brynnb Posted September 16, 2011 Share Posted September 16, 2011 Some people have mentioned putting a layer of paint on their anvils, but I think I'd rather have whatever protection I put on there be clear so the actual metal is showing. Anyone got some suggestions on what I can put on there to keep it from rusting? It doesn't seem like a regular clear coat would really work. Link to comment Share on other sites More sharing options...
pkrankow Posted September 16, 2011 Share Posted September 16, 2011 I use wax. I mixed up a concoction that is popular as a finish, and use it. 1 part wax (bee's recommended, I used paraffin. 1 part turpentine 1/2 to 1 part linseed oil Using a double boiler, melt the wax, then take it all outside. The heated water is enough heat to finish. Add turpentine and linseed oil, mix well, transfer to a heat resistant can like a clean metal paint can. Cover and let cool. Forms a paste product that can be used on hot or cold metal, wood and other materials. Apply, let dry and buff. Use in a well ventilated space. I find that the metal of the anvil will slowly brown through the wax, but does not form rust that will transfer to clothing. Phil Link to comment Share on other sites More sharing options...
bajajoaquin Posted September 16, 2011 Share Posted September 16, 2011 Most don't bother. Working on it will keep the face and horn free from rust. The body of mine is coated with wax, that was used by the previous owner to highlight the markings for sale. Others have mentioned ATF. None of the anvils at Vista Forge are coated, and they're just fine. But if you want to coat, I'd say wax or ATF. Link to comment Share on other sites More sharing options...
Glenn Posted September 16, 2011 Share Posted September 16, 2011 Clear paint? (grin) The best option to keep a anvil in good condition is working hot iron on the anvil on a regular basis. Link to comment Share on other sites More sharing options...
njanvilman Posted September 16, 2011 Share Posted September 16, 2011 Boiled linseed oil on the body. Lots of use on the top. Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 16, 2011 Share Posted September 16, 2011 I've never used anything during the last 30 years living in OK, AR, OH, NM and with a number of anvils. Not even on the loaner anvil that was left outside in OH. Link to comment Share on other sites More sharing options...
Old N Rusty Posted September 17, 2011 Share Posted September 17, 2011 I like old n rusty things the face of my anvil stays shiney from use the rest can ...rust. Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted September 17, 2011 Share Posted September 17, 2011 Sweat seems to keep it from rusting! In a round-about sort of way. Link to comment Share on other sites More sharing options...
dimenickel Posted September 17, 2011 Share Posted September 17, 2011 whatcha wanna do is get out the buffin wheel and green compound... buff buff buff till that sucker shines like a new chrome bumper...... that'll stop the rust... it'll be hard to stare at it it'll be hard to work on it an eventually you'll develop an appreciation for a rusty anvil that was easy to look at and ya got alot of work done on it just teasin Link to comment Share on other sites More sharing options...
David Einhorn Posted September 17, 2011 Share Posted September 17, 2011 In the winter I slather car wax on stuff, especially woodworking tools. Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted September 17, 2011 Share Posted September 17, 2011 All of my anvils are outside, and have a patina now. Of course living in the desert where we get 4.5" of rain a year tends to keep things from rusting bad. Link to comment Share on other sites More sharing options...
cvmikeray Posted September 17, 2011 Share Posted September 17, 2011 Get a burlap bag to cover it when not using it. You could put the paste from above on the bag, or oil the bag.http://www.tractorsupply.com/burlap-bag-6807646 Link to comment Share on other sites More sharing options...
Brasilikilt Posted September 20, 2011 Share Posted September 20, 2011 I have a little can full of axle grease and motor oil. I chuck up a little wire brush in my drill and stick it in the can while spinning. I clean the anvil with the wire brush and add a protective layer that gets in all the nooks and crannies, all in one lazy step. I also do this to my post vise. An old anvil usually has a wrought iron body. Wrought Iron doesn't rust as easily as modern mild steel, and this works in my favor. I've only had to do this to my anvil a couple times, and it is stored outside in rainy NW Oregon. Link to comment Share on other sites More sharing options...
Altusjg Posted September 21, 2011 Share Posted September 21, 2011 I wire brush off any excess rust from the base and sides of my RR anvil and leg vise then spray a heavy coat of WD40 and leave it. After it dries it seems to leave a nice oily film that prevents them from rusting. I wipe off the working surfaces well as not to transfer oil to all my work. I do this once a month or so depending on how humid its been or if they've gotten rained on, ect... It does the trick for me and both have a nice patina. Link to comment Share on other sites More sharing options...
philip in china Posted September 23, 2011 Share Posted September 23, 2011 Most of my anvils are painted on the sides. If I have to leave them for any time I put the thinnest coat of grease on the face. I think the big one is currently unpainted so is probably greased as it isn't rusting. Really unless it is very humid, as ir is here, just don't worry. To hijack the thread a bit I have seen the tip of the horn of an anvil painted a bright colour so as to avoid walking into it. What does anybody think?? Impaling the sciatic nerve on a pointed bit of tool steel can be a stimulating experience! Link to comment Share on other sites More sharing options...
Arbalist Posted September 25, 2011 Share Posted September 25, 2011 I painted mine with metal paint in "graphite grey". Link to comment Share on other sites More sharing options...
philip in china Posted September 25, 2011 Share Posted September 25, 2011 A colour coordinated anvil! Grey would be no good for mine. It would clash with my apron. Link to comment Share on other sites More sharing options...
charadam Posted September 25, 2011 Share Posted September 25, 2011 This is by way of an explanation to the blacksmith professionals and is meant to reflect reality. I use my anvil 2 or 3 times a month. My anvil sits out-of-doors in all weathers. I do not make my living on my anvil. I do like to preserve my anvil when it is not in use. So I coat the working surface with wax polish. I use satire, exaggeration and sarcasm to stop me feeling guilt about being a smithing hobbyist. And a hypothetical Brown Bess flintlock musket to keep the purists at bay. If I have offended you, I ask that you consider why. But what, exactly, is your problem with people who probably would love to beat their anvil into shining, but cannot, owing to real life pressures? Link to comment Share on other sites More sharing options...
ichudov Posted September 29, 2011 Share Posted September 29, 2011 Spray it with numerous available outdoor rated oily sprays, such as LPS-3 or any other alternative. I do it every 4-6 months and I have zero rust on the anvil that I keep outside in Illinois. Link to comment Share on other sites More sharing options...
Bigred1o1 Posted September 29, 2011 Share Posted September 29, 2011 i do most my my work out in our barn or in the attached shop and its quite humid in there i have had very good luck with butchers wax it looks good and seems to keep the rust off if i know i am not going to be doing much smithing work i pop open the tin and put a thin coat on the face and horn and i have had no problems with rust Link to comment Share on other sites More sharing options...
Dragons lair Posted October 11, 2011 Share Posted October 11, 2011 Ok here it is one more time. ya want patina(RUST) I can't help ya. Ya want it to look like a new 100 yr old anvil(mine do) I use the same stove black (polish) I use on Ya guessed it on my wood stove. Slather it on and buff. No rust just a nice old lookin black body with a shinney face. makes the old wood burner look like new also. Use it on sides of hammer heads also. My grampaw taught rust is rust NOT patina. OK pop I finally hear ya(45yrs too late) Ken Link to comment Share on other sites More sharing options...
Frank Turley Posted October 11, 2011 Share Posted October 11, 2011 "The old, rusty anvil laughs at many a worn out hammer." Link to comment Share on other sites More sharing options...
nonjic Posted October 13, 2011 Share Posted October 13, 2011 Ive recently taken to wire brushing them with an angle grinder to get the worst of the flakey stuff off, I then 'ensis' them, this is an anti-rust we use at work, it seems to be a wax in a solvent. When this is painted over the remaining rust it goes a lovely 'leathery' brown. I have also done a couple recently with graphite stove polish, which buffs to a lovely deep dark grey luster. My 'user' is painted with a very thin coat of black gloss, and gets a wipe of oil on the face and horn every now and then. Link to comment Share on other sites More sharing options...
Please sign in to comment
