Lefse Posted May 22, 2018 Share Posted May 22, 2018 ^nice anvils I'm jealous! Here is one of mine being put to good use Quote Link to comment Share on other sites More sharing options...
jlblohm Posted May 24, 2018 Share Posted May 24, 2018 Picked this Fisher sawers anvil up at auction for $21. They had it listed as a horse anchor. I will get it cleaned up and better pictures. I know...my truck is a mess. Im using my Suburban to haul wood for making charcoal so it is what it is. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted May 24, 2018 Share Posted May 24, 2018 jlblohm Way to go.. That is excellent.. How much does it weigh? Quote Link to comment Share on other sites More sharing options...
Frozenforge Posted May 24, 2018 Share Posted May 24, 2018 Has a handle on it and it looks to be about 100lbs. Nice score .....21$!! Thats just crazy. Quote Link to comment Share on other sites More sharing options...
jlblohm Posted May 24, 2018 Share Posted May 24, 2018 I havent put it on a scale but the listing said 80lbs and it has to be close to that maybe a little heavier. It has a date but the first and third numbers are corroded away but it is 18?6 Quote Link to comment Share on other sites More sharing options...
Pyrostic Posted June 8, 2018 Share Posted June 8, 2018 Just picked up my first anvil. 190 pound Hay Budden. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 8, 2018 Share Posted June 8, 2018 Looks to be a farrier's model though someone has truncated the side clip. I hope you can slap some hot steel on it this weekend! Quote Link to comment Share on other sites More sharing options...
JHCC Posted June 8, 2018 Share Posted June 8, 2018 13 minutes ago, Pyrostic said: Just picked up my first anvil Welcome to IFI, Pyrostic! If you haven't yet, please READ THIS FIRST!!! Quote Link to comment Share on other sites More sharing options...
C-1ToolSteel Posted June 8, 2018 Share Posted June 8, 2018 Nice anvil! Sad, though, that it appears that someone welded on the edges to make them nice and sharp... Probably the same guy that Cut the clip off. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted June 8, 2018 Share Posted June 8, 2018 We have a 108 pound farriers Hay Budden and love it. Hope you have read about not grinding or milling the hard face (other than slight radius of the sharp edges). A wire wheel and hot steel is all it needs otherwise. How is the ring and rebound? Quote Link to comment Share on other sites More sharing options...
Pyrostic Posted June 16, 2018 Share Posted June 16, 2018 The rebound and ring is fantastic on it! As far as I can tell, I don't think it had any welding done. If it did I can't tell through rebound or anything. Thanks for comments guys! Quote Link to comment Share on other sites More sharing options...
stevomiller Posted June 23, 2018 Share Posted June 23, 2018 On 10/7/2017 at 7:15 PM, Tom's Metal Shop said: I can't find much about it or the company that maid it except that Gardiner MFG co. was founded in 1944. So I know it's no older than 73 years old. If anyone knows anything about it, I would love to know if it was a good find. I have this anvils brother or cousin. I bought mine from an old farmer about 20 miles from where it was made, but know very little as well about it. I did speak to old man Edwards at Edwards Heat Treating in Oakland, he remembered the company and had done some work for them way back. My anvil is in storage now, but I think the markings are identical. The stamped number on mine appeared to be 25460, perhaps the last digit was a C. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted June 23, 2018 Share Posted June 23, 2018 I vaguely remember reading or seeing something about this company in the way, way back.. IIRC They were war time anvils.. I could be totally off my rocker but that is what comes to mind today.. Quote Link to comment Share on other sites More sharing options...
stevomiller Posted July 1, 2018 Share Posted July 1, 2018 Remarkably good small Chinese anvil I picked up for my techs at work to use. I bought it on Ebay for $145 shipped, fully expecting it to be cast iron or low carbon steel, but figuring it would suffice for their usage. It’s an Italian/French pattern, 30kg or 66lbs, 3/4”~ hardy hole opposite the round horn. I usd flap discs on my disc grinder to clean up the horn casting, which was quite orange peely, but the flat face came ground smooth. I originally grabbed a new Johnson USA file to break/radius the edges, only to be met with a screech and now buggered file, hrumppff. Back to flap discs to put an 1/8” radius on most of it, and a greater 1/4” for the first 3.5” on either side nearest the round horn.I don’t have any large bearings to test rebound, but when lightly struck with a small hammer over the sweet spot it will throw it back at you. Both horns ring like the bells of Hades. Long story short, I am NOT submitting an expense report for this purchase because it is coming home to live in my shop to keep my other tools company! For what it’s worth, I’ve had three Chinese steel anvils, as well as an American anvil. I’ve gotten lucky, one 110lb north German pattern was a good casting and harder than wood pecker lips just like this little guy. Second 110lb was a little less, but still a consistent low 50’s on the full face. A friend got same model, complete dog. Either luck of the draw on the alloy they happened to pour that day, or haphazard heat treatment. However, on a good note none of them was porous, again lucky. One of the 110lb went to my dads property, the other to a custom black powder rifle building friend of mine. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 3, 2018 Share Posted July 3, 2018 looks like it needs a "lambs tongue" hardy tool... Quote Link to comment Share on other sites More sharing options...
Joshua Vanier Posted July 3, 2018 Share Posted July 3, 2018 My new 153 pound anvil. I paid 370. I can't find any markings on it at all. Face is in extremely good condition, as if it was never used or was reserfaced. It has a larger radius ground in near the cutting table on both sides. The base looks old, with painted over rust but the face looks new. It seems to have decent bounce with (i don't have a good ball baring to test it with), but does not have a very high pitched ring. Anyone able to help me with ID? Should I be worried about the not so high pitched ring? What do you guys think of the price? I was using the anvil shaped object I made in the third picture for a couple of years. This actual worked quite well for me. New anvil has much better rebound than this as expected Quote Link to comment Share on other sites More sharing options...
Latticino Posted July 3, 2018 Share Posted July 3, 2018 1 hour ago, Joshua Vanier said: Anyone able to help me with ID Lugs on the feet and general configuration look like Fisher to me , but I'm no expert. What does the other side look like? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 3, 2018 Share Posted July 3, 2018 Fishers don't ring they "thwap"! So if we can nail it down to that---you did EXTREMELY well! Fishers are the highest grade of non-ringing anvils and make great shop anvils. Quote Link to comment Share on other sites More sharing options...
Joshua Vanier Posted July 3, 2018 Share Posted July 3, 2018 Wow cool, I'll look up Fisher anvils to learn more. Thanks guys! Pic of other side below. Do you think there could have been mark in the area where the paint is more worn away? Strange that there are no markings! Quote Link to comment Share on other sites More sharing options...
Latticino Posted July 3, 2018 Share Posted July 3, 2018 Shape of the ground away area also reads Fisher to me (right edge looks like a Fisher eagle). There is a Fisher expert on the forum, I'm sure he will chime in if asked. Any numbers on the feet? I think some Fishers have the weight cast there. Quote Link to comment Share on other sites More sharing options...
Joshua Vanier Posted July 3, 2018 Share Posted July 3, 2018 No, there are no numbers on feet. I have checked very carefully. Even looked on the bottom. I think your on to something with the ground away eagle. I'm sitting here comparing it with another picture with the fisher eagle and I agree. the upper right area looks like the top of the wing and head. I wonder if someone wanted a flat surface there and that is why they ground it off. Any idea who that Fisher expert is? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 3, 2018 Share Posted July 3, 2018 www.iforgeiron.com/profile/10347-njanvilman/ He is the Fisher & Norris Factory Museum Curator Quote Link to comment Share on other sites More sharing options...
Joshua Vanier Posted July 4, 2018 Share Posted July 4, 2018 So njanvilman had a look at this and responded through PM saying that this is a 1950's era Fisher. The company was making unmarked anvils at this time for an unknown reason he says. Also, the area we think we can see the eagle he says could possibly have had a paper label. Thanks for the help everyone! I'm super happy with this outcome. Quote Link to comment Share on other sites More sharing options...
JHCC Posted July 4, 2018 Share Posted July 4, 2018 As you should be. Great anvil at a very decent price. Quote Link to comment Share on other sites More sharing options...
Chris Pariso Posted July 14, 2018 Share Posted July 14, 2018 My in-laws just won the birthday game... the top has definitely seen some use/abuse, but it beats the 50# chunk of cast iron I've been using. There are no markings that I could see about maker or weight, but it feels like it's at least 125#, if not more. Any thoughts on what make or type it might be? Quote Link to comment Share on other sites More sharing options...
