November 22, 20196 yr Burgie, you did a very nice job on that stand. it is a beauty for sure and should be proud of the work.
November 22, 20196 yr burgie, very nice stand. I'm right handed and I use mine with the horn pointed to the right. As has been mentioned, it's really your preference. I move around if I need to. You may even sit it up on end and use the shapes in the waist, feet etc.! As Glenn says, you bought the whole anvil, so you may as well use it Welcome to the forum
November 24, 20196 yr I finally had time to get my anvil mounted on a stump I placed in the ground a couple weeks ago. Very excited to start using it!
November 28, 20196 yr Okay, I'll play! 60 lb swage/block anvil from GS Tongs, Hi, Glen. The anvil still rocks. 200 lb Fisher found in Western, MI.
November 28, 20196 yr 23 minutes ago, greenskpr said: The anvil still rocks. Maybe you should fasten it more securely?
November 28, 20196 yr Yup and that card board stand looks a little flimsy or that is a super light anvil. Are you sure this is even on earth? I think those white things are breathing helmets.
November 28, 20196 yr 7 minutes ago, jlpservicesinc said: Yup and that card board stand looks a little flimsy or that is a super light anvil. Are you sure this is even on earth? I think those white things are breathing helmets. lol. Blacksmith Magician!
November 28, 20196 yr 49 minutes ago, jlpservicesinc said: Yup and that card board stand looks a little flimsy or that is a super light anvil. Are you sure this is even on earth? I think those white things are breathing helmets. Milk crates are stronger than cardboard, but only just ... Interesting how the anvil has offset anchoring lugs. And just in passing ... if you had your anvil on milk crates and worked on it like that, do you think the milk crate would collapse?
November 28, 20196 yr Marc1 nearly all the Eagle (Fisher Norris) anvils I have seen the lugs are offset. I've only seen 1 that was not offset and it was tiny. I had tried steel milk crates back in the 80's. The heaviest I could find.. and they didn't last. The spot welds broke along where the feet were resting.
November 29, 20196 yr I believe you ... only I have never seen a Fisher anvil in the flesh. The question was tongue in cheek, of course eventually the crates will give in after flexing one time too many. . I was hoping for a smart answer like ... the hammer blow is absorbed by the anvil so the base does not contribute to the system ... or words to that effect.
December 2, 20196 yr LOL. I get it. 20F here right now. Even in the shop, so a few smacks and lower anvil for sure.
December 3, 20196 yr Gday guys, new around here and hoping to be doing some forging soon. Thought I'd share some pics of the "anvil" i built. I was going for the Brian Brazeal style die anvil in scrap mild steel. The steel is 160lbs, it is welded to a 20lb plate, bolted to about 10 feet of 4x4 doug fir and surrounded by 4 slabs of about 1.5 inch pine, 2.5 inch angle iron and about 60lbs of sand. In total it comes in somewhere around 300lbs.
December 3, 20196 yr That is perfect.. That is going to be a wonderful platform for forging on. Can't wait to hear about how you like it.
December 4, 20196 yr That's a piece of art, lchaloner. Seems very specifically suited and functional.
December 6, 20196 yr Thank you very much. I really hope its functional since i have no idea what im doing and havn't hit it yet. Appreciate your kind words mate.
December 6, 20196 yr You should include a sound file to hear the sound of that fantastic improvised anvil. make sure you hit only hot steel on it
December 6, 20196 yr Thanks mate. Its got a pretty dull thud, had to try it, so yeah it has a couple of dings in the top now, i'll learn. When its really banged up some more ill get the grinder out again the neighbours love it. I did make a video while i was building it but im pretty sure i cant post links here. If anyone wants to hear a rough accent while watching bad cinematography and someone who doesnt know what theyre doing let me know and ill pm you a link.
December 6, 20196 yr Your description of rough accent and bad cinematography is right up my alley.. I love both of those if it's an interesting concept or action.
December 6, 20196 yr You can post a link to it here, as long as it doesn't contain commercial content.
December 6, 20196 yr More precisely, as long as it doesn’t contain material that would violate the TOS if it were posted in the forum.
