May 27, 20188 yr Hi, we recently purchased an anvil and the markings on the side are hard to distinguish. We have worked out the word "warranted" and we think the word "tredin" underneath it... Can anyone enlighten us further?? TIA
May 27, 20188 yr More pictures and where in the world it's located, would go a long way in helping to identify it.
May 27, 20188 yr Hey Brenda, I have met the name "tredin" before but I couldn't remember where. Might be my first anvil. I don't remember because I haven't seen it for 15 years. Where id you buy it?
May 27, 20188 yr Author We purchased it off a buy/swap/sell site here in Australia. It has hundred weight markings on it also. I've googled "tredin" and found nothing so far... Will post more photos shortly
May 27, 20188 yr Ms. Murray, Welcome to the site. I suggest that you modify your profile and place your location in it. That information will result in far more relevant responses to your questions. Australia is vast and there are numerous members from there in I.F.I. There may be several residing nearby. There are other female members here too. Again welcome. SLAG.
May 27, 20188 yr No apologies are necessary. The site takes a little bit of time to learn to navigate and figure out the peculiarities. Like the search engine is poor. So use your favorite one and also put 'iforgeiron" into the search phrase. (for google or another). Also, if you want to go to another page in a particular thread hit the refresh button and the page will then come up. If not the page does not appear. Also, check for a thread that lists all/many Australian members. Dale Russell tends that thread, somewhere on this site. Another member will probably post to guide you to where it is, here Regards, SLAG. Just checked out your co-ordinates. Never met anyone from Bendigo., before. But Melbourne is a different story. Cheers.
May 27, 20188 yr Welcome aboard Brenda, glad to have you. Nothing to be sorry about there's a learning curve to using Iforge and things change occasionally without warning so the learning curve never ends. Being asked to include a general location is probably the most common request made of new folk. Ah, and another peculiarity of IFI just occurred, slag and I are typing a reply to the same thread at the same time. If you think of this place as a giant cocktail party of characters with one similar interest and someone with every other interest on earth present you'll be close. Oh, can't help with the anvil's identity but I'd sure like a look at it from a little distance so I can see it's condition and profile. Frosty The Lucky.
May 27, 20188 yr Hey Brenda, welcome to IFI. There are a few of us Australians on here. I'm a few days drive north of you. You're not too far away from Bendigo and I have been there a couple of times for the annual swap meet. A few anvils for sale but all overpriced. If you go to the Everything Else thread and scroll down to Oz Roll Call, you can meet up with a few of us there and perhaps add your details. https://www.iforgeiron.com/topic/7176-oz-roll-call/
May 28, 20188 yr Author Thank you everyone! Navigating the site on an iPhone is not ideal. I'll fire up the computer and familiarise ourselves with the site. Needs a good clean up, job for this week
May 28, 20188 yr Looks like a Wilkinson to me with the fat throat at the horn and thick waist. But they have a little more sweep under the heal.
May 28, 20188 yr Author Thank you for that! If it is a Wilkinson, will there be any identifying marks to look out for?
May 28, 20188 yr You are going to think that we are a bunch of anvil weirdos, (and you will be right) but we need pix of the areas under the horn, under the heel, and the very bottom surface for a better chance of a definitive ID. There are also marks frequently found on the front and back surfaces of the base. A pronounced "keel" on the bottom of the horn usually indicates a Sheffield, England origin, most notably Mousehole or one of it's numerous spin-offs or competitors. Re-labeling was not unknown, either.
May 28, 20188 yr It definitely looks to be a Mousehole-type, even if not from that specific factory. If the rebound is good, you should be in good shape. Couple of tips for photographing markings and other details: low-angle light will cast shadows over dips and valleys and show any marking more clearly. You can also give it a dusting with talcum powder or flour to bring out numbers or lettering.
May 28, 20188 yr welcome aboard.. lovely shop it looks like.. i saw a barbie, but no forge.. ???????? Love the heavy work table.. I belive the top part in the first picture is "Warranted"
May 28, 20188 yr One of the issues is that there were hundreds of anvil makers in England over the years and many of them make anvils that look quite similar---generally because they learned the craft working in one of the major manufacturers like Mousehole or Peter Wright and then went out to start up their own businesses and tended to make anvils similar to what they learned on... CWT weight stamping is a sound indication of English pedigree as as far as I know; no other location weight stamped using that system.
May 29, 20188 yr Author Thank you everyone! Please excuse my photographer, it ain't my strong suite. We tried the tracing over it with charcoal and paper, tracing over it, you name it. I'm pretty confident it says WARRANTED with "TREDIN" underneath. Yes we do have forges, a gas and a coal one. Here are updated photos, after a bit of a cleanup.
May 29, 20188 yr No more abrasives on the anvil please, hot iron will lift the rust just fine with out artificially wearing the anvil. And the lady above (JLP services, aka Jennifer) if an inspiring smith so if any one gets snarky about a lady in the smithy look up some of her vidioes and tell the “boys” to set down.
May 29, 20188 yr Note that Medieval Blacksmithing Guild regulations state that a woman is only allowed to work in the smithy of their Father, Husband or Brother---so it was happening enough they felt a regulation was needed!
May 29, 20188 yr I imagine truth be told it was the husband or brother being allowed to work in the wife’s or siste’s smithy. Lol
May 29, 20188 yr A typical method for a Journeyman to get the capital to have his own shop was to wed the widow of the previous Master it they were without kids.
