Premium 4341 HSS Titanium Impact Hex Drill Bits for Wood, Steel, Metal, Plastic, Quick Change Design (1/16”-3/8”) Edited July 27, 20214 yr by MageDK I added more detailed information
July 27, 20214 yr Author I haven’t hardened it yet. Just did some basic forging and grinding to get the general shape.
July 27, 20214 yr Author The steel I bought was 1095 Hot Rolled Carbon Steel 1/8" x 2", 12" bar, Knife Making Stock, Billet im not familiar with all the terminology yet but does hot rolled mean it was hardened already?
July 27, 20214 yr You might try using a torch to heat just the spots you want to drill to a dull red and toss it in some sand to let it cool slowly. That's a low tech means of annealing.
July 28, 20214 yr 1095 can hardened as you worked it if you were not real careful of temps. For hardened steel I have used a solid carbide bit; expensive and *delicate* and not the first choice!
August 5, 20214 yr Sometimes drilling thin stock is a pain. Even mild steel can work harden when drilling. Heres a few suggestions. Drill a single pilot hole, then go to your final bit. Make sure the pilot hole is a little bigger than the flat on your final bit. Ease up on the downward pressure. Too much creates heat and this will cause your work to harden. use cutting fluid or even water when drilling small pieces. Apply the fluid before you start to drill. Otherwise it may harden your work when drilling. If it hardens, anneal as was stated above.
August 5, 20214 yr Author I did try annealing it and that helped a little. I was able to get a little further with the drilling, but then it hardened up again. I was able to work the hole a little larger with a small file. I am trying a few different options of cutting oils and lubricants on some scrap pieces to help ease the heat while drilling.
August 5, 20214 yr Bosch M42 Cobalt drill bits will go through annealed/hot rolled/normalized 1095 with ease. I'm sure there are other brands that would do the same, but I've used these so I'm willing to recommend them.
August 5, 20214 yr Also, if you are using the same bits you used before annealing, they may need re-sharpening.
August 6, 20214 yr Although the "obvious" thing to do is to look for "better"/harder drill bits, the problem is not usually with the drill bit, but with the rest of the setup, In My (limited) Experience. Very few handheld drills run slowly enough for drilling hard steels. The hardness problem is not usually "just" the hardness of the steel that is about to be drilled. Work-hardening often enters into the equation as well.
August 6, 20214 yr When you look up the feeds and speeds for drilling, there are both values, feed and speed, given. "We" can usually take the speed with a pinch of salt and run a lot slower, as the values are given for production scenarios in which time is money. It is certainly unwise to run faster. The feed is important for work-hardening materials. Each pass of the cutting edge does work as it cuts and leaves a thin work-hardened layer on the workpiece. If the feed is correct, the next pass of the cutting edge will get below this thin work-hardened layer and cut the un-work-hardened material beneath. Turning slow and feeding hard with a drill-press is the best approach for most of us. Using a hand-held drill, it can be hard to maintain enough pressure to get the feed necessary. If the drill stops cutting, even momentarily, it will skate on the previously-cut surface with the feed pressure spread over a tiny area at, and just behind, the cutting edge. This high-pressure contact will cause further work-hardening and the problem will swiftly escalate. Many of us are impatient, bloody-minded types and will persist in trying to drill after the drill stops cutting. If you have no option but to use a hand-held drill, use the slowest speed you can, watch the swarf and IMMEDIATELY stop if the drill stops cutting. Either sharpen the drill (a skill that is well worth acquiring) or replace it with a new one, then start again. IME, the only "better"/harder drills that work well in a handheld drill are TCT drills intended for use on Stainless Steels (which work-harden very readily) or Hard Plate (here in the UK, I've bought them from locksmiths when I've run into the problem when out on sites, but they really know how to charge). Cobalt drills do work a little better than vanilla HSS, but they also tend to be more brittle. The improvement is significant in a rigid setup, but there is a high probability you'll just break them in a handheld drill. Solid Carbide is even worse for breaking when used in a handheld drill (though truly superb in a rigid setup). The TCT ones have the hard tip, but a tough shank and flutes, so are a good choice in a handheld drill.
August 7, 20214 yr Keep an eye out for a deal on a drill press. More often than not trying to drill steel with a handheld drill ended in frustration and an unfinished hole for me. Pnut
August 7, 20214 yr Not only for a drill press but one that goes slow enough for drilling steel! I've seen a bunch good for drilling wood that don't step down enough for doing a good job on steel.
August 10, 20214 yr Any good drill will work for cutting 1095, a quality drill not the ones you find for $5 a package. Heat is your enemy. You need to drive the drill slow enough so that the drill does not over heat and loose temper. This will cuase dulling, but must move fast enough to cut the metal and get the chip out. If the metal overheats it will work harden. The goal is to keep the heat in the chip and get it away for your work. So the cut will have to be deep enough for the chip to be big enough to hold that heat. Most likely, like others have said, a hand drill is to fast. You are needing about 50 feet per minute feed rate. That will translate to around 600 rpms on the drill. Also a drill press is much prefered becuase you can keep constant pressure and alignment of the cutting edge of the drill. There are fromulas out there to help you figure these things out. Easily available on line. I just inputed "speed and feeds for 1095 steel" and got a whole table of feed rates for all types of steel. RPM = (12 x feed rate) (50 in this case) / (3.14 (pi) x diameter of drill) (5/16, .313" in this case) 12 x 50 = 600 3.14 x .313 = . 928" 600 / .928 = 646.5
August 10, 20214 yr All good points mentioned earlier. I would like to add two things: 1. Watch for even chip formation from both cutting edges - if not a sign of one edge dull. 2. Listen to the sound of the drilling action- if it does not sound right e.g. high pitch screeching, crunching etc.- stop and check the cutting edges.
October 17, 20223 yr Author I could, but I am no where near good enough to make a nice perfect circle like a drill bit would leave.
October 18, 20223 yr Recommend a tempering pass at around 1200 deg. F (up to just barely glowing in a dark room) before attempting to drill. Let it cool to touch before drilling to avoid ruining the temper on your drill bits. If you can put in an insulated container afterwards that will help also (wood ash, vermiculite, even a gas forge that is turned off and cooling overnight - not sand)... This will soften the tang and allow easy drilling. As previously mentioned, learning how to sharpen these bits without destroying their temper makes a huge difference as well. Cheap bits lose their edge quickly.
October 18, 20223 yr Why didn't you drill the pin holes BEFORE heat treating the blade? I've been sharpening drill bits and lathe tools since I was maybe 8-9 YRO, Dad insisted I learn but I use a Drill Doctor I picked up at a yard sale 30-40 years ago. The bits are sharper, cleaner and at the ideal angle. I was good at sharpening bits but nobody's perfect and I didn't have a 1,000 grit grinding stone. It is harder and takes longer to learn to drill holes properly than it does to learn to sharpen the bits. That is in large part how I got good at it so young. Anneal the blade, drill your holes THEN harden and temper. Buy a Drill Doctor ad your drill bits will cut correctly until the flutes are gone on the stubs. When you drill the holes use LOW RPM and modest down pressure. Listen to the bit on steel it will tell you what is happening once you learn he language. If the bit jams, do NOT pull it out of the hole! Turn the motor off while holding the bit down so it can NOT turn in the hole. Once the drill has stopped hand turn the chuck backwards to back the bit out of the burrs that have it jammed. Eyeball the bit for rolled edges on the faces. If there's no damage oil the hole and SLOWLY advance the bit until you HEAR it ticking against the burrs you raised and advance the bit VERY SLOWLY until it's running smoothly. Pull the bit out to make sure it hasn't over heated then continue drilling the hole. Breaking through sheet metal wants to snag the bit every time but you can hear it starting to, lower the feed pressure and all but wear through the last little bit. Drilling holes correctly is a craft of it's own and well worth learning the basics. Frosty The Lucky.
