December 5, 20169 yr Here are a few pics of a knife I just finished up for an old friend. It is a 44-layer ladder pattern made from 1095 and 15N20. The guard and frame are nickle silver and the scales are Sambar stag. It is loosely patterned after the knives made by Wostenholm & Sons in the 1850s. This is my first ladder attempt, and as all such things it was quite a learning experience.
December 5, 20169 yr Lovely, clean work. Ladder pattern is really nice, particularly in the clip, and I really like the raised head rivets and framed handle. I'm sure your friend will be thrilled. I certainly would be.
December 5, 20169 yr Author 36 minutes ago, Steve Sells said: tight and even patterning that's the key, you nailed it Yeah, I took a page from JPH's book on the grooving, and it just worked. I did the grove and smash version since I had access to a mill, but no press. However, the deep slots I cut left me with some cold-shuts at the interfaces to the grooves. Next time I'll try the "Squish and grind" approach. Here is the slotted billet: And after forging flat: There were still a few small cold-shuts/inclusions that I couldn't get completely ground out. Next time, if I mill the slots, I won't go so far past the radius of the ball nose cutter in depth. Those deep vertical slots got me in trouble.
December 5, 20169 yr no need to go any deeper than after the radius is cut, meaning the straight sides form going this deep were just wasting metal.. but a great first.
December 5, 20169 yr Author 1 hour ago, Steve Sells said: no need to go any deeper than after the radius is cut, meaning the straight sides form going this deep were just wasting metal.. but a great first. Thanks, I'll keep that in mind next time. It's an addictive pattern, so there will be a next time
December 5, 20169 yr very good work. i don't like to criticize my betters but even if i did i couldn't find anything to criticize.
December 5, 20169 yr Author Lol, well thanks my friend, but I'm not your better, and there is plenty to criticize. I'll never make a perfect knife, but hopefully I'll keep trying until I am no more.
December 8, 20169 yr Hope no one minds.. Those are not cold shuts..they are cold laps caused by the peining of the "tops" when you flattened..you should not of cut down that deep... HOWEVER there is a way to cut down that deep and that is to chamfer the "tops" a bit to compensate for the peining effect. That is what I do when I cut down past the radius.. This way you don't get the lap-overs that can be a PITA,,, Also..flatten at a welding heat..makes things a bunch easier if you ask me... Hope this helps.. JPH
December 8, 20169 yr Getting tips from an expert is never a bad thing! With my geology background I would have said, "make the notches like river valleys rather than glacial ones", (V rather than U)
December 9, 20169 yr I'm really impressed with how consistent the pattern is side to side. Looks amazing to me. I'm a fan of the handle too.
December 9, 20169 yr rhitee93....are you going to the IBA meeting in the morning near Stilesville? If so, bring bring that along for the display table. I would love to see it in person. Thanks Dave
December 9, 20169 yr Author Thanks again all. JPH, I understand exactly what you are saying. I like candy, so lets say it could have looked like two kit-kat bars back to back It wasn't until I got into this project that I appreciated how many variables are at play with a ladder pattern. I based my groove depth and spacing on info in one of your books, but scaled it a bit to fit a ball-end cutter I already had. Afterwards I realized that the desired spine width, the parent billet thickness, and the depth of cut are all locked into a relationship with each other. Dave, Sadly, no, I won't be there. I still have two seniors in high school, and lots of kid events to go to on the weekends. They'll be off at school next year, and I am thinking I may have more time for dad events
December 9, 20169 yr No problem...I just had my hopes up for a bit... Dave 3 hours ago, rhitee93 said: Dave, Sadly, no, I won't be there.
