Show me your anvil
  • Replies 3.8k
  • Views 850.7k
Most Popular Posts
  • Not done yet but this was cut from 4" plate. Horn was roughed with a O/A torch the finished with a 7" zircon flap disc. Feet cut separate and will be severely welded ;)
  • This is a 80# piece of drop from cutting a hole in a steel plate. No one said an anvil has to have the standard anvil shape.
  • DocsMachine
    DocsMachine
    140-lb pre-1910 Peter Wright. Aged, badly abused, and severely chipped, but no cracks or large chunks broken off. Stand fabbed from scrap angle, strap iron and some fresh 1" square tubing. Two "cutout
Well I guess you won't get into trouble for trademark infringement---ACME anvils used to be sold in the Sears and Roebuck Catalog about 100 years ago...
Haha, if Warner Brothers hasn't been sued in the 70 years they've been using it, I won't either :P Besides, it's not like I' m selling it.
I just need to figure out how to stick some coyote arms and legs out from under it in a non-flammable way...
Check out this thread. If scrapartoz can make sheep, I'm sure he can offer some tips on coyotes.
No but Warner brothers might sue you:D. Anyone starting a cafe and calling it Rick's American used to be sued. They also took on the Marx brothers on their Casablanca movie but realized that they would loose face. Groucho told them that they should not call themselves Warner BROTHERS since the Marx brothers were older.
Have a nice movie sorry I mean weekend
Göte
How about just a row of coyote outlines on the anvil for confirmed kills...
Ooh good one Thomas! A buggy eyed, tongue lolling, Coyote version of Killroy. Ooh I wonder if I can draw that well enough. Deb maybe.
Hahaha, that's hilarious, I might have to do that one... Thanks for the idea!
I've got to make a portable anvil stand for it... I was thinking of maybe forging some arms and legs too, that I could use to hang my hammers :P
Still not sure what I'm gonna do, but I'm sure I'm gonna do something!
When I got my second BS degree I had a Wile E Coyote "slapper" on my mortar board, little plush Wile under a plush anviloid and if you slapped it it gave the "whoosh....Booom!"  and then a couple of seconds later "Beep Beep"  For some reason I ran the battery out on that thing fairly fast...
Edited by ThomasPowers
Hello new to forums and have an anvil to show and might be for sale 170 lbs 28 inches long 4 1/2 wide 12 inches tall Thanks for any info
Well, the silhouette looks like a Haybudden to me... Is... the anvil bent? O_o or, is it a perspective illusion?
Other than that, it if IS a Haybudden, looks in pretty good shape.... Where ya from roughly? If you're in Minnesota, I'd certainly be interested :P
Hey guys there's no need to Quote a post and resend the pics already posted. Glenn has to pay for bandwidth lets give him a break. If you wish to make a specific point then cut all the other pics in the post except the one in reference.
Please.
Thanks for the info the photo makes it look bent.
I have seen Hay-Budden anvils with the face sloping downward toward the heel. What was the reason for it?
Finally got my anvil stand done.
I did set the anvil on another already ash filled container to testforge and i am really happy with her.
ambossgstey.thumb.jpg.4af690056fc16f95f5
Now i only need to collect 80liters of fine ash. I'm not in a hurry as cold seasons are coming soon and i think in spring time it's done.
Given to me by a friend yesterday.  It has been sitting in a shed for years.  Needs cleaned up, but rang like a bell when I struck it with a hammer. WEymass.jpg
I have one I bought new. That is (imo) a Russian made cast steel anvil, mine is 110 pounds. I bought mine knowing they would not last on the shelf, and they did not, they are discontinued.
Hello, I am new here, and I've already seen some familiar names! :D
Here is my new/used Mousehole.
M&H Armitage
Mousehole
0*3*15
I need to set it up, but time has me constrained at present to more pressing concerns. I hope to begin soon.
Edited by tanglediver
Introduction
"I use it once in a while to straighten something". I'd offered my young neighbor three hundred dollars for this years ago when I spotted it lying horn-first in the dirt. Really, the dollar amount wasn't an issue to my friend, probably thinking it far 004.thumb.JPG.e7d6ea44c45fad5edd3be7ce8d006.thumb.JPG.610109ec30f4a3cc3e9ac7a5a1too much to accept. "It's been here as long as I remember" he said, adding "but you can sure come over and use it if you need to".
Discovered this anvil today in the welding shop for the tugboat company I work for. Just wanted to share the pic for the size of the anvil (look at the spray can on top). No visible markings due to the paint on it and I didn't have time to try to clean it and look further. Unfortunately it has a pretty serious torch cut in the face near the hardy - and even more unfortunately - it's not for sale -- yet...... :)  I hammer tested it for ring with a small sledge - some ring near the horn - dull thud near the hardy and cut. It's got to be one of the biggest in the field anvils I've seen.
Looks like a Haybudden, or a Trenton anvil to me. (Haybudden made some anvils for Trenton, IIRC) I'd guess 180 lbs ish? Has an awful narrow waste... The damage isn't TOO bad, it could be restored...
Still need to make a stand for it but here is my 406lb Double Horn Mousehole
180lb Fisher that I picked up this past Saturday.
IMG_4273.thumb.JPG.74346d1805de8ed64ad91
unnamed.thumb.jpg.afa455627401add188b7a9unnamedsdfswfsd.thumb.jpg.844256f3587168
Hot cutter
11121.thumb.jpg.9a280c7beb56feee7114232a
I cleaned up all the cuts and made the hot cutter bigger and hit the whole top and horn with a flapper disc to smooth things out after taking these pics. I'll add some shots of the 2.5 footer once i get the horn cut into it.
Additional note: The rail is from 1950 and is some of the hardest steel I've ever tried to cut with a cut off wheel. I think I've put 4 discs into the 2.5 footer and I'm still only about 1/4" into the top of the track where I'm removing material for the horn.
Edited by neophite
posted 2 times
